Chiltern - Trainee Train Driver - Bletchley (06/09/23)
mattymat
23 Dec 2022
I think the paper exercise still helps you develop the skills like picking info out quickly that can be transferred to a computer screen?
7819Hinton
5 Jan 2022
There’s some good software that is similar to the test. Top result on Google. it’s not ‘how 2 become’.
There’s also plenty of plugs on here for really good software with minimal searching.
It’s not free, but depends how much you want the job.
why would you not over prepare?
RogerDoger
17 Sep 2023
Buckinghamshire
I have just completed mine. I was expecting SJT as well as the VSE as alluded to in the practice materials, but I only had the VSE when I logged in.
I would say it isn't particularly like the examples they give you, especially the letter comparison, but the theme is similar.
First two individual elements are nothing to get stressed about, but it certainly ramps up when you are required to do them at the same time. I have no idea how I have done tbh. I know I messed a few up
Will have to wait and find out
Best of luck everyone
12LDA28C
14 Oct 2022
Has anyone done the VSE test yet?
If you search for other recruitment threads on here there are many who have done the VSE test, if it's other people's experiences you are interested in.
stelczkrisz
23 Jul 2023
Daventry
Good luck! How long does it take roughly?
7819Hinton
5 Jan 2022
That’s your opinion, which you’re perfectly entitled to.
The packs they provide you with are ok, but are limited in content.
Everyone is different and some may reap the benefits of some additional practice material.
I wanted to make sure that I left myself in no doubt as to the outcome of my results, in that I had prepared as much as I could have done, leaving nothing to chance.
Some will fly through without having to do much practice at all.
Ultimately it’s down to the individual and their perception of their own skills and abilities.
nickman
19 Sep 2023
Milton Keynes
Any links for that ??
7819Hinton
5 Jan 2022
Any links for that
12LDA28C
14 Oct 2022
Showing initiative, doing one's own research and not requiring to be spoon fed might be considered a positive attribute to possess when applying for a job. An inability to type a few words into a search engine - not so much. Just something to bear in mind.
7819Hinton
5 Jan 2022
You are spot on.
Apologies ’nickman’ but they are right.
George2000
6 Oct 2023
Bletchley
Just wondering, after completion of the OPC visual search exercise, will you be contacted if successful? On the other hand will you still be contacted if you have failed? Thanks for the help in advance
RailKing
6 Oct 2023
Milton Keynes
If someone has received a rejection email, it's pretty safe to assume that all unsuccessful candidates who have fallen foul of the initial sift will have received a similar communication. If an applicant has not received such a message then it's a fair assumption they are still in the process.
I have still not received a rejection email…is it safe to say I’m still in the running and will get the VSE test soon?
mattymat
23 Dec 2022
Can someone who’s done it give in depth examples of the VSE test and what comes up please? I’m still waiting to hear back.
Are there 3 rounds of questions?
RogerDoger
17 Sep 2023
Buckinghamshire
First round is the track where there are multiple stations (dots). You need to watch and if there is an error click a button. An error may consist of the dot moving more then one space, moving backwards, changing colour or there being more then one dot on the screen.
Second test you have a cabin panel of shapes adjacent to another which represents the signal panel. On each panel several shapes will illuminate and you need to click one button if the signal and cabin panel are the same. And another button if there is an error.
The third test is to complete them both at the same time.
Honestly wouldn’t panic too much about them. The first two exercises are simple. The 3rd is pretty challenging but just read the instructions carefully and crack on with it. Honestly don’t think you can really prepare for it.
Aviator88
22 Oct 2012
Strangely, I found Part 3 the easiest - I think I only made one mistake on it, compared to about 6 mistakes on Part 1. Parts 1 and 2 are your first exposure to a new challenge, whereas Part 3 is more a test of multitasking and prioritising ability, and you can almost leave the individual tasks down to your autopilot to manage, because you know how to deal with them already.
Best advice I can offer - if you make a mistake, you haven't failed. If you make many mistakes, you probably will. So when you make a mistake, forget about it immediately and refocus. Good luck everyone!
Theoffs
14 May 2022
Concentration and speed is key for the tests - you are timed with your responses! Tests 1 & 2 are fairly straightforward - test 3 you will need to be alert and on the ball!! Remember it says on test 3 - the rail track is the PRIORITY - so concentrate on this first and then check the symbols!
mattymat
23 Dec 2022
I’m thinking of doing it in a library where there will be background noise my laptop is too slow. I’m hoping it won’t affect concentration?
stelczkrisz
23 Jul 2023
Daventry
In my opinion library should be quiet enough for the test. As long as the internet connection is good and the mouse is working you should be fine just need to focus on the test. I completed mine at home but it’s been ages since i used a mouse so it was crap sometimes.
