td97
- Joined
- 26 Jul 2017
- Messages
- 1,304
Good to see Bolton can take an 11 car 390, even if no future service is currently plannedP3 - Up 305
P5 - 279m
P5 - 279m
But you never knowGood to see Bolton can take an 11 car 390, even if no future service is currently planned
During the 2014 Chorley Tunnel blockade six car (3x150) services frequently stopped at Blackrod. These units didn’t have SDO and there was no overhang issues.
Actually there were. The Down platforms at both Blackrod and Adlington (used in both directions due to Single Line Working) were at that time just too short to fully accommodate 3x150. However with the 1/3 2/3 door positions on 150s the simple solution was to provide all such trains with a second guard who was tasked with preventing passengers from attempting to use the non-platformed rearmost set of doors. The first guard used a door control position further forward in the train with doors being released in the normal way. During the 6 weeks of the blockade I happened to find myself working a number of such services: they made for an interesting variation in rostered work.
That's what I also thought.
Should be noted however that no Preston trains stop at Clifton, Farnsworth, Kearsley or Moses Gate (& haven't for as long as I can remember), only Wigan & Clitheroe trains stop at these.Clifton, Farnworth, Kearsley and Moses Gate are probably the shortest at 4 cars each. Not sure what the actual lengths are. Blackrod just about held a 180 when Northern had them.
The TfN Rail North Committee paper, https://transportforthenorth.com/wp-content/uploads/Item-5-Train-Service-Planning.pdf, states, in para. 3.6, that TPE's May 2019 timetable bid includes several amendments to the Train Service Requirement as contracted [and originally bid for May 2018 before the overrun]. One of these amendments is "continuation of existing Manchester to Scotland services".Before the overrun, and May TT farce there was a perfectly valid timetable for TPE via Bolton, and all the other Northern changes.
One would assume once Bolton is wired, and once the May & December 2018 TT changes are introduced in May 2019, that everything will be as it should’ve been in May 2018.
Incidentally various stations on Clitheroe line have very short platforms - 4-car 156s can only open doors on 3 of the carriages at Clitheroe & Whalley.
Moses Gate is the shortest at 79m. It's the one that has thrown a few of the newer guards when a pair of 156s turn up instead of the booked 156+142 on the Wigan/Stalybridge/Alderley Edge circuit!What is the shortest length platform on the Manchester to Preston (via Bolton) route? What combinations of units will this be able to take?
The retaining wall doesn't look completed, so my guess is the 'fettling' may be the installation of some new piles for it, as it should have been completed by nowB410p Lostock
The ziggurat still seems to need heavy fettling.
The entire reasoning behind these piles is an anecdote for NR's incompetence and sky-high electrification costs.
But you never know
That's what we thought when we designed it. Electric route, with 390s running (nearly) past both ends ... too obvious an eventuality to ignore. Platform 4 also has passive provision for extension to the same kind of length, if you look closely at the south end.Obviously useful for diverted 390s...and the work is done should some 390s call in the distant future..
Be handy to start an early morning Manchester Picc - Euston from Bolton, and terminate one there in the evening. Capacity at Piccadilly P13/14 being one of a few issues.
Still, if there’s a will.
B418m - section insulator (SI) where two electrical sections meet but are not always connected; the section switch that connects them (or not) can be seen above the boom. The strange wiggly horns are arcing horns to allow over-voltages (e.g. lighting strikes) to be dissipated into the other section if required.
AT wires now up and stretch from Blackrod towards Adlington.
