Class 810 for East Midlands Railway Construction/Introduction Updates
800001
24 Oct 2015
Thanks , In general though is there a specific way you keep track or is it just a case of knowing where it is currently and checking if it's moving on a given day?
The only unit out on network is 810001.
All other units remain at factory under going static testing.
Regards 001, it can operate at any time on the Dalby Test, that won’t show up on any websites.
If you see Old Dalby to Peterborough, and then Peterborough to Newark 5Qxx paths on real time trains then, 99% it will be 810001.
Spire Sam
18 Feb 2024
Chesterfield
Ok thank you :)
Nicholas Lewis
9 Aug 2019
I remain unconvinced that having this looked at by a TSC would do anything either in this particular case or for any subsequent rolling stock orders.
Maybe but there is large amount of passenger benefit not being realised across multiple operators and this is costing someone serious money which can only drive up the cost of any future orders.
Aspen90
24 Oct 2021
Rugby
Drivers aren’t seeing them until end of Q1 2025 now, so another delay. I believe they should have been training with them in August.
43066
24 Nov 2019
Yep! Depot drivers first, then instructors then drivers. Then obviously TM’s and catering crew on top of that…
Quite likely TMs will be trained up on the stock during driver training runs, as happened with the 360s. Ultimate you need enough of all grades to be competent before the stock can enter service.
Might be tempted to put a quid on 2027 when you put it that way. But surely not…
I’m confident they’ll be in service by 2030! ;)
Nicholas Lewis
9 Aug 2019
EMR keep telling us they coming soon but clearly not. I know these aren't exactly a 80x but they aren't that much of departure from them so whats gone awry?
800001
24 Oct 2015
Don’t know why the delay, but it’s about 70% a different train from all previous models.
Nicholas Lewis
9 Aug 2019
Mechanically and electrically they are just iterations of previous build and they are well versed with the bodywork construction method. Also I wouldn't have thought Hitachi will be as daft as Bombardier to rehash the base software of the TMS like they did with 701s. Lets hope there is more transparency about what is going on as all this delay is costing money and hardly helps deal with the capacity issues MML has.
800001
24 Oct 2015
No they are not just iterations of previous builds.
Firstly this is the first body to be welded at Newton Aycliffe. And it is taking longer than expected per vehicle to complete.
Different length of vehicle means a whole redesign of everything mechanically and electrically.
New type of engine, and more engines per 5 car train than all other 8Xx models.
Due to different length of vehicles all testing of the complete train needs to be redone, as different length, different weight all changed how train performs.
Different length train means different pantograph testing.
The above are just a few of the things I can think of, but read any article about the train and it is basically a new train and can not be compared to any previous 8Xx classes.
Aspen90
24 Oct 2021
Rugby
On top of the issues that @800001 states, a number of sub contractors have gone out of business throughout production. None of which has helped and they’re a nightmare to paint and achieve a decent finish with, lots of rework apparently. I’m only assuming the colour is a difficult one to work with.
43096
23 Nov 2015
But all of that was known when they were ordered, so Hitachi should have had time for that work built in to the build schedule.
Nottingham59
10 Dec 2019
Think how much delay and cost EMR would have saved if they'd simply ordered 9-car 80x, with the standard 26m car body length.
Richard Scott
13 Dec 2018
What engines do they have? Apologies if a technical specification elsewhere in this thread but afraid don't want to trawl through whole thread to find it!
dosxuk
2 Jan 2011
The 810's are required to match the 222's performance on diesel to maintain the existing timetable. The standard 80x's can't do this - hence needing a re-design to add additional engines to the formation.
Maybe if Hitachi hadn't tried to be clever and had stuck to the standard 23m car length, they wouldn't have to embark on an expensive redesign to fit onto standard sized platforms.
It's also worth remembering that these trains were in the EMR franchise bid, so Hitachi must have done enough work to know it was feasible long before the franchise was even let.
800001
24 Oct 2015
It’s not about Hitachi being clever about vehicle length. 2 x 5 car at 26m length would not fit in St Pancras platforms, hence 23m (or 24 can’t remember) were specified by the TOC! This has been discussed loads on this forum.
Probably not so important now they are delayed, and wires will be to Wigston, and southern section wires upgraded to 125mph by time they enter service
With hindsight might have been quicker to add 20m to a few platforms so they could accommodate 260m trains
If you go back to the original order announcement, they are running about 3-4 years late. Even if you allow a year for covid related delays, it is difficult to understand why the two other extra years were not foreseen at order announcement time.
dosxuk
2 Jan 2011
The UK rail network had standardised on 12x20m and 10x23m formations for the purposes of platform design, with new builds (such as St Pancras) being done to those standards. It was Hitachi deciding to offer 9x26m for the IEP project rather than stick with the established standards that has caused these issues - which has come around to bite them.
Nottingham59
10 Dec 2019
It was the government Intercity Express Programme that specified a "standard" train length of 260m, which was compatible with all the mainline stations that can take an 11-car Pendolino (265m). St Pancras at 240m is the odd one out.
Martin222002
6 Nov 2011
Chesterfield, Derbyshire
It was actually the DfT that mandated the 26m vehicle lengthen as part of the IEP procurement, so not Hitachi changing the 'rule book' on it's own.
800001
24 Oct 2015
Do some research on the specifications of trains.
Dft specified 26m as part of the Intercity Express Prigramme Order.
A lot is Hitachi’s fault, but at least blame them for the correct problems.
