Why do (some) freight companies use older locos like the 37s or the 50s instead of newer 60s (for example)?
I think the 37s cling on in some parts due to their route availability - I think this is the reason the Cambrian uses the 97s (or why they fitted the ETMS to the 97s and hence why they now have a monopoly).
Why is that amazing?its amazing to think that are steam locos that are lighter than some modern diesels..
A class 9F, one of the biggest, most powerful steam locos to be built and run on the British Network. Compartive figures are tricky for all sorts of reasons, but they have a listed tractive effort of 176.45kN. It weighs about 141t on six axles (plus a tender? Think this is weight minus tender)its amazing to think that are steam locos that are lighter than some modern diesels..
agreed. they are really quite decent locomotives.you wont get better lightweight, all round locos such as the 37 and their sister fleets..they are easier to maintain, are near enough nuke proof , no digital engine management etc..just a human, Electro pneumatic , relays etc controls they can go anywhere literally, these new heavyweights might look great, but they are route limited...its amazing to think that are steam locos that are lighter than some modern diesels..
But also loco's such as 47's are just brilliant for all sorts of work like the sleeper, charters plus when Colas had them which are now used by GBRF they were on the Washwood-Boston steels and departmental.
still quite a lot.how many 37s and 20s are typically in use, over say a week?
So you plan on adding more kit in such as a transformer, a cab (which would have to be to modern standards) and still have the loco as RA5. And you get into acceptance issues and hacking around 40 year-old bodyshells. That's before you get into what the market is for such a machine. Still, not like an enthusiast forum to come up with ill-considered, expensive pipe-dreams, is it?agreed. they are really quite decent locomotives.
top+tail on the wherry line is quite an experience-they go like rockets!
I don't think too many people would have predicted the 20's lasting as long as they have, but as people on here have stated already it's the "go anywhere" low route availability in part that has given them their longevity.
the short wheelbase is the redeeming factor I think.not many other locos have it on the network...I think only 73's and HST.
just goes to show there is certainly a market for a low RA type 2/3 mixed traffic engine.Given that both 20's and 37's are now 50 years old +, maybe vivarail can do something with a "cut+shut" HST power car!
i)weld a duplicate cab on the blunt end and add relevant pipes+buffers
ii) re gear for 90mph
iii)pinch the panto's off 31x's going for scrap
iv) throw in new transformer rated around 3-4MW.
v)derate MTU power plant to 1600-1800bhp
vi) assign one alternator motor pole for selection to traction or ETH depending on load.
vii) improve the brakes to cope with unassisted wagons.
hey presto -it's a kwiksave dual mode 20/31/(nearly 37) replacement.perfectly capable of 500T freight or passenger car in tow, and RA5 so it has lots of options.
should weigh in around 80 tonnes and regearing (and maybe AC traction)will give you about 45-50 000lb/f of tractive effort.
37 will win on tractive effort given the extra weight and pair of powered axles but it could be a use for the old HST, and the MTU engines are quite new(around 10 years old), so plenty of life left.
ok epoxy it is then!You’ll not be welding an HST cab on, they're made of fibreglass...
The 60s in particular are hideously complex with extensive, but very dated electronics - this is the reason why DB was quick to sideline these when they didn't need them. Probably a factor in Colas selling them on to use 56s instead.
transformer- yes..not a problem. 3MW one is about 2500kg
cab- the existing ones from HST power cars are already acceptance tested for 125mph+ crash worthiness are they not?
you just have one at both ends..remove the existing guards area! you won't be running at 125mph!!!!!!
market- as said before. the utility loco's class 20-37 are 50 years+ old. they are end of life.
not to mention environmental concerns over their engines, and fuel economy compared to MTU4000.
I would wager such a construction would be considerably cleaner and safer than a class 20!
..or you can just be really pedantic and stick the MTU4000 into a class 91 instead. They will be going spare...and all the cab safety and electronics you are so concerned about is already there and proven- even the blunt end at 100mph.(the problem with that would be the it's rated for 6MW under the wires,so the diesel would be a bit underpowered)
for those so inclined,a photoshop might be slightly amusing if someone cares to conjour one up!
look- if we were doing health+safety on steroids then why do class 20's get driven blunt end first?
where there is a significantly higher risk of death or injury to the driver?
granted you gain a bit of extra visibility, but from a HSE risk assessors point of view on their nice little spreadsheet multiplier, you are slightly decreasing the likelihood of an accident, but vastly increasing the severity in injuries should they occur
(I have to do risk assessments!, it's frankly my pet hate)
nice!!..good find!You might as well couple two of the PCs fitted with draw gear back to back.
Interestingly enough, there's a pic online somewhere of a cut and shut PC model similar to what you just described.
Edit: Found it!
I've seen some unusual ideas here but re-engineering a class 43 with an additional cab and 25kV electric equipment...wow.
DRS are after some new locomotives to replace the older locomotives:
https://www.railforums.co.uk/threads/drs-planning-10-x-mixed-traffic-locos.168515/
As I understand it these will be the 93's which will 88's with a more powerful diesel engine able to match a 47 on diesel power:
https://www.railforums.co.uk/threads/new-class-93-not-ic250.169065/
https://www.railmagazine.com/news/n...s-fuels-its-ambitions-with-tri-mode-class-93s
"Grandfather rights" in this context are to do with pollution standards for diesel locomotives. Environmental legislation (currently an EU matter...) dictates that new locomotives and DMUs meet very stringent rules on their exhaust emissions. The Class 68s and 88s meet those standards, but other recent locomotives (e.g. 66s) do not. However, older locomotives only have to meet the standards that were in place when they were introduced into service, even if they are substantially rebuilt. This is part of the reason that a lot of money was spent rebuilding 73s with new engines - they are allowed to be more polluting than a brand new locomotive because they're a rebuild of an older loco.There's also "grandfather rights". I don't know what they are but I think it applies to BR units.
True but Colas didn't do a great job on maintenance as was seen on a YouTube video of 477xx when it caught fire at Bristol Parkway some years back.Until they go bang and break down like 47s nearly always do, or when they can't climb Old Hill bank![]()
You really have not thought this through.transformer- yes..not a problem. 3MW one is about 2500kg
I think you'll find that R.O.G are getting the 93's, and the design concept was an 88, but no-one knows what it will actually look like, but the base traction platform is that of an 88 with additions. As for DRS it was an initial order for 10 Diesel only mixed traffic loco's to replace 20's/37's and 47's. I still think this is a further order of 68's myself,but DRS have yet to announce who will build the locomotives so I may well be wide of the mark there.
