What TOC’s require the national benchmark only?
Unknockable
4 Nov 2018
A couple years ago I sat an assessment which required me to pass at the enhanced standard. After some feedback I was informed I’ve met the national standard so I can apply to companies that only require that.
Dec_10
27 Oct 2016
Northern are one:)
Stigy
6 Nov 2009
You can apply to others, you’ll just have to resit the tests you didn’t me the higher standard in.
SWR is national standard.
Unknockable
4 Nov 2018
On my next attempt, I think it would be in my best interest to go for a TOC that requires the national standard only, hopefully something pops up soon!
Dynamonic
10 Jan 2013
Nottinghamshire
I reckon as time goes on, more and more TOCs will require an enhanced standard as a way of further filtering the increasingly high number of applicants. I understand that some TOCs have differing enhanced standards too for different tests, so what may not be the 'enhanced' standard for one TOC, may be the 'enhanced' standard for another too.
You should not be put off applying for TOCs that have an enhanced standard either, as you could be severely limiting your options.
Unknockable
4 Nov 2018
Yeah I think so aswell and understand that, I won’t be put off. Only thing I’m concerned about is when I have to answer on an application form ‘Have you previously failed a driver assessment test before’ I’m going to have to say yes and it will possibly stop me from being considered from the get go or will it not? Will they even be aware of the other tests I’ve met the standard for at that stage?
FGW_DID
23 Jun 2011
81E
Have you ‘failed’ it though? You have passed to the National Standard.
Stigy
6 Nov 2009
I think they just use that to indicate whether you have had your two goes. I’ve only seen one application form ask this too.
OneLowban
30 Oct 2017
I personally wouldn’t call ‘passing’ at national standard a ‘fail’.
There are just levels, anything past the first level (national) would be a pass to me. :s
Unknockable
4 Nov 2018
Oh yeah, you’re right. Got a bit confused there. I didn’t meet the enhanced standard for the group bourdon (I know I was very quick on that but I also had A few emissions) and The SJT, which was the worse part of the day. Some of the answers are so ambiguous
Stigy
6 Nov 2009
I don’t recall doing an SJT as part of the process other than for the MMI? I passed to enhanced level, however the Group Bourden is one I don’t understand being at that level. I had to redo this to meet the enhanced standard as my current pass mark wasn’t at that level (my initial tests weren’t to enhanced level anyway). I don’t recall doing anything any faster this time round than I did 3-years ago when I first took it.
387star
Thameslink have one of the highest pass requirements in the industry
DOO operators normally require a fault finding test which I passed with Greater Anglia
Cavey81
1 Feb 2018
GTR are only to national standard. I spoke to their HR last week and they confirmed this.
Unknockable
4 Nov 2018
Yes, mine was with Arriva and I had a fault finding test.
I would assume virgin also have the highest pass requirment since they don’t even hire trainees. Forgive my lack of knowledge here but what does DOO stand for?
Dynamonic
10 Jan 2013
Nottinghamshire
DOO = Driver Only Operation. :) Basically, trains with no guards.
Stigy
6 Nov 2009
If they don’t hire trainees and only qualified drivers, the assesments are irrelevant aren’t they? I know of somebody who went to work for them as a qualified driver but had to retake some tests which I found strange, but not Psychometric assessments.
ComUtoR
13 Dec 2013
It's called a 'Training Needs Analysis' All qualifieds transferring TOCs should undertake one. It's pretty standard procedure.
beavercreek
18 Nov 2011
I don’t buy into this “enhanced pass” or “pass”.
There will be other factors which will decide if you get employment within a TOC/FOC.
If you are already part of the railway you will have a massive advantage should a position become available at your depot.
People who pass to an high standard don’t always become the safest drivers.
I keep saying I’ll print out the GBT sheets and have a laugh in the messroom.
