158 on Huddersfield to Manchester Victoria stopper...
Discussion in 'Allocations, Diagrams & Timetables' started by 61653 HTAFC, 11 Aug 2015.
Thread Status:
  1. 61653 HTAFC
    61653 HTAFC Established Member
    10,906
    18 Dec 2012
    Another planet...
    Noticed something rather unusual this evening, which did at least take my mind off the debacle at the weak beer stadium tonight: a Northern 158 arrived at Huddersfield from the Leeds/Bradford direction, which I assumed was going to be my train home. Upon my arrival on P4 all doors were closed but active, and I noticed the unit was coupled to a 142. I was about to board when a Northern member of staff approached me and asked where I was headed. When I said Batley, he told me this was the Manchester Victoria service and that the Leeds stopper would be arriving shortly. AIUI 158s don't normally work West of Huddersfield, so I'm now wondering why this one was being sent West. Is there any maintenance work that can be carried out at Newton Heath (or Allerton) that can't be done at Neville Hill, or is this in fact a regular positioning move for tomorrow's early Calder Valley services that I was somehow unaware of?
    Rail Forums
  3. WCMLaddict
    WCMLaddict Member
    416
    20 Mar 2012
    142+158 on one of last Huddersfield-Vic services is a normal booked job.
  4. 61653 HTAFC
    10,906
    18 Dec 2012
    Another planet...
    Oh ok, guess this is a relatively recent thing (since the May timetable change) then, as I've not been at HUD on a late night until the football season started.
  5. wellhouse
    wellhouse Member
    330
    4 Oct 2009
    West Yorkshire
    Although unusual for working through from Huddersfield to Manchester, a 158 often works the early morning Marsden-Leeds stopper, having arrived .ECS at Marsden from Huddersfield.
  6. aformeruser
    aformeruser Veteran Member
    30,637
    23 Jan 2009
    Do they have to lock one unit out of use due to platform lengths?
    I can see there being a lot of annoyed passengers if they have to travel on the Pacer when a 158 is on the back locked out-of-use.
  7. Geeves
    Geeves Member
    1,021
    6 Jan 2009
    Rochdale
    It was a four car 158 the other week, Absolute luxury. Not many passengers on at that time to really get annoyed! Its been happening on the very last Huddersfield since before May, probably about two years on and off.
  8. 61653 HTAFC
    10,906
    18 Dec 2012
    Another planet...
    This happens with all 4-car formations except 2x142 due to short platforms at Slawit and Marsden, with the rear unit being unlocked (if needed) at Greenfield. It is annoying if there's a 156 or better at the Huddersfield end, though the opposite applies in the other direction of course.
  9. darloscott
    darloscott Member
    540
    12 Dec 2013
    Stockton
    Assuming this is 2M91 2215 Hudds-Victoria we're talking about?
    The 158 appears to come off Leeds-Sheffield/Nottingham expresses, though the 142 I'm not sure on (appears to be off Leeds-Vic services)
  10. 61653 HTAFC
    10,906
    18 Dec 2012
    Another planet...
    That's the one. I was in the King's Head drowning my sorrows when it arrived, so I wasn't 100% sure if it arrived on an incoming service or as ECS. Presumably the 158 comes back East via Rochdale the following morning?
  11. alexl92
    alexl92 Established Member
    1,710
    12 Oct 2014
    I presume you meant services on the Huddersfield line when you said this, but if not, they do work Blackpool - York services and also Man Vicc - Leeds via Bradford and Halifax, amongst others!
  12. Welshman
    Welshman Established Member
    2,773
    11 Mar 2010
    How times change!
    Only 9 years ago and it was only 158s which worked the fast services west of Huddersfield. :)
  13. 61653 HTAFC
    10,906
    18 Dec 2012
    Another planet...
    Indeed I did. Of course they work many places West of Huddersfield (Blackpool, Aberystwyth, Bristol!), just not from Huddersfield!
    And only a few years before that there were occasionally 142s standing in! <D
  14. gimmea50anyday
    gimmea50anyday Established Member
    2,699
    8 Jan 2013
    Back Cab
    And only a few years before that we had deltics standing in for peaks and duffs! :lol: :p :D
  15. aformeruser
    30,637
    23 Jan 2009
    142s were very rare, even rarer than 144s. 156s were more commonly seen.
  16. 175001
    175001 Member
    913
    3 Feb 2007
    Between Heaven and Hell
    Its been a booked move for about 4 years to bring a 158 back to Victoria from Huddersfield late at night. It used to be on the 2234 HUD-MCV before the timetable change, now on the 2215
    Its a local instruction for Slaithwaite and Marsed JCollins, which takes precedent over any annoyed passenger.
  17. aformeruser
    30,637
    23 Jan 2009
    Does a local instruction dictate it has to the front or rear unit that is locked out of use or could the crew use common sense and open the larger unit if it's a busy service?
  18. WCMLaddict
    WCMLaddict Member
    416
    20 Mar 2012
    Try to put yourself in the staff position.
    You have two units coupled together, no selective doors gimmick and all. Approaching Slaithwaite, on the up the platform is on slight right curvature. There are no stop boards, you can't see the back of your train, it might be any combination of units etc.
    You do know that only 2 car set fits on the platform. Would you really want to risk stopping within platform with only back set? It is much safer and easier to just go to the end of platform with the front set. You will always be in.
    Hence you always have the back set locked out.
  19. 175001
    175001 Member
    913
    3 Feb 2007
    Here is the local instruction from the Sectional Appendix
    So Greenfield is where any additional sets must be opened/locked on the route.
    Common sense isn't allowed over a rule in the Sectional Appendix i'm afraid.
  20. 61653 HTAFC
    10,906
    18 Dec 2012
    Another planet...
    I have seen the the rear of two 150s in use at Slawit heading Eastbound. The guard came out of the rear cab and instructed any pax for Slawit to move to the next (3 of 4) carriage. He then released doors from behind the front cab of the rear unit, I was in the rear car and the buttons for the doors lit up but were not in the platform. This might not have been strictly within the rules but to me it seemed a better option than cramming everyone (it was an evening peak service) into the front unit.
    By the way, thanks to the moderator who moved the thread, wasn't sure whether this section or Rolling Stock was the right one, so went by the rule of coin-toss!
  21. wellhouse
    wellhouse Member
    330
    4 Oct 2009
    West Yorkshire
    I have often joined 4-car services at Slaithwaite when the rear 2 have been out of use until Greenfield. This week, however, joining a 2x142 service at Huddersfield, I was asked my destination by the guard and directed to the front set. Other passengers (presumably for stops west of Marsden) were allowed in the rear set, and when I left the train at Slaithwaite, the guard dispatched from the front of the rear unit.
    Has there been a relaxation of the rules? (Not identifying the exact service to protect the possibly guilty!)
  22. Rich McLean
    Rich McLean Established Member
    1,567
    6 Feb 2012
    If the rear unit can be de-selected on corridor stock, then I can't see there being a problem.
    Having seen the local intstruction, things may have changed or a case of certain Guards being "naughty"
  23. bramling
    bramling Established Member
    7,298
    Could the guard have utilised just the local door? Presumably this would be permissible?
Thread Status:
Share This Page
