HS2 Progress near Kenilworth
Yindee8191
16 Mar 2019
The main HS2 thread has been closed and apparently we’re to post individual site updates now, so here’s a couple of drone flyovers from near Kenilworth uploaded today. Really shows that earthworks are coming along well. Also, one of the first proper looks at the ‘Green Tunnel’ portal design in real life that I’ve seen, from Burton Green.
Sonik
7 Jun 2022
WCML South
Nice footage, good to finally see a decent stretch where the outline of the route is actually visible beyond all the mess and temporary works.
bib
15 Nov 2021
East Midlands
Kenilworth to burton green flyover
Flyover of the route between Kenilworth and Coventry, 01:35 appears to be the start of a cutting to allow HS2 to go under the Leamington Spa and Coventry Line, if I have the location right.
Big block along the Kenilworth line in July where some progress should be made along there.
Meerkat
14 Jul 2018
In the video above are they building the abutments for the Kenilworth line in a cutting to the side, to be slid in?
bib
15 Nov 2021
East Midlands
Another video flyover of the same route as the first video in post#1. Interesting to compare them , quite a bit more earthworks started on gaps that were green fields in December, the abutment to the diveunder at 1:30 is coming along slowly.
Another flyover covering the same area as the second video in post#1.
9 day block of Leamington to Cov in a few weeks, so there should be some more progress during that.
Are the dates for this public knowledge?
29th July to 6th August. Why wouldnt they be public kmowledge? The trains are offered and in realtimetrains etc. Its the same time as the Oxford work so no XC between Didcot and Leamington with diversions via Solihull.
Jurg
10 Aug 2017
Cheers
hozza94
10 Jan 2012
That bridge in shot will be pushed during the blockade. The first few days will be excavating the existing line, then bridge gets pushed in and earthwork backfilled afterwards.
Same methodology was used on M42 Marston Box, and the A46 Kenilworth will be next to follow.
david1212
9 Apr 2020
Midlands
.... and the A46 Kenilworth will be next to follow.
Is it known if the A46 remain open, be closed overnights and/or weekend or be completely closed? If the latter how long, a few days say Christmas / New Year? While the A46 is three lane and one carriageway could be closed given the proximity of the excavation and insertion of the concrete sections would that be considered safe? If so just one lane each way would create very long queues at peak times.
For a total closure the official diversion route would have to be M40 - M42 - A45. For e.g. Oxford - Coventry the alternative is M40 Jn10 - A43 - M1 - A45.
Local and lighter traffic would try the back roads but they would become gridlock at peak times.
hozza94
10 Jan 2012
Nothing is confirmed yet. It will definitely be fully closed for a period as the new bridge is constructed as a box structure and be pushed the whole way, which shortens the closure lengths. There is an opportunity to keep some carriageways open during excavation but it's not confirmed.
Can almost guarantee A429 and B4115 would be nightmare during those times.
If its a slide like the M42 bridge, it will be a total closure.
adrock1976
10 Dec 2013
A quick question here - when the HS2 section of the works are complete at Kenilworth, is it intended to double track Milverton Jct - Kenilworth?
When Kenilworth station reopened, there was space left for another track and platform there.
Milverton Jn to Kenilworth is all south of the HS2 crossing. That redoubling, (if ever authorised), could be done anyway without any consideration of HS2 progress?
adrock1976
10 Dec 2013
The new bridge allows for double track, nothing else is being done.
TheDavibob
10 Oct 2016
The line is marked on OpenStreetMap, fairly clearly now:
snowball
4 Mar 2013
I'm very surprised that, as far as I'm aware, the Ordnance Survey does not yet show any of HS2 as under construction. (And I'm not sure what their symbol for railway under construction is.)
I see that OpenStreetMap, viewed at sufficient scale, in addition to showing certain areas as being occupied by HS2 works, shows a dotted line all the way from Euston to the Water Orton triangle, and then along the south side of the triangle and most of the way to Curzon Street - but not at present the other two sides of the WO triangle, or from there to Handsacre.
Bristol
I'm fairly sure it's been mapped off the plans that were part of the parliamentary authorisations.
It's very funny about zoom levels and layers. If you go on https://www.openrailwaymap.org/ and flick between the 'Max Speed' and 'Infrastructure' layers at different zoom levels you'll see the entirety of the original proposals including the Toton Parkway and Golborne Link sections.
Probably someone jumped in and edited it once the two year "pause" of Delta to Handsacre was announced.
Their map key for the 1:50000 series has a symbol, (which is a 50/50 dashed black line), but I can’t remember ever seeing a railway under construction marked on a published map, although to be fair I’ve never looked for one either.
