Borders Railway - Now Open
clc
31 Oct 2011
GARL strikes me as a very inefficient use of capacity just shuttling back and forward between Central and the airport. I'd rather the airport was served by longer distance inter-regional services such as Ayrshire to Edinburgh. Obviously you'd need Crossrail to enable this. Also, the only shuttling that takes place should be between the terminal and the existing line; surely there must be a viable alternative to building a very expensive heavy rail line right into the terminal?
marks87
23 Jun 2010
Dundee
Both Glasgow and Edinburgh airports could, in principle, be served by building or relocating stations on existing lines and linking with some form of light rail, similar to the Gatwick monorail.
Glasgow - move Paisley St James a mile or so west and build a link along the route of GARL (more or less).
Edinburgh - move South Gyle a few hundred yards north and build a shuttle to the terminal.
Xenophon PCDGS
17 Apr 2011
As a supplementary query to your point above about GARL, was it the Class 380 "Desiro" units the ones that were to be specified to operate this service before the spending cut-backs put an end to the project. How far advanced was the placed order before the embargo was made ?
D365
29 Jun 2012
Yes, there were a number earmarked for GARL, the provision of which has left a bit of slack in the fleet, but these units will be put to good use soon.
jopsuk
13 May 2008
The tram will connect Edinburgh Park and "Edinburgh International Gateway station" (beside the Gogar Roundabout) to the airport. So this is rather being done, sort of.
clc
31 Oct 2011
So the airport would be served by the existing 4tph on that line. Would a monorail to Gilmour St be feasible? If so, existing services through GS would give you 10tph to the airport without having to run any additional trains.
Zoidberg
27 Aug 2010
West Midlands
There is, at last, an end in sight http://www.edinburghnews.scotsman.c...rams-on-princes-street-by-christmas-1-3096728
The building site that is central Edinburgh will soon be no more, thank goodness.
TRAMWORKS will be cleared from the streets of the Capital in less than five weeks – paving the way for the line to be open for test runs on Princes Street before Christmas.
City leaders today announced a new timetable for the project which will see passenger services underway by May at the latest.
marks87
23 Jun 2010
Dundee
That assumes the trams were a good idea :p
When you have landing planes practically touching the railway line, it seems madness not to have a station nearby, served by some form of light rail (whether that be a tram, monorail or something DLR-esque).
I know there was uproar when the trams were stopping at Haymarket, which meant changing from plane-tram-train to get to the centre of Edinburgh, but correctly implemented as part of the airport infrastructure, a shuttle to a national rail station would be seen as not much different to the North/South transfer at Gatwick.
A monorail to Gilmour St would be too long, I think - as with Edinburgh, it would need to be a short enough trip to seem like part of the airport experience. Move St James station (or build a new one) to just before the A737 bridge and you're within a mile of the terminal building.
Is the Paisley Corridor at capacity? Could the 4tph along the Inverclyde line be doubled as far as St James, which could gain terminating platforms in its move?
(All just back of an envelope thoughts, which are no doubt full of holes!)
Altnabreac
20 Apr 2013
Salt & Vinegar
The Paisley Corridor improvements part of GARL went ahead despite cancellation of the airport link.
This gives capacity for an additional 4tph in the Paisley corridor and at Glasgow Central.
However since the cancellation of GARL 2tph of this capacity has been used to introduce Ayr/Irvine semi-fasts.
So you'd probably be looking at strengthening the Inverclyde services to 6tph. 4tph to Gourock would be easy enough and is the peak hour service anyway. Wemyss Bay would need some significant new infrastructure to take 2tph so you'd probably have to run a service in the opposite half hour terminating at Port Glasgow. Not sure what if any turnback facilities exist there.
Could see that being a reasonable use of the extra capacity even without any airport service and 6tph would provide a decent frequency.
Would also allow a recast of the fast / semi fast split in Inverclyde to a possible skip stop pattern.
Can't imagine you'd get much change out of £50m for your people mover though so it seems very unlikely to be a goer.
clc
31 Oct 2011
£50m seems a good deal compared to GARL if I've understood correctly:
GARL - £200m = 4tph to airport + 8tph to Ayrshire/ Inverclyde.
People Mover - £50m = 12tph to airport/Ayrshire/ Inverclyde.
TheKnightWho
17 Oct 2012
Oxford
I doubt it'd be able to keep up with anything like the demand if frequency was that high.
Altnabreac
20 Apr 2013
Salt & Vinegar
What you've forgotten is that GARL at £200m included the Paisley Corridor Improvements programme to create those extra 4tph. While GARL was cancelled PCI went ahead at a cost of £170m (not directly comparable as the new PCI included some additional elements that were not part of GARL).
