Is there? Is it not cleaner for passengers to only need 1 route?
Ah, but there are many different definitions of 'good'. The key question is:- where do the good folk of Warrington *actually* want to go, not where do these forums think they should want to go. But you'd need LENNON or MOIRA data to know that.
Bear in mind that Warrington BQ offers (or has offered in the past) services to/from both Manchester and Liverpool via Chat Moss as well as the CLC route, and that allows connections in and out of the WCML - quite valuable for traffic from, say, Runcorn or Chester.
Indeed. Having everything running the same stopping pattern would be one way. 'Ormskirking' it would be another. both would require fairly minimal intervention now that Merseyrail have 777s.
Now you're taking a problem with an imperfect interregional line (lets face it, most of the problems are rolling stock problems, staffing problems, rarely infrastructure constraints).
And your solution is to stop all longer distance trains and shove a set of buffers in the middle of Warrington.
Incredibly disruptive solutions for minor problems.
