Ilford or in desperate times Bounds Green. Very occasionally Derby Etches Park or Hornsey are also used too.
These are desperate times![]()
Indeed, another 360 failed yesterday with rather large wheel flats/cavities.
Is there any YouTube footage of wheel lathe in action? I've looked and not found any in the past.
What's causing AGA to have so many units out of service with large wheel flats/cavities?
How long does it take to reprofile/repair a single wheel?
That's providing there's enough metal on the tyre to remove otherwise it's a retyre issue
Does a change of tyre mean removing the wheel from the bogie first?
At least 3 AGA 156's at Derby Etches Park yesterday.
They even approached EMT to lend them some unitshock:
NRW - GYM / IPS - PBO services to be cancelled tomorrow and for the rest of the week. Rail replacement buses are to be utilised, due to a lack of serviceable units..
"We apologise for the ongoing impact of train service cancellations affecting our local routes in Norfolk, Suffolk, Essex and Cambridgeshire, and for the inconvenience this is continuing to cause our customers. The problems are due to some of our diesel trains suffering wheel damage, as a result of poor rail conditions. This situation leads to excessive wear on the wheels which must be repaired before the trains can re-enter service. On average we are continuing to see two trains arrive back at the end of each day with wheel damage, more than double the rate we have experienced in previous autumn periods. This means that trains are having to be taken out of service for repair at a more frequent rate than previously experienced.
We are doing everything possible to repair the trains affected as fast as we can (including sending trains to other locations with spare capacity for wheel repairs - to speed up the process of returning trains back into service - and seeking to hire additional trains temporarily, though other train operators are suffering similar problems, so we have not yet succeeded) and we are working with Network Rail to try and improve rail conditions to prevent further damage. We hope to be able to eliminate these cancellations and restore the normal service as quickly as possible, however where we continue to see poor rail conditions, necessitating the need to continually carry-out repairs to the trains incurring damage, the situation remains a challenging one. In the meantime, we are seeking to minimise the impact of the disruption by providing bus replacement and other alternative services wherever practical to cover for the cancelled train services"
Here's a surface (or above floor) wheel lathe in action: https://www.youtube.com/watch?v=uRqeKL5VsjIIs there any YouTube footage of wheel lathe in action? I've looked and not found any in the past.
Not helped by AGA requesting a reduction in RHTT trips a couple of years ago as lineside clearances were supposed to have reduced the problem and they claimed the RHTTs were disrupting their services :facepalm:
And while not a lathe, here's an underfloor wheel truing machine that might be in use in that wheel shop: https://www.youtube.com/watch?v=Ip1VUnQPVhE
