Blockade to allow Waterloo upgrade to take place, resulting in timetable changes
The passengers know how easy it is.
What's more ridiculous though is that "letting off steam" on twitter is one thing, but what passes for BBC journalism nowadays is to just copy and paste those random ignorant tweets onto their website.
infobleep
27 Feb 2011
I say what I normally say re: these rants: I'd rather they let off steam on twitter than taking it out on front-line staff. The former can be safely ignored where appropriate.
If I'm honest, I do think people's expectations could have been managed better, especially in the aftermath of the derailment, however possibly due to how the first couple of weeks went, NR were scared of any further negative publicity, and buried their head in the sand a little.
The project has by and large gone well, and customers mostly understanding (ignoring obsessive local rags which were only interested in headlines which turn people's heads). NR should be able to take many positives (and lessons, of course) away with them.
I think a lot of organisations are scared of anything negative coming out. I think it's inherently human. Saying that, when I did a masters dissertation, I documented everything good and bad. I was then told that it came across to negativelya and hindered the message that the overall outcome was positive.
Thus I put the negatives in an appendix. Detail was there but it wasn't jumping out at you and detracting from the overall positive conclusion.
Maybe Network Rail could have done something similar.
Does the new track layout make it more likely that you are going to be held at the last signal on the UP SLOW? It's only one day, and I'm only on my pnb but I am wondering. Do any other drivers have a view on this? Haven't got past that last signal without having to stop yet.
Sounds a bit like what often happens when arriving on the UMF.
Isn't the idea in the future, i.e. when all 24 platforms are routinely available, to operate main suburbans into all six of the 10 car platforms, which is supposed to counteract the fact that the new layout is slightly limiting?
I suppose 2 into 6 will always have many conflicting moves, it will possibly take a while for signallers to find the optimum way to use them, and possibly tweak the timings.
Incidentally, in the event of a "logjam" can a train from say P5 or P6 leave via the down main fast and then cross over behind an incoming train onto the down main slow, and hopefully before Vauxhall?
RichardN
29 Nov 2013
Are any extra suburban services now being strengthened now that all the Waterloo platforms can take 10 coaches?
Or will they still need to have the special 9xxx service codes for the 10 coach suburban services?
ijmad
7 Jan 2016
December '17 timetable change I'd heard...
MarkyT
20 May 2012
Torbay
With the new layout, #4, #5 and #6 can access the down main fast and can then cross back over to the down main slow through the west crossings junction. I don't think such a move would be able to get around the rear of a stationary 10 car waiting at the up main slow home however, but as long as that was already moving in parallel to a lower numbered platform the manoeuvre should work as soon as the up train's tail has cleared west crossings.
bb21
Emeritus Moderator
4 Feb 2010
Class 9s should not be needed from now on. They were only needed to help prevent those trains being routed into Platforms 1-4, which is no longer an issue.
The only other common occurrence of Class 9 on the Wessex route is now for when Class 153s are scheduled through Salisbury.
rj90
4 Jun 2014
Sent from my SM-A510F using Tapatalk
There's currently a flank protection limitation designed into the interlocking, but it can be removed and is going to be. This stops trains being routed into 4/5/6 from w2 and 7/8/9 from w4 at the same time despite it being ok. Similar applies for some routes out of the platform.
With regard to using west crossings - they are only 15mph and all of it is double slips so it won't be used for timetabled services. Further down the line a three line crossover might get installed between Waterloo and Vauxhall with a much higher speed - but this is pure conjecture on my part and I have never heard it mentioned, it's certainly not in scope. In reality once the WIT is open things will flow much more freely. Plus, all the timetable modelling says it will work as installed with no future modifications required to deliver the aspired timetable - and in reality the signallers at Wimbledon are able to achieve more than the modellers suggest (models and SWT said the timetable wasn't achievable with the extra closure of P10 and DMF/UMF to west crossings)
MartinB1
10 Jun 2015
Regarding the flank protection that's very interesting, I'm presuming this will be in place whilst they develop confidence in the system? Do you know how long this is likely to be in place for?
Juniper Driver
17 Jul 2007
SWR Metals
They stopped doing that during the upgrade AFAIK.I didn't work many 455/456 combos (one day I think) though as I was down the main line mainly although I did work two ten car 458's down to Reading.(Oh you explained why during the upgrade)(doh)
https://www.standard.co.uk/comment/...loo-chaos-is-just-unforgiveable-a3614336.html
That train didn't derail.It was just made up.:roll:
That's a nice piece.Not.
