Amsterdam Eurostar
Mutant Lemming
8 Aug 2011
You still have the hassle with check-in and baggage reclaim though.
You have to check in for Eurostar too with some quite lengthy queues right round to the South Eastern side of the station at busy times - and most people only have "cabin baggage" these days only those on longer trips check bags in.
DavidGrain
29 Dec 2017
Is checking in baggage in on Eurostar something new with the new trains. I have not travelled Eurostar for a number of years. Surely this is a retrograde step
Mag_seven
1 Sep 2014
here to eternity
It isn't checking in baggage as such as per an airline. Its arriving early so you can be security screened etc and have your bags x-rayed.
Goldfish62
14 Feb 2010
Yes, purely logistical. If everyone arrived 5-10 min before the train was due to depart the system wouldn't be able to cope. However, unlike the airlines there's considerable flexibility for late comers. In my experience, "check in closed" doesn't having the same meaning as at an airport. I've arrived 10 min before departure and have still caught the train.
Comparing the time spent at stations when travelling Eurostar with that at airports when taking a flight of similar length:
  • No need to queue to drop bags on Eurostar as you take them on board regardless of size.
  • The delays through security are no worse than can be found at airports, and if you arrive within the minimum time but still miss your train I believe they will put you on a later one without extra cost.
  • Automated check-in and two passport checks before boarding replace the showing of boarding passes before security, of boarding passes and passports at the gate, and of passports on arrival.
  • No need to wait at the destination airport to collect checked baggage.
So as we're discussing end to end time here, most people will have less "dead time" when passing through Eurostar stations than they would if they'd flown instead.
DavidGrain
29 Dec 2017
Thanks for the clarification. My case used to be x-rayed at Waterloo back in 1998 when I first travelled on Eurostar so I could not understand the references above to checking in and baggage reclaim on Eurostar. Yes I know there used to be two way traffic at the luggage racks on arrival so you often had to queue to get to your cases.
telstarbox
23 Jul 2010
Wennington Crossovers
Goldfish62
14 Feb 2010
Don't forget liquids. No restrictions on liquids on Eurostar.
tasky
30 Oct 2018
It really is amazing what you can take through security on the Eurostar - my girlfriend happily brought a compressed air cylinder for a soda-stream through. She had checked in advance and they had told her it was fine. Meanwhile I had my deodorant confiscated at an airport last week.
Chester1
25 Aug 2014
That will be very useful to me; I'm planning another trip to Berlin via Rotterdam this year.
What is the journey like? I have considered London-Amsterdam and Amsterdam-Berlin but the latter journey is 7 hours and I have gone via Cologne before and it probably splits the journey better.
Goldfish62
14 Feb 2010
Yes. A very small amount of explosive can bring a plane down. There's not the same issue with a train.
MarcVD
23 Aug 2016
And it is also quite difficult to hijack an Eurostar train and crash it into some large building.
TheSeeker
15 Feb 2016
Braine-l'Alleud
I moved to Belgium by Eurostar. Each trip I had two large suitcases filled with bicycle parts, books, VHS cassettes, reading lamp etc. Once even my desktop PC although I had to take the CRT monitor by car. My sister is an expert at visiting us, buying something enormous in a flea market and then getting it back through Eurostar to Wales. Last time it was a chest of drawers.
cle
17 Nov 2010
Eurostar are re-timing the morning train and adding a new third daily train:
https://www.theguardian.com/busines...ondon-amsterdam-service-to-three-trains-a-day
It's great news. It think once the 'airside' operations opens at the two Dutch stations, it will really pick up - and I'm sure frequencies will increase.
Who knows what will happen with Brexit, either way - but if traffic to Brussels goes down, Eurostar as a business are going to need AMS even more.
30907
Amsterdam-Berlin is a standard DB Intercity set, with a loco change at Bad Bentheim (which makes it a rarity). It follows the same route as the Cologne train from Minden eastwards. The change at Amersfoort from Rotterdam is (was) cross platform. 2 hours longer but potentially a fair bit cheaper.
Matt_pool
9 Nov 2016
I've done Berlin to Amsterdam twice and Amsterdam to Hamburg once and it's not that bad. I take a few beers, some food and a book and the time actually passes by quite quickly. You can actually have a proper kip too without doing your neck or back any damage because the seats in standard class are very comfortable and you get a lot more leg room than on trains in the UK.
