Bridge strike at Plymouth (30/08)
alastair
14 Oct 2010
Dartmouth
This does not look good. https://www.devonlive.com/news/devo...5yMdPgDaMKpZFj-XnvXBHvcVjgUaH1ISsoP-DqSCnIOHn
Disruption to trains and nearby roads is expected until the end of the day after a lorry wedged itself under a Plymouth bridge.
The lorry first became stuck some time just before 3.30pm today (August 30) underneath the train bridge in Mannamead.
Other vehicles can not get through as a result of the lorry-shaped blockage.
Some westbound XC's seem to be turning round at Totnes.
PHILIPE
14 Nov 2011
Caerphilly
GWR saying could be closed until end of the day with passengers, especially at Exeter St Davids, all over the place trying to get information.
GWR saying only limited road transport available.
Extract from GWR Journey Check
Cancellations to services between Plymouth and Totnes
Due to a lorry colliding with a bridge between Plymouth and Totnes all lines are closed.
Train services running through these stations may be cancelled, delayed or revised. Disruption is expected until the end of the day.
Customer Advice
Extremely limited replacement road transport has been sourced to run between Exeter St. Davids and Plymouth. Passengers are advised not to travel between these stations.
South Western Railway are conveying passengers between Exeter St Davids and London Waterloo in both directions until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
CrossCountry are conveying passengers via any reasonable route until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
Information on the ground virtually non-existent
py_megapixel
5 Nov 2018
Northern England
Based on the picture in that news article and the Google Street View for what I assume must be the bridge in question, the driver must have ignored at least two signs warning them of the 10'9 height limit in conjuction with the mandatory notice in their cab informing them of the vehicle height.
If that is indeed what happened then they should be stripped of their drivers license and maybe they or their company should foot the bill for all the delay compensation that will come out of this.
Nova1
26 May 2021
Stratford-Upon-Avon
Plymouth rail services disrupted after lorry hits bridge - BBC News
this image is hilarious to me, how on earth that driver thought he'd fit is beyond me. I hope the driver is held accountable and the company is expected to pay for repairs to the infastructure.
apparently there is significant damage to the bridge, it's been lifted up by a few inches, and the rails have been moved slighty.
and meanwhile on the passenger side, CrossCountry have said they've been unable to source road transport. Going to be a long night if you wanted to go in or out of Cornwall and Plymouth (as I imagine many may want to at the end of a long bank holiday!)
XC services from the east are terminating at Totnes. I expect they'll have a unit or two and crew "cut off" to the west.
GWR are advising "do not travel" between Exeter and Plymouth, and the Night Riviera is cancelled in both directions tonight.
Horizon22
Jobs & Careers
8 Sep 2019
Large Tesco lorry which was 0.6m higher than the bridge height has struck the bridge. Line expected to be shut until the end of service today and beyond. It's reported that the line has been raised. Trains are terminating at Exeter, Netwon Abbot and Totnes where possible. Currently hundreds stranded at Exeter SD.
GB
16 Nov 2008
Somewhere
Line potentially closed for a couple of days. Has lifted the rails and cracked sleepers.
Nova1
26 May 2021
Stratford-Upon-Avon
Looking at it from the other side (https://goo.gl/maps/QJGm4j1t2fNfViw5A) you can see that the road is on an incline and the headroom at the far end is less. I wonder if the driver ignored the signs and just saw the size of the tunnel entrance?
Probably - but still, the driver should know better. They should know the height of their vehicle. It wouldn't have even been that far to divert to a bridge over the railway!
Other bridges have these "strike plates" (not sure of official name), so overheight vehicles hit that instead of ripping apart the bridge.
(This bridge is near Grantham)
As you can see here, the structure in front of the bridge meant there was no damage to the actual bridge, allowing services to continue.
py_megapixel
5 Nov 2018
Northern England
In my view that is no excuse. Height limits are signs on every low bridge for a reason. Vehicle heights are posted in every HGV cab for a reason. HGV drivers require specialist training for a reason.
It is their responsibility to know the height of their vehicle and plan their route accordingly, and frankly, if they can't do that then they should not be in charge of multiple tons of machinery.
ANDREW_D_WEBB
21 Aug 2013
Will be a challenge to recover the lorry without damaging the bridge further, the deflate the tyres and pull it out method won't work from the front, so it looks like it will have to be winched back under the bridge. Fortunate no train was crossing at the time.
Horizon22
Jobs & Careers
8 Sep 2019
The lorry cannot currently be moved. Coaches are being arranged for tomorrow morning's service.
Haywain
3 Feb 2013
I believe there are restrictions in putting things like that in place which is unfortunate as it is such a simple solution.
SteveM70
11 Jul 2018
That’s a shame. Although in the example in the photo upthread, I’m not convinced having the strike plate so close to the bridge would be that effective
29 Nov 2018
All very well being wise after the event but apportioning blame or chastising drivers isn't much consolation to those inconvenienced by these seemingly regular occurences. Furthermore, trains may well pass over unsafe bridges prior to the strike being identified, which is hardly ideal. Surely it would be better to reduce the possibility in the first place by design.
I often wonder how much effort goes into raising low bridges. Often bridges (and/or the roads beneath) are replaced with others of similar limited clearance
Horizon22
Jobs & Careers
8 Sep 2019
You wouldn't be raising low bridges for bridge strikes - you'd be needing to lower the road surface.
It would be better if lorry drivers drove properly. Or get the road haulage industry to pay to redesign our Victorian under bridges.
27016
2 Feb 2020
We'll have to wait and see what the full bridge inspection reveals, once the lorry has been removed. Either way that looks very much like major structural damage to the bridge, which will take more than a few days to repair....
nanstallon
18 Dec 2015
The railway is so vulnerable and there is no resilience. Regardless of fault, it makes me feel that road transport is more reliable.
21 Oct 2012
Wilmslow
The bridge is over a notorious rat-run through residential streets between Mutley Plain and Alexandra Road, used to avoid most of the traffic-lights on Mutley Plain itself. It should be closed anyway, apart for pedestrians and cyclists. Looking at the pictures the rising gradient has meant the lorry has given the bridge a severe thwack, and the damage is pretty major.
Jamesrob637
12 Aug 2016
Done it a few times when living there! Surely the route via Okehampton should be reopened in the next decade!
