Where is the wheel lathe for AGA trains?
skfl
19 Nov 2015
:idea:
Thanks. I think the second video is more like the real world for wheel machining as most if not all "lathes" do not require the wheelset to be removed from the unit.
Transit? Agreed. Freight + heavy haul, though, will often use above floor truing machines (lathes or milling) that require the wheel sets be removed - granted, other actions are also likely being performed to the wheel set components.
28 Jun 2012
Epsom Downs
You cannot do a single wheel, both wheels on any axle have to be identical diameter. But I believe using a modern wheel lathe whole 4 or 5 car units are done in only a few hours, they are usually in and out in the same day.
both wheels have to be the same size as you say but to complicate even further power axles on a DMU need to be the same or the final drives can have issues by the master and slave not having parity.
Wimbledon Park has a nice new double headed lathe so both wheels on a bogie can be turned at the same time.
Class 170101
1 Mar 2014
Not helped by AGA requesting a reduction in RHTT trips a couple of years ago as lineside clearances were supposed to have reduced the problem and they claimed the RHTTs were disrupting their services :facepalm:
Is this because NR insist on running them whilst the train services run rather than prune their maintenance time and run the RHTT overnight when AGA are not running trains.
TheEdge
29 Nov 2012
Norwich
Would it make a difference if they did, in terms of money probably yes but in terms of time probably not
What? Of course it would save time. If there was a wheel lathe at Crown Point then there would be no need to send stock to join the queues for the lathes at Ilford, Hornsey, Old Oak or Etches Park. The DMU, Mk3 and 90 fleets could be quicker turned around at CP.
SpacePhoenix
18 Mar 2014
Are all the units with flat spotted wheels all based out of one depot of various depots?
jopsuk
13 May 2008
All of AGAs DMU fleet is based at Crown Point in Norwich.
They do have a small fleet of micro fleets, which doesn't help. They've got 5 153, 9 156, 4 2-car 170 and 8 3-car 170
DarloRich
Fenny Stratford
what maintenance time? There is little spare time. Ours on WCML south run:
Bescot - Rugby - Macclesfield - Rugby - Northampton - Bletchley - Bedford-Bletchley- Euston
On the way back it runs Euston - Watford - St Albans - Euston - Northampton - Rugby - Bescot covering up all lines
It leaves Bescot at 10:50 and returns at 0632. In that time you have to feed and water the locos, attend to any minor maintenance and more importantly fill the water tanks back up
14 Aug 2012
Stratford
Suppose you have a point, would any lathe a CP obstruct the depots other daily business though
jopsuk
13 May 2008
So that's a sophisticated ultra-modern lathe that can process effectively six bogies in seven hours. I'm guessing older lathes take longer? If anyone's trying to keep score on times!
Even before this autumn AGA have had long running reliability issues across their DMU fleet- which as previously highlighted is three micro-fleets of different classes, one of which has two different formations. The units are operating out of two hubs - Ipswich and Norwich - but there's just the one depot, shared with the Intercity fleet and by reputation overcrowded. So much so that some of the Intercity formations are a carriage shorter than the rest entirely because of space at the depot.
What is the solution? A separate depot? But if so where? A uniform fleet? That would be madness, several of the routes really do merit only a single 153 whilst others really do need those 3-car Turbostars.
SpacePhoenix
18 Mar 2014
Who could AGA do swaps with (and swapping what for what) to get rid of their microfleets?
D365
29 Jun 2012
:roll: I think you're missing the point entirely.
In an ideal scenario, electrification between Ipswich and Cambridge would find us a home for the Class 317s going spare by the end of the decade. But by then a new depot really will be needed!
jopsuk
13 May 2008
Well yes- electrification should ideally "sort out" Ipswich-Cambridge, Peterborough and Felixstowe and Cambridge-Norwich, plus the Sudbury branch (which some would like included into a Cambridge-Haverhill and on to Colchester reopening, but that's another, somewhat fantasy, scheme).
