Caledonian Sleeper
Discussion in 'UK Railway Discussion' started by Essexman, 10 Jan 2019.
  1. Mainliner
    Mainliner Member
    229
    1 Nov 2010
    North Tyneside
    Coincidentally, the latest Tripadvisor review includes a reference to this: “Going to bed the fun started. We didn’t sleep at all during the trip. There was a loud never ending noise from the window. It was like going with high speed through a windtunnel. At first we thought it would be simply dealt with by just closing the window but that was impossible.
    A member of staff apologised profoundly and told us that this complaint was a daily fact. It would never be solved since it was a well known design fault, since the windows were doubling as emergency exits”
  2. John Bishop
    John Bishop Member
    134
    15 Nov 2018
    Transport Secretary was getting a grilling in Scottish Parliament yesterday over the poor performance of CS. Not quite sure what the end result was, it apparently he was refusing to apologise over the debacle.
  3. 47271
    47271 Established Member
    2,724
    28 Apr 2015
    Possible, but I haven't heard that one before. Noise around the window is more likely to be caused by the aircon outlet which is located bizarrely on the bottom sill. This is is also the cause of a separate complaint from seated passengers who find one arm or another frozen during the journey.
    In the mk3s, cold air was pumped in silently via the ceiling. I can only assume that it was cheaper to build with the duct running just below the windows.
  4. OvergroundMatt
    OvergroundMatt Member
    28
    31 May 2017
    The managing director of Caledonian Sleeper is out, reports Richard Clinnick.
  5. Goldfish62
    Goldfish62 Established Member
    3,985
    14 Feb 2010
    The aircon vents on the bottom sill has been pretty much the default location on European rolling stock since aircon started being fitted. It's also present on the Eurostar Class 373.
  6. Bletchleyite
    Bletchleyite Veteran Member
    46,973
    Up and down the south WCML (mostly)
    I doubt it was cheaper. It is very common practice on mainland European coaches, possibly because in a larger UIC coach the ceiling is far further away. It's probably just because that's what CAF LHCS does - the interior of the Mk5 does have a very European look to it unlike all the CAF DMUs and EMUs which look more British.
  7. BRX
    BRX Established Member
    2,327
    20 Oct 2008
    It may be less of an issue in UIC stock because of the extra width. With some UK stock, you end up with the windowsill being used as a kind of armrest, because the actual armrest has been squeezed away to nothing due to overall width obstructions. And if the windowsill becomes an armrest by default, then it's obviously not a great location to have pumping out cold (or hot) air.
  8. mde
    mde Member
    480
    17 Nov 2016
    Here's an extract from the Official Report (it's a bit lengthy) detailing the exchanges in question:
  9. Bletchleyite
    46,973
    Though that doesn't really apply to the Caledonian Sleeper seated coaches as they are basically all First Class.
  10. Struner
    Struner Member
    629
    13 Dec 2018
    Ommelanden, EU
    The Sleeper’s Ross Flaherty has resigned. Not sure if it will help tho? https://www.theguardian.com/uk-news...-boss-to-quit-post-at-much-criticised-service
  11. 47271
    2,724
    28 Apr 2015
    Fair enough, I'd never thought about it much when I've been on trains in Europe.
    Anyway, if it's making a level of noise that's keeping people awake or freezing their arms then it's an unsuitable design.
  12. alangla
    alangla Member
    747
    11 Apr 2018
    I don’t think Nightstar stock had aircon under the window. It’s been a while since I was last on one (Quebec City to Montreal) but I certainly don’t remember anything like that & the lounge car photo here- https://en.m.wikipedia.org/wiki/Renaissance_(railcar) doesn’t seem to show vents there.
  13. Flying Snail
    Flying Snail Member
    977
    12 Dec 2006
    "The cars were built by Metro Cammell in the mid-1990s... They are based on the British Rail Mark 4 design"
    So no reason they would have continental style window AC vents then.
    The overhead vents can be clearly seen in some of those photos.
    Prior to the CAF Mk5 the only stock in the UK built with window ledge vents was the original Eurostar sets and the Irish Rail/NIR Enterprise stock.
    The Irish Rail CAF built coach sets used on Dublin - Cork also have window vents. They also had lousy ride quality when first introduced and despite remedial work never came close to matching the ride quality of the BR Mk3 coches they replaced.
  14. 47271
    2,724
    28 Apr 2015
    So the moral is, don't buy stock from CAF, it's rickety and is generally built to standards totally unsuited to UK or Irish use.
    Too late.
  15. Bletchleyite
    46,973
    I've been on a TPE Mk5a (admittedly in 1st) and I think it's possibly the nicest thing on the UK rails, if that helps. The ride and build quality are poor, though.
    And I'm not a loco nut.
  16. Flying Snail
    Flying Snail Member
    977
    12 Dec 2006
    So poor ride, build quality and some of the most uncomfortable seats installed on any long distance train anywhere; how the hell is it "the nicest"?
  17. Taunton
    Taunton Established Member
    4,222
    1 Aug 2013
    Probably the lowest bid though. Is anything else important to UK purchasers?
  18. 87electric
    87electric Member
    609
    27 Jan 2010
    Anyone know the current 1M11 loco, attached to 1C11 right now?
  19. TimboM
    TimboM Established Member
    3,518
    12 Apr 2016
    92043 is on 1M11 tonight
  20. TimboM
    3,518
    12 Apr 2016
    Lowest or only? There were very few companies from what I recall prepared to even bid for such a low-volume, highly bespoke production run.
    I wouldn't describe still being employed by Serco Group and moving to another area of the business to be nearer his family as "resigning"??
  21. adrock1976
    adrock1976 Established Member
    2,786
    10 Dec 2013
    1M16 Inverness - Euston was double headed by 66706+73968 as far as Edinburgh Waverley.
    The loco from Edinburgh to London was 92010.
  22. 87electric
    87electric Member
    609
    27 Jan 2010
    Thank you for that.
  23. LeylandLen
    LeylandLen Member
    704
    28 Oct 2013
    Leyland Lancs
    1S25 Euston Scotland being diverted via ECML tonight due to WCML closed near Lancaster , OHLE probs.
  24. Tom Maddox
    Tom Maddox Member
    581
    14 Apr 2019
    Frodsham
  25. 6Z09
    6Z09 Member
    235
    19 Nov 2009
    All the rest going WCML, waiting on the line being opened!
    Currently predicted for 0500.
  26. Bungle965
    Bungle965 Established Member
    2,535
    2 Jul 2014
    Blackley and Broughton/ Walsall South
    Last I heard they had found more issues so that time was likely to slip...
    Sam
  27. BRX
    2,327
    20 Oct 2008
    Interesting/surprising that it was possible to arrange this at such short notice.
  28. _toommm_
    _toommm_ Established Member
    2,920
    8 Jul 2017
    Whiston/Leeds
    07:00 at this point; although I'm sure that will get pushed back once there's first daylight.
  29. side effect
    side effect Member
    72
    20 Jul 2015
    1m11 still at Oxenholme and 1s26 stuck in Barton and Broughton lay by if that's what you call it.
  30. marks87
    marks87 Established Member
    1,519
    23 Jun 2010
    Dundee
    The Northbound Highlander hasn't fared too bad, all things considered - diverting via the ECML has left it "only" around an hour late into all three destinations.
    The Lowlander not so good. Running only to Glasgow, and currently 178L around Beattock.
Share This Page