However £100m+ of that £200m has already been spent so the monorail will probably bring costs up to a similar outlay for the original GARL project. With the mode change the time penalty is likely to put off potential travellers so you are looking at similar costs but fewer passengers.
caliwag
29 Mar 2009
York
Ha...Bear in mind the ongoing thinking, and justification, for the rebuilding of the 'old' line via Glanfarg of Forth bridge to Perth. Given that there is a motorway on some of the route, £1 billion seems a fair guess. Of course this is justified in time saving to the North and as a longer term solution to just doubling bits of the A9. Would be rather nice to see though! Look forward to KWVR's Dubdee working up the bank with as many mineral wagons as can be mustered. WJV Anderson would hear it from his grave!!
jopsuk
13 May 2008
I know there was uproar when the trams were stopping at Haymarket, which meant changing from plane-tram-train to get to the centre of Edinburgh, but correctly implemented as part of the airport infrastructure, a shuttle to a national rail station would be seen as not much different to the North/South transfer at Gatwick.)
A dedicated system running from a station at the runway end would make the trams seem like value for money. What is being implemented is a sensible solution.
PaxVobiscum
4 Feb 2012
Meanwhile, back at the topic :D
http://www.bbc.co.uk/news/uk-scotland-south-scotland-24107619
Borders to Edinburgh rail route interchange preparations begin
Construction work on the interchange building in Galashiels will get under way
Preparations have begun to clear the way for a purpose-built transport interchange in Galashiels associated with the Borders to Edinburgh railway.
It aims to "link up sustainable modes of transport" with the rail route when it reopens in 2015.
The first phase of works will see the realignment of the town's Stirling Street to create a space for the new building.
It will also see the creation of a new civic space and car park.
Construction work will begin on 14 October and is likely to continue until the new interchange comes into operation in 2015.
Car parks in the area have now been closed in order to let preparatory works begin.
Construction of the building itself will start in early 2014 once the infrastructure improvements are complete.
Minimise impact
Scottish Borders Council's executive member for roads and infrastructure, Gordon Edgar, said it would ultimately be a major boost for the area.
"We appreciate there is going to be some impact to existing arrangements to allow this work to get under way, but this is a huge project which will bring some significant benefits for local businesses and for people travelling into and out of the Borders," he said.
"All of the work this year is being carried out by SBc Contracts, the council's in-house contractor, to ensure traffic management requirements are fully co-ordinated so that disruption is kept to a minimum.
"This single point of control will also benefit co-ordination with the Borders railway project."
And as for progress on the Whifflet electrification:
When Whifflet electrification was announced in May the Scottish Govt said the reason for bringing it forward by 4 years was to allow greater flexibility in deploying trains during the Commonwealth Games and to free up rolling stock for the Ryder Cup. Given the political importance of both of these events the SG must be very confident the scheme will be complete by next Summer for it to make such a public commitment.
Edit: Also, during the Rail debate on 30 May Keith Brown stated: "I mentioned the Whifflet route electrification, which will take place by summer 2014. Work on that will start next month..."
All of which I am aware.
I took a run out to Cumbernauld via Whifflet this morning (Friday 20/9/13) just to see the progress. Work has indeed started at the Cumbernauld end. OLE masts, signalling cable ducts and signals are being installed from Cumbernauld through Greenfaulds and has reached just short of Garnqueen South Junction. Obviously the line is electrified anyway as it approaches Coatbridge.
Absolutely no sign of anything happening yet on the Whifflet to Rutherglen line which was my point. However, there's still another 9 months left which is enough time for many things to happen. :D
onyxcrowle
29 Jul 2013
I am not to sure if it would be cost effective to open it all the way to Carlisle or even Hawick for that matter.
Another alternative would be to open it to St Boswells and then on through Kelso and on to the ECML at Berwick this would then give people a chance of travelling south from the central borders by train.
I am aware the it would mean a new station at Berwick but it would not be a major problem to build one south of the existing one the other side of the river.
I would suspect that this option would be cheaper than opening the Waverley route through to Carlisle.
One big problem of opening right to Carlisle is the the missing bridge at Hawick.
Hi guys im New on the forum and avidly following the Bordets route.
I think thst the line needs to push onto hawick eithin ten years, its quite possible to extend an extra mile to Melrose.
To take frieght up It from carlise has to be a major plus.
As for St Boswel there should be serious attention given to thatnas it will not only open yet more of the borders to rail but provide a bypass for the Ecml.
it might promote the fact you could link Berwick to Edinburgh via Boswell and provide a local service there,
in reality though I forsee hawick soon and before that perhaps even five years electrification.
Now all they need is full doubling.
Id also reopen the Stirling callander to oban line. its criminal It was ever shut .
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Good phot of work to cross the city Bypass on the bbc website.
I'm surprised they've bothered to replicate the rumble strips and signage on the temporary carriageway.
In fact with the amount of earthworks they've put in just to move the road, they could have built a flyover for Sheriffhall roundabout. :lol:
YorkshireBear
23 Jul 2010
Councils are rather strict on that kind of thing now a days... they wouldn't have been allowed with them.
railjock
30 Jun 2012
Drove along the bypass today and the underpass for the railway is certainly taking shape. The bridge over the A7 at Gore Glen should be in place next weekend. I can't remember what the previous bridge looked like and can't find any photos of it either, shame.
