C2C 387s
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
Indeed - the cascade seemed to work rather well for GTR from that perspective. Still wonder whether the blue doors will be kept or whether Southern olive will be vinyled to match the /1s? Have to admit, the blue doors suit them better.
The blue is significantly darker than what they use on the 700/717 though. I reckon they should revinyl the entire 387 GN (not GX obviously) fleet with blue doors in the same shade as the Desiro Cities. Perhaps they will.
43102EMR
28 Mar 2021
Could be true yeh. Maybe thats proof that they were at one point expected to be sent to southern
The units were ordered by Southern for Thameslink before they became part of GTR, hence why they were built to their spec - after that, they were expected to be used on Corby services with EMT. Once the MML electrification got delayed, they were then bound for GWR until they ordered their current fleet of new build 387s, hence why they ended up going spare and moved to Great Northern to release the planned 377/5s for them to Southeastern.
Guess we’ll have to wait and see, but it wouldn’t surprise me if they left them as they are in all honesty.
Second attempt for the GWR drag? Seems as though a loco is pathed into Reading TCD for Tuesday: https://www.realtimetrains.co.uk/service/gb-nr:53669/2022-07-05/detailed
Class 466
5 Mar 2010
Atherton, UK
Not really, they were started straight after the 377/6/7s were built and effectively a follow on order by Southern for Thameslink services so go Southern Spec interiors/doors. Passengers aren’t going to identify a train by the colour of its doors so there’s no need to revinyl or paint them.
43102EMR
28 Mar 2021
387303 is now at Hornsey, apparently to use the wheel lathe.
43102EMR
28 Mar 2021
I suspect you’ve been misinformed, the wheel lathe is out of use ufn whilst a bogie drop is installed
That doesn’t necessarily mean it will be going in straight away, not going to say who my source is but they’re pretty reliable - the units are now allocated to Hornsey anyways, so will likely also be receiving the mods required to work with GTR.
St. Paddy
11 Sep 2019
Hitchin
I saw it heading to Hornsey earlier, good to know they’re staying on the GN. The lathe upgrade is approximately 2 months into a 6 month project so I hope its wheels aren’t too square :lol:
43102EMR
28 Mar 2021
Ahh yes, misread - basically 303 has wheel flats, so was likely sent to Hornsey taking into account both this and the lathe upgrade. Monday mornings hey!
St. Paddy
11 Sep 2019
Hitchin
No worries lol. If they’re too bad, it’ll have to go elsewhere for turning. There’s a lathe nearby at Bounds Green
3973EXL
2 Feb 2017
26 Nov 2018
You may have answered my question.
I went thruPeterborough today at about 1pm and I thought I only saw 2 387s when expecting 3.
They were in the line nearest to the ECML.
Can anyone confirm both 4 and 5 were there then?
Thanks in advance.
43102EMR
28 Mar 2021
Thanks in advance.
Yes, only 304 and 305 are at Peterborough now as 303 has a wheel flat so went over to Hornsey this morning - 301, 302 and 306 will be due at Nene tomorrow.
Fincra5
6 Jun 2009
303 is also at Hornsey for general Evaluation etc. The Wheel Lathe is O.O.O atm.
43102EMR
28 Mar 2021
So I’ve been told - can imagine it will also receive its mods to be compatible with GN’s other 387s.
Fincra5
6 Jun 2009
Precisely that. They'll be like a GN 387/1 when they're done. Just with Blue Doors...
MCR247
7 Nov 2008
I assume the c2c 387s also have the divide 2/3s down in one of the driving carriages? Do the GWRs ones have this too?
Yes, all 387s have the divide in the 421xxx coach. Likewise, 377/6s, 377/7s and 379s in the same location.
fgwrich
15 Apr 2009
Hampshire
Though at least it actually works as a first class divider in the 379s, unlike Southern who, for reasons unknown, decided to have the sham first class at the inner end of the coach. Just odd that Bombardier carried it through all the subsequent builds following the 379s.
317362
7 Sep 2017
Definitely just left Reading for Peterborough (again), although I didn't see what was up top this time.
Although just seen the clue above so assume 37601!
FGW_DID
23 Jun 2011
81E
Can confirm it was 37601. 5Q45 departed approximately 30 mins early and hopefully that’s the last we’ll see of it! :D
43102EMR
28 Mar 2021
Would appear so - seems to have made it past Acton Main Line this time!
357
12 Nov 2018
They had already had shoe gear and shoes fitted since build. Please check the video that I linked in post #31, and the reply in the next post.
The shoes were removed at c2c however the rest of the hardware was left in place, such as the beams
I’m told the shoes themselves are a very quick replacement job anyway, as they’re obviously a wearing part in normal service.
158798
9 Mar 2022
Cambridge
Not sure if this has been mentioned elsewhere, but I’ve just spotted 303 sitting outside Hornsey with GN branding applied. The Navy blue doors remain for now
