you will be going to the OPC office in Watford , there Will be fewer people at this one ( I had 6 on my day 2).
You will do a mixture of tests ( sorry don’t know the names for the tests ) some paper based and some on a computer, as put above , you will do the old stare at the blinking grey square test , you have to push a button as quickly as you can when it changes colour.
You will also do a search exercise where you have a photo pop up on the screen for a few seconds , you will then have 5-6 options to chose how many items you saw i.e;
Car
Motorbike
Traffic lights
Pedestrian
Shop front etc
I think you get 5 separate photos.
Another test is the hand ( using both hands ) , eye co ordination test where you will have to draw a line around a set pattern trying to keep your line with in the set pattern , for this you will have two joy sticks , one will just control up and down movement, the other left to right movement. If you draw outside the pattern you get a warning noise , you need to move it back in as quick as possible.
Another test is the VSE , I personally found this the hardest , it’s broke down into 3 sections ;
First part you watch a dot( simulating a train) making it way round a track, as soon as it skips a part , or maybe two dots appear you push a button.
Second part, you will have a series of shapes , if these shapes match you pick( note they don’t have to be next to each other) , No fault button , if they don’t match pick , fault.
For example
See the 3 shapes match , so this is a no fault
Then you have to do both together, the train going around the track is your primary task.
Unlike day 1 you will get told your results as you go along , if you don’t pass a test you go home.
Survive all the tests , it’s then time for your MMI.
Apart from that it’s not to bad lol
