Chiltern - Trainee Train Driver - Marylebone (11/01/24)
12LDA28C
14 Oct 2022
The back of beyond
Yeah I understand that.
But I mean as in when you first start your application there are no online tests, you simply complete the application then wait to receive a VSE link after sift.
Yes, correct although in previous rounds of recruitment a second questionnaire was sent to everyone who passed the initial sift, before the VSE test was sent out via email. Things are being done slightly differently this time.
6 Jul 2021
South
Thanks for the heads up.
Echomike01
25 May 2023
Salisbury
hoping I get a VSE invite soon, I’m 45 minutes commute and I currently work on the railway and it’s not like there was any online tests so can’t think of why I would not get an invite, but we shall see.
Fingers crossed
Checked your spam folder ?
6 Jul 2021
South
They got back to me and said I had been rejected either due to location or OPC results, and I’ve never completed an assesment centre for it to be the latter so must just be my post code, shame though as I am within in a 45 minutes commute.
Alandev
24 Nov 2023
Does anyone know if it's only a VSE after the initial sift or has anyone also been asked to do a situational judgement test at the same time as the VSE?
12LDA28C
14 Oct 2022
The back of beyond
The current process should be initial sift - VSE - SJE - OPC - DMI with each stage dependent on passing the one before.
Alandev
24 Nov 2023
Thanks for that. I know DMI = Drivers Manager Interview but please can you confirm if I am right on these two?
SJE = Situational Judgement Test? (I saw that noted as RSJT somewhere else)
OPC = Criteria Based Interview
Also how long after passing the online VSE would you expect it to be before these other three things would be done - and would they all be at a test centre on the same day? (Assuming you don’t get eliminated at any stage).
Also I saw all of these other test types detailed here:
Do you know if Chiltern / Arriva also get you to do some / all of these if you get past the stages of VSE - SJE - OPC - DMI?
If they do, do you know if there are usually some days / weeks in between passing the first four stages and being asked to do any other tests?
Alandev
24 Nov 2023
Update – I have just seen the below post from TacoTraveller page 2 of this thread. Do Chiltern make you do all of these after completing the VSE - SJE - OPC - DMI (if successful at each stage)?
You don't re-do any test, you just do different ones.
If you complete the at-home tests you'll be invited to an assessment day spread over one day or two days (TOC dependant)
Those tests will include:
Group Bourdon Test
TEA-OCC
TRP 1
TRP 2
WAFV
ATAVT
2 Hand Coordination
If you pass all those tests you'll then do a MMI, then pass that you'll usually do a DMI but some TOC's do DMI first.
sal2323
8 Feb 2024
Has anyone heard back regarding their VSE test yet? I was sent an email (after completing the VSE test on 01/02/2024) saying that successful candidates will be contacted from 08/02/2024 onwards.
london96
13 Jan 2024
I heard back to unfortunately didn't pass. Best of luck to those who did going forward.
sal2323
8 Feb 2024
I did too this morning - didn't pass either. Part 3 got me for the first ten seconds and only then did I simultaneously work on both sides. Best of luck to everyone else.
12LDA28C
14 Oct 2022
The back of beyond
SJE / SJT is as you describe, this would be sent to you via email.
OPC is the suite of various tests (which you have mentioned) carried out at a testing centre (usually Watford) and can be carried out over one or two days which will include an MMI interview.
There is no set timescale after passing the online VSE test before progressing further. It depends on various factors. The DMI would be an interview with a manager at the TOC after you have successfully passed all other tests.
I'd encourage you to read through the various threads dealing with recruitment as there will be plenty of information here relating to what you can expect, any questions you might have will have been answered many times before.
The first four stages? The DMI at the TOC is the final stage and if you are successful there then you would be offered a position dependent on passing a medical
Alandev
24 Nov 2023
Thanks very much for all of this - I think that's all clear now. And yep, will definitely search around for more details on what to expect.
Idontknow
12 Feb 2024
Pluto
Hi all,
I completed the vse last week Friday and received my invite to stage 1 testing with the opc this morning. I never sat any online sjt. I was shocked because I certainly made a lot of errors on the third part.
12LDA28C
14 Oct 2022
The back of beyond
Hi all,
So you completed the VSE three days ago and have already been told you've passed and invited to full OPC testing? That sounds unlikely.
Murgy_murg
13 Nov 2023
Just received mine. Is anyone aware of what the Chiltern Stage 1 assessments may include ? From what I have read in the forum it looks like stage 1 includes Group Bourdon, TEA-Occ, TRP 1 and 2.
Is anyone able to provide any further insight into whether these are typical stage 1 tests for Chiltern or whether it is worth practicing other assessment materials ?
Thanks.
King8989
23 Jun 2023
I have passed stage 1 before to standard but failed enhanced. i believe i failed fault finding and passed everything else. i believe fault finding is not involved. would i have to resit the tests i passed previously ?
Idontknow
12 Feb 2024
Pluto
Thanks.
Surely 8 hours is too much for all those tests? I thought we would sit all the tests in one go including mmi and leave as we fail them. Then those who pass sit a dmi and medical e.t.c.
Murgy_murg
13 Nov 2023
I'm really not sure to be honest. I was curious because of the wording of "stage 1" assessments. I wasn't sure if there would be a second set of stage 2 assessments. I hadn't heard of that many people doing all the assessments in a single day to be honest. Correct me if I'm wrong though.
Umer
13 Feb 2024
I got the stage 1 invite but it says assessment date 2025. Surely thats a mistake. Does it say that for everyone?
Idontknow
12 Feb 2024
Pluto
Hopefully someone more knowledgeable will come along shortly.
Mine says stage 2 testing will be in “January TBC”. Hoping that’s a mistake too. I guess it all depends on available course spaces.
12LDA28C
14 Oct 2022
The back of beyond
Whether or not OPC testing is done in one day or two depends on the number of candidates being put forward for testing. More people attending the testing would mean two days are required.
Ses16
23 Sep 2022
Here’s my thoughts. When I had my stage 1, we were based in a hotel because there was so many of us. But for my mates Stage 1, they’re having it directly at the OPC office. So I can only assume there’s not too many to be assessed for that depot.
Also I’m pretty sure that it will just be the stage 1 assessments but prepare yourself in case you’ll be sitting the full whack.
Zest49
8 Jan 2023
Does anyone know what the shift patterns are like for Marylebone? Also how easy is it for a new driver to permanently swap turns with another? I think I could do any pattern wether late or early, I’d just need the consistency.
12LDA28C
14 Oct 2022
The back of beyond
It is possible to swap however I don't think as a brand new driver you should be allowed to swap onto a permanent shift. If you can't handle the alternate earlies / lates I'm not sure you should be applying for a job as a train driver.
