Worcester - van on track 4 March 2024
Henffordd
27 Apr 2023
The Marches
Local press (Hereford Times) picked up a story about a vehicle blocking track "between Worcester and Hereford" Picture shows a van which appears to be on the railway bridge over the Severn at Worcester. Now, how did it get there?? Picture credit Anil Patel of Worcester News
GatwickDepress
14 Jan 2013
You can't park there, mate.
Pause for raucous laughter.
How does this even happen? It's a fair way to the bridge from the nearest level crossing, isn't it? Surely at some point you'd realise you were no longer on the King's highway.
hexagon789
2 Sep 2016
Approximately 260m, but that is reportly what occurred - wrong turn at crossing, then carried on until struck bridge. You would think driving over sleepers abd ballast would be rough enough to 'waken' them up to their error.
Accidental turn at level crossing? Or a desperate attempt to flee the police like that case near London a couple of years ago? A high clearance van will probably cope ok with conventional ballast and sleepers, but fail big time on a bridge with timber waybeams, and gaps everywhere between the rails…
styles
7 Dec 2014
Midlothian
Nope - happens regularly in Nottingham on the Lenton Lane tram bridge. There's something silly like 12 no entry/tram only signs, rumble strips, road markings, on approach and once every few months somebody still manages to drives onto the bridge.
The concrete from either side of the rails disappears, leaving a challenging balancing act to get to the other side of an arched bridge, which they're never successful at.
Photo from Joseph Raynor/ Nottingham Post.
Cars from Google Images getting stuck:
YorkRailFan
6 Sep 2023
York
hexagon789
2 Sep 2016
Oh dear :oops::rolleyes::lol:
John Luxton
23 Nov 2014
Obviously someone paying too much attention to the Sat Nav!!!
About a decade ago I bought my first car with a built in sat nav.
Having never used one before I set it up for a journey from my work place to Liverpool Costco about 4 or 5 miles out of curiosity to see if would take me the route I had always used.
I was amazed when it showed me a route into the Wallasey Tunnel which ended in the tunnel.
Liverpool Costco and the the Wallasey Tunnel ventalation shaft are adjacent to one another and obviously share the same post code which obviously accounted for the glitch.
All my subsequent cars have had Sat Nav - but I treat its advice with a pinch of salt as some of the suggested routes are not ones I would take because I know a better way.
Sat Nav is a useful took if used in unfamilar areas - but drivers need to realise it doesn't replace common sense!
Did you see post #11? I suspect it’s likely nothing at all to do with satnav…
75A
31 Mar 2021
Ireland (ex Brighton 75A)
On a dull day I have been known to use the one built into my Land Rover and the one in my smartphone at the same time, quite often they'll have different routes in mind.
bleeder4
19 Jan 2019
Worcester
Sat navs sometimes deliberately guide their users down a longer route to their destination so that they can gather accurate data on how long that route takes. There are always multiple routes between two points and sat navs need to display to their users how long each of those routes will take. It is by occasionally picking a random user as a "guinea pig" that they gather that data.
rower40
1 Jan 2008
My early satnav had quite a fit when I took it on Eurostar, and it kept trying to lock on to the adjacent M2 on the Medway Viaduct.
86206
12 Jan 2015
Incorrectly (surprise) Worcester News at one point had the van getting on the track at Foregate St.:lol: Images of Mini Coopers a la The Italian Job spring to mind
Oxfordblues
22 Dec 2013
Why do these vehicles always have fuzzy, illegible number plates? Is it to protect the idiots' identity?
nickswift99
7 Apr 2013
A hobby exists involving members of the public writing down numbers of vehicles on the railway. This is clearly an attempt to frustrate them collecting all the instances of this class.
notverydeep
9 Feb 2014
Perhaps a heritage railway will host this Transit as visiting traction on an upcoming diesel gala…
Benjwri
16 Jan 2022
Bath
As much as some people like to theorise this every now and then, there is no evidence or admission that this happens. However what does happen in a fair few systems is a objectively longer route will be offered, under the principle that while for one user the route is quicker, if everyone took it the route becomes the longer one.