And the stop at Bad Bentheim is for 15 minutes and breaks up the journey a bit. I got off to stretch my legs and watch them change locos. And you can walk up to the buffet car and sit there for a bit. They make freshly prepared salads and I once saw them cooking sausages for someone. None of the microwaved rubbish we get on trains in the UK.
Mutant Lemming
8 Aug 2011
I do like using Eurostar, loved the trip to Amsterdam but even with discounted fares the next trip to Paris will be by plane at less than half the fare quoted by Eurostar for similar times on the same days. I just don't get how the air fares can be so cheap - someone, somewhere, somehow must be subsidising/paying for it in some shape form or another.
Groningen
14 Jan 2015
In Loehne (Westfalen) the lines from the Ruhrarea (Koeln to Dortmund via Duisburg or Wuppertal) come together with the line from Amsterdam to Hannover and Berlin.
tasky
30 Oct 2018
Have you factored in the costs of getting to and from the airport? I don't know where you live but you're probably looking at least £50-60 if you factor that in, given open returns from Zone 2 to Luton, Stansted, Southend, Gatwick (where the cheap flights go from) are £30 or so, and Paris CDG is no better. It's just as bad if you get cabs or end up parking your car.
If St Pancras and Gare du Nord being on the Tube and Metro make accessing them cheaper the total cost may be a lot less, given it is sometimes possible to buy a return eurostar journey for £60.
Goldfish62
14 Feb 2010
Airlines make a huge loss from passengers who buy the cheapest fare and not any of the extras such as reserved seat, priority boarding and grub. They also need to make the planes as full possible in order to make money on a flight. It's all knife edge stuff
radamfi
29 Oct 2009
On the other hand, there are so many airports in the London area, chances are there might be one nearer your home than St Pancras.
Because:
a) the airlines don’t pay for the operation, maintenance, and amortised cost of construction and renewal of 450km of £20bn worth of fixed infrastructure. They pay only for use of the terminals at each end.
b) Eurostar is perceived as a premium service (easier travelling experience, ability to work en route, city centre to city centre journey, etc.) compared to the airlines by ‘the market’ and can therefore charge a higher price.
c) the airlines are very good at defraying costs (extra charges for bags, picking a seat, etc) which Eurostar don’t (or can’t) do. I’m flying to Europe with Easyjet soon; the return fare is about £70, but it’s costing another £85 to choose seats that I can sit in (long legs) and take a hold bag.
fowler9
29 Oct 2013
I live in Liverpool. No way I am getting Eurostar to anywhere in Europe unless I just fancy the experience and have the time. Same for huge swathes of the UK. I used Eurostar once purely so I got to use it. There are millions of people who will never use Eurostar because it makes no sense and they aren't interested in trains.
Goldfish62
14 Feb 2010
Yes, if you're that far from London and have a significant international airport on your doorstep then you're right.
2392
7 Apr 2015
Felling on Tyne
Indeed yes. It would be more convenient for me to fly to Amsterdam. As Newcastle International Airport has direct flights to Amsterdam Schipol. I can get a T&W Metro direct to Newcastle Airport and at the other end a train from Schipol direct into Amsterdam City Centre [Amsterdam Centraal]. Mind you having used the Shuttle through the Chunnel, I would like to take a Euro Star just to say I've used it. Having sailed from Hull as well as flown, yes I know DFDS sail from the Tyne, but they are most reluctant to have single occupancy of their cabins. From my point of view they'd rather sail with an empty cabin instead........
Of course. Interestingly, just about half of the nearly 6m UK - Paris / Brussels air passengers* travel to/from Heathrow, Gatwick and Luton. (The numbers from City and Stansted are negligible). In addition there’s about 9 million on Eurostar. Taken together, that means that only 20% of all the UK - Paris / Brussels air/rail market does not use London. So whilst there are large areas of the country where it doesn’t make sense to use Eurostar, in terms of numbers of people in the market it is a relatively small proportion.
Back on the subject of Amsterdam, it is a similar picture. 46% of UK - Amsterdam air passengers travel via a London airport.
* some of this will be interlining at Heathrow or CDG and therefore not a true alternative to Eurostar.
Source: CAA route analysis 2017
