To be fair, slower trains don't need to be as "crash proof" as 125+ mph trains. Pacers can have massive windows, whilst modern fast trains have smaller ones.
Similarly, since everything has to fit into the same "envelope", a 125+mph train which tilts will need to be a bit narrower than a slow unit like a Pacer (with no tilting). Narrow sleek bodies designed to tilt means narrower seating and less space above the seats for luggage (one big problem with Voyagers, which lack suitable luggage space).
I'd therefore suggest there is a correlation between speed and internal atmosphere.
If the 1970s APT were built to modern safety standards, do you think it would have such big windows?
TBTC, as someone has already pointed out, your leaving yourself wide open here.
Mk3s are designed for 125mph, and are amongst the safest (if not the safest) in the country.
TGVs go a lot faster. They have bigger windows. The X2000 goes about 125, and has bigger windows.
Now for tilt. The Mk4s are designed for tilting operation. They have bigger windows, and are much more spacious inside. They are also much more pleasant overall. I believe the X2000 may even be tilt.
The Swiss tilting trains have larger windows. There is only one type of train ive come across that has windows like a pendo, and a dark dinghy interior like a pendo, and it probably comes as no surprise that its an Italian tilting train.
Now regarding loco hauled etc. I will admit i prefer loco hauleds on the West Coast, but the reason is not because im a backward looking enthusiast who only likes loco haulage. Its because the WCML is an intercity operation. Intercity standards to me mean unpowered coaches. Which invaribly means loco hauled. However I realise the 90s and 87s were too slow for a modern day WCML all the way to Glasgow (they could have managed on Birminghams though). My prefered option would have been an updated 91 and Mk4s with tilt enabled. To me it doesnt look like an Intercity train unless its loco hauled. But im not looking backwards. A 91 is just as fast as a pendo.
This is what i would have done if it were me, and id also have kept most of the Birminghams as they were. The time saved (if you discount the fact the loco hauleds had far too much slack time) has not really been worth the expense of all the extra trains.
Anyway, my main gripe, as it is with most people, is the fact that standard class on a pendo, is woeful. For me to step off a train without it even leaving is pretty bad. Ive only ever done this on a pendo.
Next year i intend to try them out, but in 1st class. I refuse to travel on them in standard. Even Voyagers are nicer, if the underfloor noise is taken out of the equation. Which i can put up with, because its not a major problem (although crosscountry is no longer an Intercity operation).
However, like em or loath em, there is no denying that the increased speeds on the WCML seem to be proving popular. Im still going via ECML to get to Glasgow though! Changing at Edinburgh if i need to.
Read my post and only then post a reply. :roll:
The less time you spend on a train, the less likely it is to lose travellers to other modes of transport. For many people that is an issue in itself and a good point going for the faster connections to the North like the HS2. The reduced time also in a sense reduces the need for the Pullman like conditions that seem to be called for...
Whos calling for Pullman conditions? Not needed. A mk1 slam door EMU will do me. Oh boy do i miss them!!
