If you have a look on the OPC website there are example tests. But normally they send you through some examples too before you do
Where did you practise the 2 handed co ordination test about mate?I've got my stage 2 assessments coming up soon, and I've been practicing the dual hand coordination test, on some of the practice stuff the track disappears does this happen on the real thing too?
Alright mate! Jesus!Even if you knew the pass mark, you won’t find that info out, do you know how many mistakes you made. Just follow the instructions and do you best. You either pass or fail, I see no point asking about the pass mark, that’s not going to help.
Sorry. Not having a dig. Trying to point out that even if you knew the pass mark, that’s not going to help. Do your best, no-one is going to make mistakes deliberately, you may not know you’ve made a mistake or may think you’ve made a mistake when you didn’t, knowing these marks is not going to make any difference, you can only do your best, and that’s all you can do.Alright mate! Jesus!
I failed on this early this year, however I’m soon to do my retry.
Initially I had not been aware that time was a factor on this test, and between each test (10 total)? I sat, I had a breather, reset myself and took a good minute before doing the next..When I had finished I was way behind everyone else, maybe a good 5 minutes and I was called aside and told I had failed, I was then told after that maybe if I was quicker I would of been ok, my experience however was awful. I called the assessor twice in the exam and complained about my controls not moving even with significant effort, then all of a sudden the dot would jump and be way out of the shape, it would go from super sensitive to, nothing, like it was glitching. All I was told was they cannot do anything about it and to carry on, I spoke to two others that day one who had the same experience and someone else said there’s was fine, so I’m going into this again a little unsure on what to expect with the sensitive, and I never did find out if mine was faulty or normal. All I do know is to be quicker and not to worry to much if the dot strays outside the shapes, but to re yourself quickly.
can anyone give me some advices or words from there experiences with this test?
cheers
They’ll do a urine “dip test” which I believe is for diabetes. It’s neither here nor there for you really though, as you’ll presumably just be declaring it to them?Hi all,
I hope everyone is keeping safe and well.
I am a new member and do apologise in advance if this question has been answered before.
I have a medical coming up to start as a trainee train driver with LNER.
Has anyone recently had a medical with them?
I have read that they test for diabetes. I was diagnosed with type 2 however have been under control with normal blood sugar levels. Is this likely to affect the medical outcome?
Also is controlled colitis an issue?
Many thanks in advance
G
cheers
Hi Stigy,They’ll do a urine “dip test” which I believe is for diabetes. It’s neither here nor there for you really though, as you’ll presumably just be declaring it to them?
If you’re not insulin dependent, then I think you’ll be okay. Obviously every case is dealt with on its individual merits though. Good luck!
It's set up with a deadspot and after the deadspot it's REALLY sensitive, it's testing your accuracy and reactions, which is probably the best way to test those skills which can be hard if you're not expecting a deadspot and oversensitivity.Exactly this!! Failed mine too with exactly the same thoughts, I know OPC are a professional outfit but the equipment is so old it must be possible that this happens?
Though I don't doubt that at all, the glitch type movement is what bothered me because when I asked some others if there experience was the same and some didn't have this, hence why I asked the assessor if it was faulty, the response didn't feel me with much confidence, but.. "you'll just have to get on with it"The controls are calibrated to make it difficult for you, stay calm, get it back on track. Speed AND accuracy.
Glitchy type movement can be interpreted differently.Though I don't doubt that at all, the glitch type movement is what bothered me because when I asked some others if there experience was the same and some didn't have this, hence why I asked the assessor if it was faulty, the response didn't feel me with much confidence, but.. "you'll just have to get on with it"
Aye your right, I would agree with that,Glitchy type movement can be interpreted differently.
Would I call it glitchy, not really I'd of said it mimicks more like lag in a computer game, you input get nothing then suddenly get it all.
You know what's coming, take your time and do it however you feel comfortable doing it, the pattern repeats so once you've done it the first couple of times it's easier to get into a rhythm until the end.
How many lines should I be able o complete for the bourdon test? Also does anybody have any practice materials that work on MacBooks ?
I don't believe soIs there any (ideally free) online simulator available to replicate this test?
