Which iPhone would you recommend in 2024?
Buzby
14 Apr 2023
Glasgow, Scotland
Yes it covers the Airpod, so instead of slippy plastic in your ear this gives some friction to hold it in place. If that is not to your liking an alternative design wedges the Pod within the ear shell and is called an ear hook - however when I tried this I couldn’t make it comfortable for extended use. (Item No 225076158683)
sor
15 Nov 2013
Unless you're wedded to the Apple infrastructure, it may be worth casting your eyes over the world of Android. Very functional phones can be had for very little money.
one major selling point for the iPhone is that you are virtually guaranteed to get software and security updates for a lot longer. It is also much easier to get genuine repairs done, particularly the battery which is guaranteed to go at some point.
if cost was a concern I'd go for a used iPhone over a new Android device any day, and you'd likely get a far better device overall (cheap Androids can be very meh). I gather the 2022 iPhone SE is a good buy. I have the 2020 model which is the same externally but has older innards (no 5G and an irritatingly bad battery life) - I gather the newer one has both issues fixed. As the SE typically uses older case designs to save money, I wonder if this will be the return of the mini that a few people here want to see.
As 3G shutdown looms, it is important to buy a phone that supports 4G calling. All iPhones from the 6 onwards support it on every network, but Android again can be hit and miss especially if you aren't a direct customer of the big 4 - I have a Nokia here that has 4G and wifi calling with a Vodafone SIM, but not a Lebara SIM even though they use the same network and appear to use the same internal systems.
The only bugbear is that the latter is the only model which still has Touch ID, and I'm not sure if I can get my head around Face ID just yet (although should be able to once I've had a bit of practice!).
If you do (I upgraded to a 14 pro last year from the aforementioned SE), you might find it quite a nice change - you just have to look at the phone (and it does check, you can't just point it at your head). The only thing to watch out for, if you use Apple Pay, is to double tap the power button and select the card *before* you put it near the card reader. I've made a few payments on the wrong card by not doing that. It's great when wearing gloves as well.
Tetchytyke
12 Sep 2013
Isle of Man
I switched from Samsung to an iPhone 13 last year and I think you’d love the Face ID. It’s so much easier to use as you just look at your phone, great if you’re wearing gloves etc. And it is secure, it does check, I’ve tested it with family members.
I’d recommend the 13 and, now the 15 is out, there’s good value to be found.
Mcv378
31 Dec 2023
Don't forget if you buy on Amazon it will allow you to make monthly payments on an iPhone
507021
19 Feb 2015
Chester
None of them, get an Android, preferably Samsung
I've had a couple of Apple products (two iPhones and an iPad), but got fed up with them in the end and decided to go back to Samsung. Haven't regretted it.
Jamesrob637
12 Aug 2016
I have an iPad because it cost the princely sum of 0 back in 2015 :D
