as I have been told you are assessed from the moment you enter that room, it's not all about the written tests. Finally wear a suit and tie and make sure your shoes are spotless.
Another thing you can do that could instantly make the difference between pass or fail. Make sure you answer all 36 questions on the mech test. If you run out of time, make a guess on everything you didn't answer. If you guess 10 answers you're likely to pick up 3 or 4 points which could make the difference between pass and fail. If you left 10 blank then you're not going to pick up anything extra.
Finally make sure you bring in a watch so you know exactly how much time you have left. It can be horrible to be taking a test and have no idea how long you've got left, and the sudden "pencils down" can come like a big shock if you've still left questions unanswered in the mech test.
You dont get marked down for wrong questions on the mech test, its all about number of correct answers, I 100% confirmed this with the assessor before the test began.I disagree Mick, I didnt complete the mech tests (but still passed) and you will be marked down more for all the wrong answers and obvious rushing than you will for not completing.
12 years ago I failed on the Mech test. I GUESSED AT THE FINAL FEW ANSWERS because time was running out and I was ONE mark off a pass!!! I was told at this point that there had been no need to answer all the questions. I had passed everything else with flying colours up to that point.
Got a high pass on everything but reactions (borderline with Northern). I actually found the test relatively easy. The assessor told me the reason why I didn't score a high pass was because I paused for too long after missing one. Unfortunately I read somewhere that you should pause for a few seconds if you make a mistake, and thought this was the best thing to do. I probably paused for a about 4 or 5 seconds to compose and only made one error in both tests. I am understandably gutted, knowing that I didn't need the pause (believing it would actually help me) makes it even worse, I believe I could've just carried on. A bit silly of me to think that remaining calm and composing would be better than continuing immediately. At the end of the day the pass marks are high and ill be the first to admit I didn't make the cut on this test. Oh well, onwards and upwards. Apoligies for grammar etc but not in the mood to correct haha
