Yes I suppose you might like me to muddy the waters of this conversation down to pros and cons of the project, rather than concentrating on the core issue. Given your involvement, I am sure you will be aware that "HS2 isn't just about speed".
Except perhaps what stopped it last time?...
I say again, I think there are people in Liverpool who would like to put a lot of questions to you if you would be willing to meet with them?
You are right HS2 isn't just about speed (although Liverpool benefits to some extent on those grounds with journey time savings, although they are not as big as they could have been with a new line all the way), it is also about capacity.
At present there is 1 fast service per hour whilst after HS2 opens it is expected that there will be two fast services per hour. However there will also still be the services from Crewe which for one service an hour currently take about 15 minutes longer than the fast services. Under HS2 these local services will still exist and so it would likely be possible to travel to Liverpool via Crewe in under 2 hours going via Crewe (even allowing 15 minutes to change trains). As such going this "slower" route would likely be only about 20 minutes slower than going direct (but depending on times could still be faster than waiting for the next direct HS2 service) but also would be about 15 minutes faster than the current fast service.
As such there is likely to be three trains an hour which would get you form London to Liverpool faster than the current direct train (up from 1), it could be that there is enough demand for the existing direct train to be retained, in which case it would be four trains an hour (that are as fast or only slightly slower than the current direct train, assuming a few extra stops on the existing direct train). 4 trains per hour with a journey time to London of less than 2:15 compared with 1 train per hour currently would, even if they were shorter than the current 9 coach 390's, provide significantly more seats per hour than the current timetable.
The current 11 coach 390s have 589 seats, even allowing just 350 seats per train on a frequency of 4tph would be 1,400 seats, or 2.4 times the number of seats. Chances are the two direct trains per hour would have about 550 seats each (1,100 vs 589) meaning that the other one or two services would only need a few hundred seats in total to make up the difference.
I'm sorry but whether you like it or not, Liverpool are getting faster trains (although not such a big saving as some other places which are on the HS2 lines) and more capacity (again, not such a big uplift in capacity as other places).
Personally I wouldn't be surprised if HS2 phase 1 gets filled up with trains meaning that it becomes viable to build a High Speed line which runs straighter up to Leeds which then allows more services to run to Liverpool and therefore increases the need for a High Speed line to Liverpool.
