As I understand it, eddy current brakes have been routinely fitted to trains running in Germany since the 1990s. This technology uses an electromagnet to induce an electric field in the rails, the resistance of which produces braking force. Unlike the emergency electromagnet 'track brakes' fitted to street-running trams here, it does not touch the rails and no friction is involved, nor does using it cause any damage to infrastructure.
I don't believe it would be possible to regenerate current using such a system, but — similarly to the current norms that combine regenerative braking with a 'backup' conventional disc brake — it might be sensible to include the equipment as part of a suite of options that a train could use to slow down, or even held in reserve for when the wheels lose traction. Of course, the reason I thought of this is the recent collision near Salisbury, where it seems like a non-friction-based brake could have helped.
Is the absence of such technology down to a particular reason, or is it simply a case of "we just never started doing it"?
