A lower reading of 90 is not normal range,as I pointed out above,its just entering hypertension territory and,as such,needs monitoring at best.
I know what i'm talking about.
Just entering yes, but medically is not classed as high.
Are you in Truro as per your profile? I moved to Redruth as couldn't afford to live there any longer, it's cheaper to drive and pay my rent here than to live in truro and walk to work.
Our wages are well publicised as amongst the lowest and living costs amongst the highest in the country down here.
I used to do those kind of hours when I worked at McDs, I now get similar income to that you mention but only doing 37.5 hours a week.
Near Perranporth, need to be near here for family reasons (childcare etc).
If we moved to Redruth we'd probably burn as much money in fuel as we'd save on rent trekking up to the inlaws/friends/family/etc.
I agree with you, and I know it is not easy, especially if really busy at work and with a young family. I managed to lose 2 stones already, and still losing now. No fad diets, just cutting out unhealthy snacks in front of tv late at night, and sensible homecooked food. Also walking 30 mins each day. Oh, and stick to water instead of juices/fizzy drinks. Well done on the bp test, and good luck for the restI've done Nutrition Plans before and found it a total waste of time and money. Partly because I can't stick to it because of work (breaks taken at odd times and in places with no facilities), and I've found the meals leave me wanting more. I appreciate they work for some, but there is no substitute for good old fashioned exercise combined with eating sensibly. Unfortunately in my current situation neither are easy to do.
Many of the nutrition plans have more negatives than positives, losing too much weight too quickly is far worse medically than being obese. Losing weight too quickly can cause cardiac problems.
I find it hard to believe that following an approved nutrition plan will cause an individual to enter catabolysis.
It could be white coat syndrome as a previous answer said. I have a BMI of 28 and I recently had a random blood pressure check at the docs. It was high, and after going back 3 weeks in a row to get it re checked it was getting progressively higher. My doc was considering medication and then decided i should wear a blood pressure monitor for 24 hrs to get a real picture and this included sleeping and a full working day.
Well, over the 24 hrs the result was bang in the middle of normal for my age. It never went into 'high' readings. He then suggested i have white coat syndrome; my blood pressure goes up whenever i am in a medical situation.
If i get through to a medical with the TOC that i am applying to then this does concern me. I would have to ask them to confirm with my doc about this white coat syndrome should i get a high reading!
If getting the job depends on your bp reading then i would suggest you at least ask your own doctors advice and see if you can try the 24hr monitor. My understanding from my doc is that a lot of surgeries do have them now.
Good to know. Thank you.Not only be aware of "white coat syndrome" but also ask for your checks to be made in the old-fashioned way manually with a stethoscope and mercury sphygmomanometer.
Some of these battery-powered machines can be inaccurate - in my experience two consecutive readings in quick succession can be remarkably different.
However, some machines aren't inaccurate. In my experience (using a £25k machine) it is only inaccurate at the extremes of blood pressure or pulse rate.
Some cheap machines can (especially the ones that measure around the wrist) be horribly inaccurate but they are usually the consumer level. However, some machines aren't inaccurate. In my experience (using a £25k machine) it is only inaccurate at the extremes of blood pressure or pulse rate. Any result which doesn't fit with the clinical picture should be an indication for a manual blood pressure being taken.
That being said, the gold standard is listening for Korotkoff sounds with a stethoscope.
I should hope a £25k machine could be trusted!!
The one my GP lent me after my heart op was more in the £60-£70 bracket, and I changed the batteries!!
