hooverboy
- Joined
- 12 Oct 2017
- Messages
- 1,372
DB Bahncards are not "off peak only" - they do not have such a concept at all. All walk-up fares are "Anytime" - "Flexpreis" (though the price can vary by day of the week I believe, and commensurate with that it's singles only, no returns), smoothing of this is done by "Sparpreis" tickets which are the same as Advances.
not quite.
when you buy the tickets from the vending machine you will be given a selection of trains times with variable fares, and its nearly always the case that the peak time fares are much higher.
It does seem to vary a lot in which mode of transport you use. Ie an ICE train fare is double or more the price of RE train for the same route, but the RE train does more stops and takes longer.
You're right about the single-only tickets though, Return tickets in germany are not common,apart from some local transport networks.
you can get other rail rover type cards that don't carry a restriction(apart from not valid ICE tains).
most local travelcards are anytime travel ie munich Isarcard.
