Changes to FGW Advance fares from 17th May 2015
gareth950
3 Nov 2013
I've noticed that there are changes to FGW Advance fares from the start of the summer timetables on 17th May. FGW Advance fares have been unavailable from the National Rail website over the last few days and buying tickets directly from FGW's website shows some advance tickets have gone up, with others coming down.
I'll be booking tickets soon for a XC/FGW trip in July so this has come as a surprise. How common is it for TOC's to completely change all advance fare prices half way through the year, rather than just when fares usually change in January?
bb21
Emeritus Moderator
4 Feb 2010
There are three fare rounds in a year: January, May and September. Not all fares change in January, eg. off-peak fares in the West Mids area normally change in September, and rises are not limited to once per year.
Changes are also possible outside the normal fare rounds, although it doesn't occur as frequently.
In addition, Advance fares are not regulated, so there is no reason why they cannot change from week to week if the TOC wishes.
gareth950
3 Nov 2013
So it's just Anytime and Off-Peak fares which are regulated and can only rise once per year, usually in January?
Thanks for the information
bb21
Emeritus Moderator
4 Feb 2010
Some Anytime and Off-Peak fares are regulated, depending on the flow.
Even regulated fares can rise more than once a year, but more often than not, the overwhelming majority only do so once a year in January.
gareth950
3 Nov 2013
What do you actually mean by 'wholesale changes'?
FGW Advance fares on the routes I've been looking at the last few weeks have all changed recently. Mainly FGW routes from South Wales to London, to Bristol and on routes in the South West. Not sure on their other routes. Perhaps I exaggerated slightly using the word wholesale, I've now edited the post to account for that.
TEW
16 May 2008
There are wholesale changes to FGW advance fares. The old ticket types have been replaced by new ones, with a far greater number of tiers of Advance tickets. The reason these are showing as unavailable is that in doing this FGW have uncovered a bug with the National Reservation System. It is unable to search for fares where more than 99 ticket types exist for one flow. These new Advance fares mean that for some flows there are now more than 99 ticket types. A fix has been worked on and Advance tickets should be available normally soon.
Starmill
18 May 2012
Bolton
That sounds entirely reasonable to me. I suppose more tiers mean price can be more closely matched to demand. Something like this could also have been anticipated given the reduction in First Class capacity and the shake-up of walkup restrictions on some lines.
Hopefully it will also mean the prices of empty trains currently can go down.
Mojo
7 Aug 2005
I noticed this the other night and was going to post something but thought it was just me because I had been doing so many searches! I was looking over a couple of days at travelling from Paddington to Parkway (Bristol) and had to buy it from www.fgw.co.uk as all other WebTIS websites were only offering walkup fares. theTrainline sites were however functioning correctly.
I personally find FGW's yield management usually works in my favour; trains I regularly wish to travel on I can usually buy the cheap tickets for Second class travel at quite short notice, although admittedly the lower tiers are usually a few pounds expensive compared to similar distances with other Intercity operators. Cheap First class travel has been quite a challenge in the last few months though, even when booked the week tickets go on sale!
*99* ticket types?! Really? How many tiers do they need? I'd have thought 20 or so would be the most you'd even consider needing, then add maybe 20 walk up fares at most. Which ones have got over 99 and how on earth have they managed it?
TEW
16 May 2008
99 seems pretty excessive to me too. There's probably a reason the bug has never been discovered before, because 99 is such a large number of ticket types for one flow. These changes introduce 34 new Advance ticket types. So on some flows which have AP routes both FGW Only and AP Slough this has pushed them over the limit.
CyrusWuff
20 May 2013
London - Exeter must be pretty close to the limit, given you've got two routes for walk-up tickets (Honiton and Taunton), three for daytime Advances (SWT only, FGW only and AP Slough) and one for the Sleeper.
gareth950
3 Nov 2013
Does this bug also apply to buying advance tickets over the counter from station booking offices? If so I hope it's resolved in the next 2 weeks, as by then I've got Rail vouchers to spend on buying FGW advance tickets for a trip to the South West in the summer. :|
trainophile
28 Oct 2010
Wherever I lay my hat
Thanks to this thread I booked some 1st Advances for July last night, having been checking every day for these on other sites without any luck.
