James James
- Joined
- 29 Jan 2018
- Messages
- 426
Manufacturers existing traction control systems don't speak a "standard" yet. So, first off, you'd have to spend time and money developing a standard that can fulfill the needs of a modern train (remember, we now have things like regenerative braking, hybrid trains, etc.). Developing standards is slow and expensive - that's the first chunk of money neeed.Why would requiring people to comply with a pre existing standard put up stock procurement and maintenance costs a lot?
One modern IP (if we are going to go modern and have a generational break in compatibility) based system will be entirely compatible with another.
Any datagrams not understood by a vehicle would simply be ignored but passed down the chain unaltered.
You then specify a basic control set at the beginning that all vehicles must understand, and a basic PIS standard based on similar standards for messaging that are used elsewhere.
If we are standardising on the Dellner we should fit the locos only with Dellners and abolish buffer type couplings entirely.
Once that's done, every manufacturer has to build new traction control systems that can speak this standard. That costs more time and money, which translates into higher rolling stock prices. Past evidence (e.g. SBB DPZ/DTZ) suggests that manufacturers aren't able to build systems that can speak to older existing trains - that should be easier with a formal standard, but not significantly easier.
This isn't consumer software development, things are slow and expensive when building safety-essential software. Just like avionics, train systems aren't cheap. And every one of these systems will need to go through a lot of testing and certification. You don't want some edge case to cause the emergency brakes to not activate on half your train...
