BML closed between Gatwick Airport and East Croydon (various routes) on 12 January
Somewhere
14 Oct 2023
My post wasn’t clear but I was trying to contrast the responses to Southern going out of their way to keep things running, compared to the disruption the other week where every other post in a thread was “why didn’t they do this? It would’ve been better” or “they could’ve done that”
Your post was clear, and I explained that there are the resources to plan things in advance, but there aren't the resources to plan things with no notice.
steamybrian
26 Nov 2010
Kent
Now if Uckfield to Lewes line was reopened there would be an alternative route to Brighton.....
( I will now run away and hide before it starts lots of discussion....!!!!!!!! )
Jan Mayen
30 Sep 2020
Sussex
Just finishing a journey from Three Bridges to London Victoria. Departed 0750, arrived 0932. It went smoothly, my thanks to all who arranged it.
Looking forward to the journey back this evening
Bikeman78
26 Apr 2018
You should've seen the queues at Gatwick on boxing day
They aren't full today. I viewed two trains around midday. Plenty of pairs of empty seats in the three coaches towards the middle of the formation. I expect the south ends would have been quieter still. No justification for not letting people on at Horsham. The doors reminded locked.
TUC
11 Nov 2010
Even worse that this is an airport so people will 1) struggle to get to the airport and 2) probably never use the train to an airport again just in case it happens again
What kind of person plans a time-sensitive journey to an airport without even checking train times and services?
3 Nov 2023
ARUNDEL
Nobody would normally use it as most of the theoretical passengers travel free with their bus passes
A complete waste of money
BUT if the Arundel chord was built (400 metres)
you would have an alternative route to Brighton at a FRACTION of the cost and disruption
PGAT
13 Apr 2022
Selhurst
The Arun Valley line is used for Brighton diversions already, the only difference is that they reverse at Littlehampton
Nicholas Lewis
9 Aug 2019
I recall the points at Stoats Nest were replaced in a blockade over Christmas 2013 - was that a like-for-like renewal or did that introduce some subtle change to the pointwork that introduced the annual tamping requirement?
Most modern concrete layouts use split bearers as it allows the layout to be delivered by tilting wagons and avoids site build up. The problem with the split bearers is the need to keep the layout pretty solid to avoid stress being placed at the joints. The bearers can easily run to 7-8m so they can exert a huge bending moment about the joint and cause it to fail. This is why tandem tamping is used to get the layout relevelled
My understanding is that the electrical supply for the third rail between Dorking and Horsham can only support a maximum of 2tph in each direction (at least when they're 12-car in length), so the half-hourly diversions are all that can run. Indeed, when such a possession is required on a Saturday (as happened in 2024), buses replace the normal stopping trains between Dorking and Horsham to enable the diversions to run.
Thats not correct this was the main route to Bognor and Portsmouth pre the diversion of all coast services via Gatwick. Pathing down through Epsom used to be the main challenge.
PGAT
13 Apr 2022
Selhurst
We all know that
But it is the Littlehampton reversals that take time, money, inconvenience, delay and stress
Do any of these things pay the bills for such a chord? It would only be used during in very niche cases like this where a circuitous route into London is the only option.
Nicholas Lewis
9 Aug 2019
Not at the cost of new infrastructure now. Would need land acquisition so T&W then the whole area would need to be resignalled. Not much change out 0f 100m.
3 Nov 2023
ARUNDEL
The local councils will dispute that figure (400metres)
And so how much would re-instatement of Lewes-Uckfield (8 miles) cost?
steamybrian
26 Nov 2010
Kent
Resinstating Lewes to Uckfield would provide a rail service from the growing towns of Crowborough and Uckfield to Lewes to the South Coast as well as a diversionary route.. Far better to provide a new regular train service that will be well used. Not everyone has a free bus.
I cannot see the justification of providing an east facing chord at Arunder Junction that will be only be used on a few days per year.
