Are Top Speeds Really Just the Recommended Speed?
TRAX
2 Dec 2015
France
Here's a hypothetical question for you. I understand the 350 Desiros had substantial modifications to allow them to run at 110 on the WCML. Could another 10mph feasibly be wrung out of them or are they screaming on the limit at 110? Just asking out of vague interest before anyone bites my head off.
it think the issue would lie more on crash worthiness than technical capabilities at this point.
DJ_K666
5 May 2009
Way too far north of 75A
Possibly. That said I wouldn't want to be on a train that crashed at either speed.
To be honest, I wouldn't want to be in a 10 mph crash either.
Or a 1.2mph one, although that would involve a lot of swearing rather than death. And paperwork. Oh gods the paperwork. Begone foul beast.
Brissle Girl
17 Jul 2018
I believe the non-passenger sections at either end would need to be a little larger above 110 than purely a cab’s depth, so would make them unviable given the lost space, particularly as units are often coupled together.
hexagon789
2 Sep 2016
They have to be tested to a 10% overspeed, so should have been up to at least 121mph. As others say though - they won't be doing that in service of course ;)
Jamesrob637
12 Aug 2016
Slab-ended trains have done more than that in passenger traffic - Stateside!
Railperf
30 Oct 2017
The original HST overspeed worked off wheel diameter, so on new tires it would cut power at 132mph, on fully worn at 128mph. I believe most (all?) power cars are now 132mph cut-out regardless, certainly those with Knorre Bremse WSP are. Presumably the way speed is measured is no longer fully dependant on measuring the rotation of the wheels?
I had an LNER HST accelerating down Stoke Bank cut out at 129mph!! :D.
But post ATP GWR ones would rarely be driven at more than 122 to 123mph ..as i understand the ATP could start warbling at those speeds when tyres were worn.
JN114
28 Jun 2005
I hear this bandied around a lot, but little evidence ever that it has been done nor references that outline such a requirement.
We’ve certainly never run our 387s at 121mph...
Boodiggy
8 Nov 2012
MK
i may be wrong (usually am) but I believe it is tested at the 10% following any line speed increases. The cl.390 were definately tested at 10% above (138mph) following the increase to EPS Speeds on WCML. Not sure if there is a requirement for all traction to be tested. I will see if I can dig anything out in the standards when in the office.
hexagon789
2 Sep 2016
Afai knew it was standard practice including for any stock which subsequently has its maximum speed raised.
hexagon789
2 Sep 2016
Should be 132mph cutout with the modern Knorr Bremse WSP for all wheel diameters and max 132 reducing to 123 on minimum tyres for those with the original BR WSP such as GWR's.
delticdave
14 Apr 2017
ISTR that 3x4 car 357's were tested to 110 mph on the East Coast Mainline at night, 'cos the LTS has an overall limit of 70 / 75 mph.
Railperf
30 Oct 2017
I didn't know that. I can imagine them being more than a little uncomfortable at that speed.
Depends how flat the track is. My understandibg is that the basic Desiro design is good for 200km/h (124mph) . In my experience they run smoothly at 100mph on good track. Some of the GE 360s seem to be riding roughly now..i hear it is due to dampers needing replacement which is unlikely to be done as they go off lease imminently.
Railperf
30 Oct 2017
Didn't ATP cut-in well before 132mph - nearer 128mph on fresh wheelsets?
Railperf
30 Oct 2017
350's at 100-110 feel smooth enough to me. Certainly not as smooth as a 390 or HST but not bad
Was on a 390 a few days ago. I had forgotten how well they ride. And they offer good sound insulation too. You barely hear any track noise, the traction motors are quite quiet too. Still feel slightly nauseous when on full tilt if i am not looking out the window.
43096
23 Nov 2015
They can't decide to just not do maintenance - if the dampers need changing (or bogie overhauls need doing) then they will have to be done by GA.
hst43102
28 May 2019
Tyneside
390s are built to ride and feel like an airliner.
SteveyBee131
28 Oct 2017
Grimsby Town
I wasn't meaning the 87mph value specifically, the class 90 and 87 had higher 110mph speeds and the 92 seems quite low in comparison given it's a powerful engine. I assume the trade off is it's much better for freight although I always think of 92's in passenger service as my only experience with them is on the sleeper.
On the subject of top speeds did the 67's ever run at 125mph? Assuming that figure on wikipedia is correct as it seems high when the 68 has a maximum speed of just 100mph.
They're certainly authorised to. I read somewhere fairly recently (apologies I can't recall where!) that they might take forever to get up to 125 with a load though!
hst43102
28 May 2019
Tyneside
During testing (without a load) one of the 67's reached 143 mph. Very close to HST max speed!
hexagon789
2 Sep 2016
Sorry I was taking about the overspeed limiter fitted not long after introduction to service.
ATP is supposed to be:
3mph over - warning
6mph over - intervention
I believe it does vary a bit for the same reason as the limiter can
Jamesrob637
12 Aug 2016
I always find Siemens stuff rides quite hard, the suspension isn't very good at absorbing track irregularities
It's used to the smoother and more "regular" German rails I think. 185s at full chat are the same.
hexagon789
2 Sep 2016
Quite possibly but I've even found the supposedly excellent SIG type bogies ride roughly on well maintained Swiss track, so I'm not sure it's 100% down to the track quality
