What stock could Northern get to alleviate the current overcrowding and stock shortage problems?
Glenn1969
22 Jan 2019
Halifax, Yorks
They were already planned to get extra electrics from WMT I think. Don't hold your breath for any more diesel units any time soon
causton
4 Aug 2010
They started giving back 319s already, so just take some back!
Apart from that, 365s at Crewe are doing not a lot, so apart from gauging issues... or 315s likewise.
Wouldn't count on getting the WMT 323s anytime soon!
Kite159
27 Jan 2014
West of Andover
I believe there are some DMUs sitting idle in sidings near Selby and other places across the network... ;)
Ideal to attach to something like a single 150 to create a 4 coach set
Although the PR might not be so good if the pacers return :lol:
Southern Dvr
13 Oct 2010
damn you, I was about to suggest something that saved the railways of the north a few years ago myself!
plugwash
29 May 2015
Well there are the 769s, which are apparently (after much delay) finally getting close to entry into service.
I presume, once the kinks are worked out, converting the rest of the 319 fleet would just be a matter of money.
Anonymous10
19 Dec 2019
wales
Capacity is king I'll take a pacer over nothing
Mogster
25 Sep 2018
TPEs Castlefield services could stop at Wigan and Bolton again on their way to and from Scotland as they used to. Northern’s peak time services from Castlefield to those commuter destinations are rammed and TPE has been allowed to make their services unavailable, extra capacity is available each hour but not being used.
357 LTSRail
28 Jan 2020
Essex
Would love to see an HST Castle set on northern trains, shame it almost certainly can't happen really. 185s could potentially become available for cascade from TPE depending on Liverpool-Nottingham services. Is also potential for more 769s or vivarail units to supplement diesel fleet. For the electrics, I believe the pool of 319s and soon 321s will be plenty large enough to dip into - especially Greater Anglia's Renatus 321s - these feel like almost new trains to the passenger and should be ideal, as Arriva Rail North has had its own 321s. 332s from Heathrow Express a likely cascade too, fitting in nicely with the 333s.
markymark2000
11 May 2015
Western Part of the UK
You could give Northern 100 more trains but it won't do anything when the infastructure isn't there.
More electric trains won't help much as the majority of Northern routes are being ran in such a way so that a service may run under wires for 70% but that final 30%, it is on diesel lines.
More diesel trains would help but then you you have more diesel trains coming in with the 195s and you have some trains due to move in from other TOCs in due course.
Northern NEEDS Bimodes in my opinion to make use of the wires when they are there but also have the flexibility of vearing off onto the Windermere branch and Barrow in Furness (even if they just get a few bimodes and contain them to these lines as they are the biggest contenders for 'longest running of diesel under wires on a regular basis'.
plugwash
29 May 2015
I'd have thought crosscountry had about the longest regular "diesel under the wires" runs, running from scotland to York on electfied lines before veering off towards birmingham on a non-electfied line. When they used to ran via the west coast they ran even further under the wires as IIRC the route from the WCML to birmingham is electfied.
LNER and GWR also used to be big contenders for long diesel under the wires runs, but they have both mostly switched to bimodes.
markymark2000
11 May 2015
XC might be the longest (followed by Avanti Chester - Euston) but Northern isn't far off though. A good 70-80 miles under wires.
LNER and GWR I didn't include on the basis of them switching to BiModes.
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
And how many of those services are diesel powered and therefore able to run via Westhoughton? Going forward the answer is/will be none so its either/or, not both. The decision has already been made, and even then TPE is trying to avoid carrying Bolton/Manchester passengers travelling with-flow during the peaks. At some point the unpopular decision to cut Northern's Airport/Cumbria services at Lancaster may have to be made to reduce the mileage of diesels under the wires and using surplus EMUs from elsewhere to work south of Lancaster. If it's OK to remove 2tph from the Castlefield corridor, even though that's where passengers want to go, then cutting the Cumbria links should also be acceptable, albeit reluctantly. Unless of course those 769s can be made to work...:rolleyes:
Mogster
25 Sep 2018
TPE can run over Chat Moss to Wigan then join the WCML. They were doing this previously and the service was very/too popular. They run through Bolton now without stopping. This requires no more paths through Castlefield, just an additional stop at Wigan or Bolton for TPE. Stopping would seem to be an easy way to increase capacity and provide services if some of Northern’s services are to be withdrawn.
The Lad
22 Jan 2015
If the DfT are now running Northern even more directly than they already were, they could presumably kick all the nice to haves into the long grass and do a Windermere-Oxenholme shuttle with DMU and electrify the rest of the journey ( other examples could exist).
Kite159
27 Jan 2014
West of Andover
I would imagine something like some of the West Coast Glasgow/Edinburgh - Birmingham - Euston services run using voyagers will top the table for diesels under wires ;)
If Hitachi could manufacture a 4-coach 800, but with the body shell & seat layout of a 385, that would probably make for an ideal regional bi-mode.
TheWalrus
6 Oct 2008
I don’t think there needs to be any more DMU orders. The whole TfW fleet is coming off lease in the next few years. Plus the 221s from AWC and 222s from EMR, although I suspect XC will be the main contender for these. There are also HSTs off lease which could provide a shorter term solution.
IMO all new train orders should be bi-modes or electric, no more diesel only.
Meerkat
14 Jul 2018
But being less removed from the government makes it harder for the railway to do really politically difficult stuff like cutting off Furness and the Cumbrian Coast.
Are the 156s off EMR spoken for?
Meerkat
14 Jul 2018
If things got desperate are there any lines where loco hauled can keep to schedule and the trains are/need to be long enough to make it worthwhile?
Just tow the 365s about!
TheWalrus
6 Oct 2008
Although in a different region entirely, Cardiff-Taunton always seems to be the first to get loco-hauled services on the GWR, this could allow a cascade of DMUs to the North?
Mtrain
22 Jan 2019
I reckon that they should get the 755s like Greater Anglia. Possibly solve the short platform as they aren’t long but they are bi mode so they could do electric when possible. Maybe.
357 LTSRail
28 Jan 2020
Essex
Going to be an expensive option though with quite some lead time for delivery, not to mention another class of stock to train on. A CAF civity bimode would be more ideal I think, or even just plain DMUs. Would be nice if Alstom and Eversholt could produce their hydrogen class 321 though, as would be a better package than the class 230 offering from vivarail.