But no one could prepare us for the shambles it has become, with nearly every day seeing new delays, usually passed off as “signal failures”, leading up to Tuesday’s derailment.:roll:
Goldfish62
14 Feb 2010
Probably better to over-estimate the works...
I.E add an extra week over to allow extra leeway...That's if they didn't anyway.:D
Must admit I find the same old drivel annoying.I wouldn't mind so much if they actually knew anything about extending platform at Waterloo and what it involves.
I actually thought Network Rail did very well
The passengers will let of steam when they feel like it I had it during the works.The more front line staff get it worse obviously.(I mean Guards and Station Staff.)
So do you never complain about anything you pay for and not get the service or goods you expected? I dare say that you probably do and are not interested in the complexities behind what has gone wrong.
Have some understanding of punters. Rail travel for commuting is a distress purchase. It's expensive. People are going to rant when it goes wrong. Personally I find some of the twitter rants very funny.
Sean Emmett
9 Mar 2015
Reading line trains back to 450s with 456s on the Ascot - Guildford shuttle.
The 17.54 WAT - FNH ran pretty much to time yesterday as far as Ascot anyway. Much less crowded than the 17.50 WAT - RDG.
Juniper Driver
17 Jul 2007
SWR Metals
What is the problem with that?
If they've got additional work to do,they have additional work to do.
I probably have more understanding than you will ever imagine.
HarleyDavidson
23 Aug 2014
Ditto. It never ceases to amaze me how the commuters always seem to think that they can do better than anyone else including the people who actually run the business.
This criticism comes from people who cannot keep their grubby hands off passcoms, egresses, ignore quiet coaches, pick the locks of locked toilets amongst other things and then whinge and whine about it on Sochal Meeja.
Passengers are more often than not the primary cause of delays and cancellation due to their own actions.
gimmea50anyday
8 Jan 2013
Back Cab
This adds to the worry:
https://www.gov.uk/government/news/collision-near-london-waterloo-station-15-august-2017
Those old enough to remember Clapham will have the cold shivers!
Hmm, yes it does. in the case of Clapham a rogue live wire which should have been removed or isolated caused a false proceed aspect to be displayed. As a result of that incident the Hidden regulations on working times was introduced which are entrenched in traincrew rosters and diagrams. I myself have had to delay trains in order to adhere to break requirements etc
Juniper Driver
17 Jul 2007
SWR Metals
I couldn't work a train back from Bournemouth during the blockade as I'd wandered into hidden.(had to pass back)
I'd worked a train down there as they were desperate and had no one to work it with less than 20 mins to spare...I made over two hours overtime which I didn't want as I don't want overtime and don't work rest days...but people forget this,conveniently.
Under normal scenario of this turn I'd have been home at 1430 (at the normal latest without overtime)...I got home at 1730.
IIRC the cause of continual signal failures on the London Bridge upgrade turned out to be a cross wired cable
You recall incorrectly. There was one example of this in September 2014, and it was a fail safe.
hwl
5 Feb 2012
The earthing of the lights and mains sockets in one of the interlocking containers proved much more problematic. Just because the cable is green and yellow doesn't mean you should or can connect them all up...
NSEFAN
17 Jun 2007
Southampton
A case of Earth not being the same potential in various locations?
hwl
5 Feb 2012
Another part of the WARS scheme of the 1980s and done under a lot of time and cost pressures.
I am slightly surprised replacement of the existing interlocking at 30
+ years old wasn't considered as an alternative given the effort needed to modify it. Some of the similar vintage stuff on the Sussex side hasn't lasted well and is being replaced.
Hellzapoppin
16 Jan 2016
I think you'll find that Hidden wasn't regulations but recommendations.
It was considered. Big bill though. Particularly as the changes - although large - aren't massive. Some of the earlier stages of London Bridge have almost been as large in terms of new relay interlockings.
Besides the interlockings done in the late 80s Waterloo resignalling are in far better nick than those done for Victroia resignalling nearly a decade earlier.
FOH
17 Oct 2013
Ah yes that rings a bell now, faulty earthing which caused signal failures for a couple of months