Jan Mayen
30 Sep 2020
Sussex
It could be used for a Horsham to Worthing Service :)
Edvid
7 Feb 2008
Rail replacement pick-up access at Gatwick is unusual by virtue of passengers having to use the entry gates, which I've not seen elsewhere.
Interestingly there was also a notice at East Grinstead explaining Gatwick tap-out arrangements for contactless/Oyster PAYG users so they weren't unfairly treated for using that route, which is good.
I planned for possible delays on my day out but didn't expect the RRB I rode on to crash into a car queuing at a petrol station! (It was a low-speed crash and nobody was hurt AFAIK.)
Nicholas Lewis
9 Aug 2019
Ashington cost 300m on an existing railway. It might be short but thats two double jcns, ground conditions pretty wet in that area with plenty of ecological and environmental constraints, would need a complete new interlocking and as soon as they touch anything old the ramifications always push out beyond the immediate area.
Its ludicrous amount I agree and i dearly wish the industry would take a long hard look at itself and get costs back to realistic levels.
3 Nov 2023
ARUNDEL
l have been speaking with a couple of Arun District Councillors about this. They are incredulous
May I have your permission to quote you?
And do you have a source for that cost figure?
Arun and some Mole Valley Councillors want a study of a possible Dorking - Horsham - Arundel -Worthing service
Harpo
21 Aug 2024
Newport
Ironically, normal Hex and Gatwick Express frequencies and journey ties are intended to provide a turn-up-and-go service that makes timetables obsolete for most users.
11 Jan 2015
In terms of busyness Victoria at 19:20 was about as busy as in COVID, ie as quiet as I’ve ever seen it. On the every 15 min service to East Croydon. Quiet as well. Sensible people from further south than Croydon will simply have arranged to do something else today.
43066
24 Nov 2019
Nobody sensible travels to an airport for a flight without checking, especially on a Sunday when it’s common for services to reduced/suspended for engineering. Most people in the catchment for Gatwick would simply take a cab or perhaps drive and pay for parking.
Unfortunately, "nobody sensible" is also most likely to run to the red tops to tell the tale of how "Fat Controller RUINED my holiday!"
Probably accompanied by a picture of them looking miserable standing on an empty train platform, surrounded by piles of luggage and with a train ticket in hand.
steamybrian
26 Nov 2010
Kent
As a matter of interest what work was being undertaken at Redhill to obstruct services from Reading and Tonbridge?
43066
24 Nov 2019
I doubt it. It’s a weekend engineering closure.
It’s a little contradictory for some people to be saying “we should have been given more notice”, while others claim the service is treated as turn-up and go so that nobody checks the timetable anyway!
It’s sounds as those the bus replacement provided was fairly decent. Personally I wouldn’t consider taking that if I had a flight, and would most likely drive and park.
From Gatwick’s point of view this is probably quite a sensible weekend to do it as the Xmas/New Year rush will have died down, and it’s perhaps too soon after the festive season for people to be heading off skiing just yet.
I dunno. We're still being treated to stories of people falling foul of EU passport validity rules that have been in force for going on five years.
43066
24 Nov 2019
Well there’s just no helping some people! The work still needs to be done at some point.
IrishDave
30 Jun 2009
Brighton
Thanks very much for the explanation - much appreciated!
Skimpot flyer
16 Nov 2012
On the 20:05 Victoria to Gatwick service and the driver announced on departure that ‘we will be calling at Clapham Junction, Epsom, Horsham and Gatwick Airport’.
Nice to know, but the departure boards on the main concourse and the display screens on the platform all stated Clapham Junction was the only stop.
So anyone who isn’t a train geek would not know they could get to Epsom or Horsham on this service !!
The train that came in on Platform 16 at around 19:55 was indeed rammed with suitcase-draggers. I’d estimate it was about 80% full.
On calling at Clapham, the dot-matrix (?) screen displayed
“20:13 Calling at Gatwick Airport only”
