C2C 387s
Fincra5
6 Jun 2009
They can do 110mph with the right PAN but GN only do 100mph for 387s etc.
43102EMR
28 Mar 2021
303 and 304 out today on the usual diagrams, last one should be the 17:43 to Shoeburyness from FST, provided it doesn’t get cancelled again.
357
12 Nov 2018
It was a traincrew issue yesterday, the units are OK
Jturner98
2 Jan 2021
Kent
Is it the pantograph though or is it just the pantograph head which is changed? Would of thought it would of been just the head changed to be honest
aleggatta
28 Sep 2015
its the whole pantograph, as a fitter (at least for me) when we talked about changing pantograph heads it generally only involved the carbons, whilst not technically correct. The pantographs that were fitted were the same type as the 357 so wouldn't have all the high speed design characteristics as the 387 pan does in the whole pan structure. The main visual differences are the large arc horns on the outside of the pan head, and this is part of the main structure of the pan head.
Also, to change a pantograph over, generally only requires the undoing of 4 bolts, an air line and an electrical connection and lifting off with a crane, to do a more complicated rebuild of the pan on the unit would take longer and leave a unit out of service for longer.
43102EMR
28 Mar 2021
It’s running - just passed me at Barking. 303 and 304 again today
Skimble19
12 Dec 2009
I can only assume, but have also heard they might be used with Southern - aim for entry is the September TTC once pantograph changes/tracklink software has been implemented to the 3 with c2c.
Today’s 1P86 working cancelled due to “a problem currently under investigation”
The current plan is for the 6 /3s to stay with GN, releasing GX /2s to move back south.
YSTrains
13 Dec 2021
Some are arguing that they won't be heading for Great Northern. Some are however. For those who are saying they could head for Southern, we will have to see if the shoe gears can still be used.
43102EMR
28 Mar 2021
It’s a similar scenario to the GX 387s (albeit the other way round) - not used the equipment for 5-6 years but as they’ve done FFR/testing on them, still able to be used.
That’s the move that makes the most sense; but I think even the GTR staff are conflicted as to where they’ll end up.
Class455
19 May 2016
As @Skimble19 points out, the 387/3’s are going to Great Northern to send the 387/2’s back to Gatwick Express and will not be going to Southern. Who knows if they’ll eventually end up though depending on what happens with the GWR 387 tender which closed yesterday.
Fincra5
6 Jun 2009
As it stands they are for GN to allow the 6 GX units to go back South....
Jturner98
2 Jan 2021
Kent
Yea
Yeah changing a pantograph is easy. I’ve changed a few on the 378s
Shoes are still able to be used. Part of the exam regime is that they have to be inspected. Last time I was there they still had them it’s just the air was disconnected. It will simply be a case of reconnecting the relevant pipe work
357
12 Nov 2018
They still have the shoebeam/gear however the actual shoes are disconnected as is the air, not sure what happens if DC select is pressed in the cab!
Fincra5
6 Jun 2009
Shoes can be Isolated in the PAN AIR Cupboard. I'd imagine this is where it is done.
Jturner98
2 Jan 2021
Kent
If dc is selected the button will illuminate in the cab, but when you press shoes down nothing will happen and you’ll get an error message on the HMI screen.
YSTrains
13 Dec 2021
So will they immediately start operations or will they will be stored at Peterborough?
43102EMR
28 Mar 2021
Also worth noting that the three that moved today still have their c2c branding on them - surprised it wasn’t removed prior to transfer!
fgwrich
15 Apr 2009
Hampshire
At least it won’t take them long to remove though. C2C, Trenitalia and that’s about it. The interiors are largely Southern anyway so will match the 387/1s.
43102EMR
28 Mar 2021
Indeed - the cascade seemed to work rather well for GTR from that perspective. Still wonder whether the blue doors will be kept or whether Southern olive will be vinyled to match the /1s? Have to admit, the blue doors suit them better.
physics34
1 Dec 2013
Pretty surprised the green doors havnt been changed themselves, GTR seem to normally be very brand aware.
43102EMR
28 Mar 2021
True say, I was expecting them to be changed to the same pastel blue used on the 365s and 700s when their original transfer to GN was announced - guess it comes in handy when unit shuffles need to occur across the GTR brands?
physics34
1 Dec 2013
Could be true yeh. Maybe thats proof that they were at one point expected to be sent to southern