I selected a station in England for collection, but tried today at Dundee as I was there, and it said it didn't have them. Definitely put the right ref in (tried twice) but no good.
Is there a problem with selecting either English or Scottish stations for ticket collection? I thought they would be interchangeable as they are all listed.
Edit: Ignore this, got tickets from Virgin machine at Aberdeen. Must be the Scotrail ones it won't work with.
causton
4 Aug 2010
Not sure, would report it to Scotrail as probably a communications issue from the TVM as there is absolutely no difference made whatever station you choose. I don't even know if the station is stored anywhere in the ToD database after you choose it; it is just to ensure you choose a station which actually has TVMs/counters to pick them up from!
Greeby
15 Apr 2011
So why not just have AP Slough then?
CyrusWuff
20 May 2013
FGW only is generally a pound or so cheaper, but AP Slough is more flexible in terms of excesses as it's a geographic restriction rather than a TOC restriction.
DEE-DE
25 Oct 2014
Did anyone notice some anomalies when looking for Underground Zone 1 stations. I had a look for Euston to Penzance for both before and after the timetable change. This only concerns 1st Advances. Before the timetable change the extra for the tube is about £2 which is reasonable. After the timetable change this increases to more than £10. I suppose this isn't supposed to happen. If this isn't resolved until next week and I decide to travel 1st I'll have to split the whole journey into two parts, one for the Caledonian Sleeper, one for the tube and then Paddington to Penzance.
I also noticed, looking at the 10:06 Paddington to Penzance service, that when adding the tube journey sometimes the FGW website doesn't offer the Super-Off-Peak single. This happens when you select St Pancras, probably because of the restriciton "Not valid to depart LONDON ST PANCRAS 0230–1025 on any tOC". But I suppose this shouldn't apply to London Underground. This is independent of the fare changes though. And it can be bypassed by using National Rail Enquiries, even when buying through FGW.
Busaholic
7 Jun 2014
Bring back King George I , all is forgiven.
Perhaps FGW are seeking to do a promotion with a tea company.
TEW
16 May 2008
It did originally but the fix was being applied gradually across all channels late last week. It is planned to be resolved within the next 2 weeks.
hangus78
8 Aug 2013
I noticed the trainline was at one point just neglecting to show any tickets that needed a mandatory reservation, without any sort of warning. So I assume any time NRS is down buying from the trainline is even more expensive!
Starmill
18 May 2012
Bolton
I bet it was London Terminals to Hereford that did it.
The existing AP SLOUGH NEWPRT, LDN MIDLAND ONLY and relative newcomers VWC & CONNECTNS, all for First & Standard Advance, plus ANY PERMITTED, LDN MIDLAND ONLY, WARMSTER-SALSBRY and VIA EVESHAM singles and returns. They have now added GREAT WESTN ONLY First & Standard advances, and probably something like AP SLOUGH EVESHAM to cater for travelling via Evesham but using LM as the connection west of Worcester. That could easily have come to more than 100.
Another one for you to ponder over here Neil is Cambridge to Manchester stations. Advances come in routes as follows but where was it intended that you travel with each:
CHESTFLD&EMT&CON
XC ONLY
AP XC EMT & CONS
PETERBORO & EC
✠VWC & CONNECTNS
Tell me that is not proliferation of variety!
Answers on a postcard please :p
CyrusWuff
20 May 2013
Reading Stations to Sheffield is another good one:
  • ✠ via Chesterfield (00129)
  • ✠ AP EMT & Connections (00486)
  • not via London (00700)
  • XC & Connections (00439)
  • XC Only (00024)
  • AP XC Only DBY (00488)
  • ✠ Any Permitted (00000)
  • ✠ EC & Connections (00430)
