Youth hostels & B&Bs in Cornwall
Drsatan
24 Aug 2009
Land of the Sprinters
Hello everyone,
In late May or early June I'd like to travel around Cornwall using a 'Ride Cornwall' ticket. To avoid wasting too much time traveling too and from where I live, I'm considering staying in a B&B or Youth Hostel (preferably the latter since I'm a student and they're a bit cheaper). Can anyone on this forum recommend any good Youth Hostels or B&Bs in Cornwall?
7 Nov 2009
Newcastle
I remember someone talking about a converted carriage either at Dawlish or Dawlish Warren, may be worth a look.
Mojo
7 Aug 2005
Have you looked at Travelodge? There are 6 in Cornwall and 1 in Plymouth and rooms start at £19 depending on the date. This can often be cheaper than a hostel and especially good if, like me, you object to sharing rooms with strangers.
Hayle is about a 25 Min walk from the station
St Austell is about 16 Min walk from the station
Roche is about a 5 Min walk from the station
Newquay is opposite the station
Saltash is about a 30 Min walk from the station
There is also one in Wadebridge but is about 14km from the nearest station (Bodmin Parkway). There may be local omnibuses, I'm not sure.
Drsatan
24 Aug 2009
Thanks for your suggestion Mojo, but I've looked on the Travelodge website and the Travelodges in Cornwall charge about £40-£60 a night in late May/early June (even if you book a Saver rate which is non-refundable), so I might plump for a youth hostel instead. A friend recommended one in St Ives which is very close to the station, so I might look there instead.
