Alliance Blackpool service to be run by Grand Central and start in 2021
6 May 2017
Near a bunch of sheds that aren't 66s.
A short-term lease of ex-GWR HSTs would seem the obvious way to go, as long as PRM issues can somehow be sidestepped. Although there are the DRS Mk2 sets just released from the Cumbrian Coast :p.
Or LNER hire those HSTs and allow them to release the necessary amount of 91s to GNWR? GNWR or Hitachi covering the costs of hiring those extra HSTs?
ChiefPlanner
6 Sep 2011
Herts
Apart form the minor issue that these cascaded 125 sets would need to be maintained and serviced somewhere ....Plymouth perhaps ? (no facilties at Old Oak Common anymore , or even at an extreme push Landore ?) .....
unlevel42
5 May 2011
Could the HSTs be serviced at Leeds?
Are routes via Manchester and Sheffield still allowed?
Any other permitted Preston direct to Leeds routes for HSTs?
To/from Leeds there are already some ridiculous early/late revenue services for MML and LNER.
Any potential for overnight routes via Manchester airport
Modron
5 Feb 2019
The problem is that there are only so many trains you can fit between Preston and Blackpool North at any one time - the route is double track, and with the through York-Blackpool North trains coming back the line will only be more busy.
There have been proposals for the Blackpool South line to be converted, at least partially, into a Tramline that would then join up with the existing Tram Network (possibly at Talbot Road), so this might have some bearing on the services in the future.
Modron
5 Feb 2019
I believe that Landore is going soon, if not already being closed down. Maliphant Sidings is now the main facility in Swansea.
takno
I would have thought you could get 10-15 trains an hour each way without too much trouble now it's been resignalled. Why would you want more than that?
43096
23 Nov 2015
Arriva Traincare at Crewe. There have been HST power cars there before and they see Mark 3s daily.
What we don’t know is if GNWR have a signed lease and start date for the Mark 4s. If they do, then they could enforce the start date and it would be LNER’s (and Hitachi’s) problem to cover the shortfall.
AMD
6 Dec 2017
Route capacity is considerably higher than what is currently being run; at present up to 6 trains per hour come out of Preston normally, but with four aspect signalling and current spacing capacity is around 10 to 12 trains per hour.
The York slot will take over the service that is just run as BPN to PRE which only stops at PFY - this was a 'temporary' fix to the timetable to reduce the number of diesel units required to run the BPN/PRE to LDS/YRK corridor.
driver_m
8 Nov 2011
Not much room on LNWR though, (unless they're kicking someone out) If no one leaves, there's very little wiggle room on there.
43096
23 Nov 2015
Isn’t Crewe the proposed base for the GNWR Mark 4 sets, so presumably there is capacity.
driver_m
8 Nov 2011
There's room outside if they do some reconfiguring of the Sidings, but I'd imagine it will be expensive.
The shed nearest the mainline is full of 350s as it is the only wired shed, the 4 roads behind usually have our 221s on and the TFW 67s and mk3s. The EMT stuff usually sits out at the back somewhere, and the TPE stuff goes anywhere. There's currently LNR 319s split up there and plenty of other stuff out of sight being altered. Someone must be leaving?
43096
23 Nov 2015
TPE Mark 3s will go this year for a start.
There might be capacity between Blackpool and Preston for 10-12 trains per hour, but is there capacity for them at Preston?
driver_m
8 Nov 2011
They're usually dumped in one of the shunts with various wagons. There's plenty of land though, it's just that some cash needs spending in the place .
158820
1 Nov 2017
Tfw loco hauled will be finishing also when the mark4 arrive they will all be dealt with at Canton
paddyb6
21 May 2018
Just to Clarify - I've got a few questions regarding GNWR services?
1. Are we still expecting September or even December this year for a start date?
2. Will it be 91s + Mk4s?
3. Is it still actually going to be happening? (XD)
Thanks for any info
BantamMenace
2 Dec 2013
Do we know their paths as well? I’m particularly interested in the morning London bound departures from Nuneaton.
pt_mad
26 Sep 2011
Out of interest how do class 90s compare at pulling coaches Vs 91s? Is there any possibility whatsoever they could have looked to hire in 4 90s and a rake of coaches so they can start their operation? Or would that need a whole new application to the ORR?
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Well they were built for WCML - so at least they are cleared Euston - Fylde Jct. Class 91s will need clearance testing or other for the entire route I assume.
Plenty of 90s available, and they are probably better suited for 110mph working than the 91s.
They regularly substitute for 91s on King's Cross-Leeds services if they are short of 91s.
The bigger problem is finding PRM-compliant rolling stock.
I imagine they could get the TPE ex-Pretendolino sets, or some other retired Mk3s, but it wouldn't solve the PRM problem.
pt_mad
26 Sep 2011
Hadn't thought of the PRM requirements.
I'm guessing the ex GWR coaches fail that then? When do the regs change, next year or this year?
