Why don't the Class 345s have toilets?
CBlue
30 Mar 2020
East Angular
When I was a a semi-frequent traveller with National Express East Anglia it was a foolish expectation that the toilet equipped late night trains even had them in service!
cactustwirly
10 Apr 2013
Most journeys on the 345s will be roughly 20 minutes long. Besides, most stations along the route will have a toilet, so you passengers go there, freeing up space for seats/standing space on the train.
This is not true for the Western end, only for the sections to Abbey Wood and Shenfield.
These trains should have a similar interior to Thameslink for services out to Reading
CBlue
30 Mar 2020
East Angular
How long is it out to Reading on the stopping service? Surely we should fit the S stock on the metropolitan line with toilets too given the journey times possible, with that logic?
Horizon22
Jobs & Careers
8 Sep 2019
Maidenhead to Abbey Wood would be 67 minutes. I didn't pick Reading because they'd probably take a GWR fast service and change. You can see the estimated journey times here - https://www.crossrail.co.uk/route/
TfL don't have toilets on any stock they run and which may also have been a factor in their design.
CBlue
30 Mar 2020
East Angular
Indeed - even when they ran toilet fitted Class 317/7s I understand the toilets were locked out of use.
cactustwirly
10 Apr 2013
Just over an hour from Paddington
Energy
29 Dec 2018
They would also need somewhere to empty the toilets in the depot...
73128
8 Dec 2019
Reading
Just under an hour to be pedantic. However Ealing Broadway, Slough, Maidenhead and Twyford (at least) all have toilets open all reasonable hours on the platform side of any gates should you need to have a break.
PeterC
29 Sep 2014
I know that when Maidenhead was first proposed as the western terminus there was a lot of campaigning for an extension to Reading. Be careful what you wish for!
Not this again.
Their predecessors on the east side didn’t have toilets. Neither did their predecessors.
Neither does the Piccadilly line, for example, and you can be on that for an hour and a half from North London to Heathrow.
Not this again.
Nor does Merseyrail, which is basically the same idea. Nor LO, which also is.
28 Aug 2019
Essex
They could probably fit them in on the class 345 trains at a later date should it prove necessary for passengers to use toilets on the train.
I completely agree. Provision of public toilet facilities generally is woeful in this country, and due to the nature of who tends to get issues requiring frequent toilet use and the practicalities thereof it is discriminatory on all three of age, gender and disabililty - does anything else at all get three in one go? Yet it is overlooked.
If I cannot find a toilet I just find a suitable place to go I’m sorry but going a toilet is a human right not a luxury! You are correct as the provision of toilet facilities are poor in this country considering how rich this country is!
cactustwirly
10 Apr 2013
Not this again.
But the Piccadilly line doesn't run out to Reading does it...
And it's not £15 for a single journey either.
It's like saying trains to Horsham don't need toilets
Horizon22
Jobs & Careers
8 Sep 2019
Surely distance isn't the issue but time?
Location doesn’t have anything to do with it. It’s typical journey time. Paddington to Reading is (or will be) under an hour on these trains. That’s the same as Kings Cross to Heathrow by Piccadilly. What’s the difference?
Some trains to Horsham didn’t have them. Some SWR trains to Guildford, and dare I say Reading still don’t.
py_megapixel
5 Nov 2018
Northern England
Even if there were going to be trains all the way through from Reading to Shenfield you'd have to be insane to use them for the whole thing. It would always be hugely faster to go into Paddington with Great Western and out again with Greater Anglia from Stratford (obviously with a Crossrail leg in between).
cactustwirly
10 Apr 2013
Unless you live in Maidenhead for example
306024
23 Jan 2013
East Anglia
Or indeed crossed legs in between.
py_megapixel
5 Nov 2018
Northern England
Indeed...
I do think a couple of toilets would have been a good idea (preferably clearly marked on the outside and on the PEDs); the point I was making was that whether there will be direct trains all the way from Reading to Shenfield is pretty irrelevant.
306024
23 Jan 2013
East Anglia
While having every sympathy with those that need to use the bathroom frequently, these trains were designed pre Covid for 1500 capacity. Toilets would be a total inconvenience during crush loading, and certainly won’t be fitted retrospectively. Even at 1000 capacity by the time you joined the queue to use the toilet you’d have passed your stop.
A 12-car 700 appears to have a total capacity of about 1700 according to Wiki, and that has them.
Carntyne
8 Jul 2015
There's no DDA issue as there aren't any toilets. If there was a standard or "space saver" toilet and no DDA compliant one, then you'd have a point.
43096
23 Nov 2015
As per the sign at Ipswich:
“Toilets closed, we apologise for the inconvenience”
"We apologise for the inconvenience of this convenience being closed. We hope you are not too inconvenienced."
