MatthewRead
Has anyone read the latest issue of RAIL it says these trains could end up in the Isle Of Wight and even the Scottish Highlands.
The problems with having small fleets all over the place are well documented. However, without these drawbacks, I would say the following lines:
- Barton on Humber branch
- Conwy Valley
- Heart of Wales
- Cornish Branches
- Kirkby - Wigan shuttle
Various commuter services onto preserved lines may also work:
- East Lancs
- Keighley & Worth Valley
- Severn Valley
Correction Bromley North.Or even Bromley South branch...
You didn’t need RAIL, Some sort of 230 variant for the IOW has been discussed regularly in these forums since last year some time...Has anyone read the latest issue of RAIL it says these trains could end up in the Isle Of Wight and even the Scottish Highlands.
I would be seriously against that.In the Highlands, a battery version for a Georgemas Junction - Wick shuttle would work well, and would also significantly reduce journey times on the FNL. The units could possibly also be good for Inverness -Elgin/Dingwall local services, freeing up 158s for longer FNL/Kyle services and perhaps WHL services.
I had thought that they might be useful for Inverness - Elgin services, but wouldn't they perhaps be a bit too slow? Mind you, if they're better at accelerating than a 158, this might not be so much of an issue. A quick charge at each end and the battery version might be a good fit.In the Highlands, a battery version for a Georgemas Junction - Wick shuttle would work well, and would also significantly reduce journey times on the FNL. The units could possibly also be good for Inverness -Elgin/Dingwall local services, freeing up 158s for longer FNL/Kyle services and perhaps WHL services.
They don't have to have longitudinal seats. Any more than long-distance trains have to have airline seats with no window (to which, I'd say, the same lack of desirability applies). What the operator chose here is to retain an area of longitudinal seating (along with many other lateral pairs) so as to provide a greater amount of standing room on the few services (at school times) that are extremely busy. They may have elected for such a layout were the train a brand new shell for the same reason; a reason that makes perfect sense......sit longitudinally.....
Must admit I overlooked that completely. Fair enough on that point.They don't have to have longitudinal seats. Any more than long-distance trains have to have airline seats with no window (to which, I'd say, the same lack of desirability applies). What the operator chose here is to retain an area of longitudinal seating (along with many other lateral pairs) so as to provide a greater amount of standing room on the few services (at school times) that are extremely busy. They may have elected for such a layout were the train a brand new shell for the same reason; a reason that makes perfect sense.
Firstly, a micro fleet of 5 units would be really silly, especially for depots with serious staff shortages and ScotRail's current training problem.
Secondly, the dead mileage. The Caithness shuttle would have to dead run for 200 miles down to Inverness for servicing. Better to make it a 158 so it could interwork with the full length Far North services.
Far better to have more 158s.
Because of the way Georgemas Junction works, the shuttle has to run Georgemas to Wick, with the main service from Inverness reversing and continuing to Thurso. I can explain more if you want.I think the 230s would be good on lines like Glasgow - Anniesland via Maryhill, short journey times with relatively low speeds. I think the 230s could be useful for new shuttle services, for example an hourly service in each direction between Thurso and Wick to keep these remote towns better connected. It could also help reduce journey times if you had services from Inverness - Wick avoiding Thurso with the shuttle going to Thurso instead. No matter where they go some people are going to be benefited and others not, but it’s about what’s best for most people.
Multifunction (PRM/bicycle/large luggage) coaches on Belgian railways have longitudinal seating for similar reasons. I'm not sure why it's so hated in the UK and we seem to prefer 3+2 facing bays where you play footsie whether wanted or not.And also to allow for an effectively unlimited capacity for bicycles, of which there are almost as many as passengers on this line, and they had already officially allowed more than the usual 2 (up to 6 at guards' discretion I believe) even on the 153s by allowing them in the wheelchair space provided the passenger agreed to alight in the unlikely (on this line due to poor accessibility at Bletchley) event of a wheelchair user wishing to board.
If the short section of 50mph running on the WCML didn't get in the way too much, the Ormskirk-Preston-Blackpool S-Preston-Colne-Preston-Ormskirk circuit would probably be a suitable candidate for a few, replacing the usual Pacers with something quite a lot nicer. You could do some promotional work by branding them up for the "Lancashire Lines" (as that circuit was known some years ago).
Diagrams would have to be altered because of the way Whitby services extend to Newcastle, Hexham, Carlisle etc. The Esk Valley line doesn't have a self-contained diagram.The Esk Valley line to Whitby would be an ideal route for 230s
I'd be interested to hear of the operational restrictions as Georgemas Jn. In any case though, I would have thought the solution would be to run pairs of 158s and split at Georgemas. If usage doesn't justify that, then I'm sure there are cunning plans available involving 153s, of which Inverness are to gain a microfleet anyway.Because of the way Georgemas Junction works, the shuttle has to run Georgemas to Wick, with the main service from Inverness reversing and continuing to Thurso. I can explain more if you want.
I continue to register my disagreement with having a micro-fleet of one or two units for a Caithness shuttle. Keep the fleets homogenous (IE: 158s).
You consider the 230 to be unsuitable for the service to Newcastle from Teeside? Or even Hexham? I wonder what is so appealing about a 156 in this context.Diagrams would have to be altered because of the way Whitby services extend to Newcastle, Hexham, Carlisle etc. The Esk Valley line doesn't have a self-contained diagram.
Well yes, but diagrams do change regularly - and I suspect that once the Pacers go then we will see a fairly large rejig of timetables and diagrams.Diagrams would have to be altered because of the way Whitby services extend to Newcastle, Hexham, Carlisle etc. The Esk Valley line doesn't have a self-contained diagram.
