Should all 4 Northern East-West routes (via Huddersfield, Calder Valley, Hope Valley and Tyne Valley) be electrified?
Which should happen from the start anyway imhoElectrification, if it happens, will come under East West Rail.
Why not carry on the electrification that far, then? You could totally eliminate diesel (passenger) haulage in north-eastern England that way, and get the option of running diversions/freight up the Durham Coast as well.If you accept that the loss of occasional GSW services isn't much of a big deal (especially as it keeps things "neater" for ScotRail/Northern), the only operational problem is the trains that carry on to Sunderland/ Middlesbrough
A very quiet line with about 20 trains every 24 hours, almost all of which are diesel hauled freight trains. I was in Gladstone Park the other day and was most surprised actually to see a train! An empty cement train returning to Hope behind a Class 66 which would not be helped by electrification of the line.Also I would electrify the Dudding Hill line even if it means changing the tracks to increase line speed and resignalling which means colour light signals will replace semaphores on the line
It's a very interesting argument against electrification: "We shouldn't electrify this line because electric trains don't currently run on it".A very quiet line with about 20 trains every 24 hours, almost all of which are diesel hauled freight trains. I was in Gladstone Park the other day and was most surprised actually to see a train! An empty cement train returning to Hope behind a Class 66 which would not be helped by electrification of the line.
Try again. The case against electrification is that the route carries very little traffic. The supplementary argument is that it's a freight only line, and most if not all of the freight trains using it will be diesel hauled anyway because the destination has no OLE; e.g. the Hope Valley line.It's a very interesting argument against electrification: "We shouldn't electrify this line because electric trains don't currently run on it".
The "almost all of which are diesel hauled freight trains" section triggered the response. In this case, electrification would coinside with the re-introduction of passenger services, which would nullify your objections.Try again. The case against electrification is that the route carries very little traffic. The supplementary argument is that it's a freight only line, and most if not all of the freight trains using it will be diesel hauled anyway because the destination has no OLE; e.g. the Hope Valley line.
There is a mooted scheme to run passenger trains from Hounslow and Kew to Brent Cross. The London local authorities behind the scheme plan to use DMUs. To the best of my knowledge, the only non freight trains using this route are Chiltern empty DMU stock workings to Willesden LMD via Neasden South Junction and Acton Canal Wharf Junction with a reversal at Stonebridge Park.The "almost all of which are diesel hauled freight trains" section triggered the response. In this case, electrification would coinside with the re-introduction of passenger services, which would nullify your objections.
Currently, there are a lot of lines above it in the elctrification pecking order, and I don't think it should get any priority.
We do need electrification on lines like Felixistowe which would allow higher-efficiency electric trains on freight. If we replaced some freight by electric, that would be more efficient and we can replace a less powerful diesel by a faster-accelerating fast freight electric.The "almost all of which are diesel hauled freight trains" section triggered the response. In this case, electrification would coinside with the re-introduction of passenger services, which would nullify your objections.
A lot of chords could do with electrification.There is a mooted scheme to run passenger trains from Hounslow and Kew to Brent Cross. The London local authorities behind the scheme plan to use DMUs. To the best of my knowledge, the only non freight trains using this route are Chiltern empty DMU stock workings to Willesden LMD via Neasden South Junction and Acton Canal Wharf Junction with a reversal at Stonebridge Park.
So? What do you conclude from that?A lot of chords could do with electrification.
That this is low-hanging fruit that is easy to achieve but would make relatively large impacts on de-dieselisation.So? What do you conclude from that?
I have no idea how you arrived at that conclusion. Very few, if any, of the very few trains using this line terminate in areas with OLE so they will continue with diesel locomotives. We already have diesel hauled freight trains on long stretches of electrified railway but those stretches of track at least have passenger trains and the occasional freight train utilising the electrification. This route would not. It would be a unique and eccentric railway line: an electrified line with not one train using the electrification!That this is low-hanging fruit that is easy to achieve but would make relatively large impacts on de-dieselisation.
E.g. Felixstowe Branch? Daventry Yard?I have no idea how you arrived at that conclusion. Very few, if any, of the very few trains using this line terminate in areas with OLE so they will continue with diesel locomotives. We already have diesel hauled freight trains on long stretches of electrified railway but those stretches of track at least have passenger trains and the occasional freight train utilising the electrification. This route would not. It would a unique and eccentric railway line: an electrified line with not one train using the electrification!
I generally meant short lines,E.g. Felixstowe Branch?
That's not what you said earlier. In reference to installing OLE on the Goods Line running from Acton Wells Junction to the MML, you said "That this is low-hanging fruit that is easy to achieve but would make relatively large impacts on de-dieselisation".I generally meant short lines,
It would be a major interchange line if it gets electrified and upgraded especially if the lineA very quiet line with about 20 trains every 24 hours, almost all of which are diesel hauled freight trains. I was in Gladstone Park the other day and was most surprised actually to see a train! An empty cement train returning to Hope behind a Class 66 which would not be helped by electrification of the line.
Obviously electric trains don't run on the line because it's not electrified!It's a very interesting argument against electrification: "We shouldn't electrify this line because electric trains don't currently run on it".
That was the entire point of my post. See discussion in posts #163 - #165.Obviously electric trains don't run on the line because it's not electrified!
Possibly but not certainly. Can you name any specific traffic flows which would result from electrification of this route?It would be a major interchange line if it gets electrified and upgraded especially if the line
Joins the Great Western Main Line then services can go from the MML to Heathrow Airport and Reading.
I’d electrify Didcot Parkway to Coventry via Kenilworth
Leamington Spa to Worcester Shrub Hill via Kidderminster
