Woking Junction is capacity constrained, so some up main line trains from the Portsmouth route bypass Woking completely by using another route from Guildford, making use of the existing grade separation to join the up slow just south of Surbiton. Some down trains also go that way, but presumably not because of the same junction limitations.
I think only a subset of drivers have that route knowledge, but the advantage is that it also helps with engineering diversions. Now if the Woking flyover got built, up mainline services would not need to take that route, so the pessimists think that the route knowledge would therefore be removed, and that's always considered a bad thing...
Losing any route knowledge is a bad thing especially from Woking or Guildford, there are simply too many variables in there.
SWT have cut the routes back over the years so that we now get to the position they find themselves in today where if something goes kaput between Woking & Surbiton, they're more stuffed than a turkey at crimbo.
Key diversions should be on all drivers route tickets, even if it means resorting to special route learning trains.
Key diversions should be:
Portsmouth line.
Guildford - Effingham - Cobham - Surbiton
Guildford - Effingham - Epsom - Raynes Pk
Guildford - Aldershot (Rev.) - Woking
Woking - Eastleigh - Fareham - Hilsea
Woking - Chertsey - Hounslow/Richmond - Clapham
Bournemouth Line.
Southampton - Swanwick - Cosham - Havant - Guildford (used regularly)
Eastleigh - Fareham - Havant - Guildford
I mean if you get diverted twice then it's probably going to be what's known as Code Black anyway so the service is completely stuffed.
But I find it deeply shameful that I cannot do some of these diversions and I have to leave passengers marooned wherever I'm told because I can't divert due to lack of knowledge.
If it means spending some money to give passengers a seamless journey then it should be done, whilst they're going to be a tad late, they're going to get there and it boosts the corporate image, instead of denting it.
