Crayonista, n. One who performs strategic transport planning with a box of coloured crayons, using them to draw lines on a map, without thinking through the implications.
For example, suggesting the linking of the Northern City Line services with Southeastern services by constructing a link between Moorgate to Cannon St.
I
used to idly think that was a good idea when I was younger, having used both Moorgate and Cannon Street (and/or Bank on the W&C...), not appreciating the difference in height between them (which heavy rail could never cope with), not thinking that "
oh, yeah, that would be ridiculously expensive land to dig through with stupidly tight curves, and those bank vaults probably can't be easily pushed aside"
Now that someone's explained it to me, I appreciate that it'd be completely impractical - might make sense when you look at it on a map trying to join up lines with a jumbo box of Crayola but bears no relation to reality.
I don't mind people asking a question like this (I've probably asked my fair share of dumb questions over the years), but I do get fed up when people
still push their ideas over and over.
For example, I can see why someone sat in their bedroom would think that it'd be easier to stick a couple of extra tracks alongside the WCML (much like adding an extra lane to a motorway) instead of a whole new alignment (HS2). We know it'd be much easier/ cheaper to start from scratch instead (no disrupting the existing lines, no spare space to squeeze more tracks etc etc),but I can understand why someone would ask the question. The problem is when they don't listen to industry knowledge of people like yourself.
More frustrating than the youthful idealism of "can't we link X and Y" is the "we must go back to whatever route was closed fifty years ago" line of argument that gets applied to every problem as some kind of "miracle solution".
No it wouldn't. I know one of the mods and he is very tolerant. What doesn't get through is repeated use of the same argument by the same person for the same (fantastical) idea that has already been demonstrated to be unsound through reasoned analysis
OKEHAMPTON!
You are making a huge assumption there, though, by framing it as a choice between a busway and a rail link. More likely, it was a choice between a busway and nothing
True.
Some people take the "
I suppose it is tempting, if the only tool you have is a hammer, to treat everything as if it were a nail" approach very seriously - for them every single "problem" needs the "solution" of heavy rail.
Sometimes heavy rail is the answer, sometimes light rail is the answer, sometimes a busway is the answer (guided or otherwise), for some passengers flows a Dial-A-Ride minibus would be more appropriate - each have their own costs and benefits - sometimes it's not worth tackling every single thing on a wishlist.
The idea that everything could and should have been the most expensive option (heavy rail) and that there's no point in tackling it with any other option is naive.
We have issues shifting a path, how on earth is anybody going to move a busway !
You mean like the Busway in Edinburgh that was closed so that they could convert it to a tram?
