Zone 6 Travelcard Validity between Slade Green / Barnehurst / Crayford
Dave91131
13 Jun 2018
Hi,
I've noticed during a couple of recent journeys in and around London that there seems to be contradictory map information regarding whether one can legitimately travel between any 2 of the above 3 stations using a Zone 6 Travelcard.
Maps on numerous station platforms show the above stations and lines linking them to be wholly within zone 6, however on-train maps (specifically on South-Eastern units if memory serves me) show all 3 stations to be in zone 6 but the lines linking them to be outside zone 6 - suggesting a journey from say Crayford to Slade Green with a zone 6 Travelcard would be illegal as the train exits and then re-enters zone 6 between the stations.
Has anyone else noticed this anomaly / error? And can anybody shed light on what the correct situation is?
Many thanks in advance for any info.
causton
4 Aug 2010
I would take the definitive version as TfL's version, which shows the lines as within the zones. I wonder if they have bothered to update the on-train maps to show Dartford as Zone 8?
BluePenguin
26 Sep 2016
Kent
It depends on where you get on and off rather than what zones the train travels through.
For example the Southern service that runs between London Bridge and London Victoria travels from Zone 1 to Zone 1 via lots of stations up to Zone 5. However if you joined at a station in Zone 2 and got off at one in Zone 3, it would not matter if you had travelled through Zone 4 along the way. It is the same principle here
Having seen the maps I would say that you can travel as you please legitimately
bb21
Emeritus Moderator
4 Feb 2010
It depends on the zones you travel through, regardless of the stations called at en route.
If you have a paper Zones 2-3 Travelcard (season), you will be liable for a Penalty Fare if checked in Zone 4.
If you have a Travelcard (season), you must touch in at the beginning of your journey and have sufficient PAYG balance to cover any excess fare into Zone 4, otherwise if checked in Zone 4 en route, you will also be liable for a Penalty Fare. (Whether the excess fare is deducted from the balance at the end of the journey is immaterial.)
If you travel on PAYG, you just need to ensure you touch in and out at the ends of the journey correctly, and have sufficient funds for your fare.
In this case, the direct routes between the stations do not leave Zone 6, so there is no difference, and the OP can legitimately travel between them with his ticket.
I went back through old maps in case the zone 6 boundary has changed, but even in May 2008 it was only the lines to Dartford that broke the zone 6 boundary as shown here:
http://www.projectmapping.co.uk/Reviews/Resources/Tube-DLR-Trams-Train-Map 30.pdf
It's highly likely that the on-train maps include errors especially when it comes to more recent updates, eg zone 8 etc, as no-one will have wanted to pay for any updates.
MikeWh
15 Jun 2010
Crayford
Crayford - Barnehurst - Slade Green is definitely valid on a travelcard ending at zone 6. If your travelcard is on Oyster then it is also valid to interchange at Dartford, providing you touched in at the start of your journey. If you choose to leave the station at Dartford then you'd be charged a zone 7-8 extension fare.
