Class 142 Pacer Motors
Gareth Hale
11 Jun 2005
Does anybody know where I can get decent 142 motors, just after driving my Class 47, the 47 is a lot smoother. The 142 model was made in 1987, just in case they require special types of motoers. :hello1::hello1::hello1::hello1::hello1:
The Snap
10 Jun 2005
TAS said:
Exactly! Don't let Rich hear that though!:p:lol:
I beg your pardon??? :o :p No, I agree, the motors in the Hornby ones are naf, and you don't get a good smooth running with the train, as there are only 4 wheels to pick up current, rather than 8! ;)
The Gricer
11 Aug 2005
MP 34½ SWML
Early versions of the Hornby Pacer had both cars motorised. Later ones only had a motor in one car. Also some versions had the pickup connections paralleled through the coupling. As you might expect the dual motor ones with the paralleled pickups always seemed to run best.
Frank
158809
16 Jul 2006
Kent
Frank
ive got that pacer. When i take 1 set of wheels of the track it doesnt move which i suppose is good so you know when its off the line.
The Gricer
11 Aug 2005
MP 34½ SWML
Well actually if that's the pacer you've got then that shouldn't happen. The idea of connecting the pickups through the couplings is so that the situation you mention doesn't happen. i.e. as long as one set of wheels is making good contact with the track the motor(s) should still receive power.
Frank
Coxster
9 Jun 2005
The Pacer shown in Dad's post is actually mine :D It's a GMPTE one with a replacement Northern Spirit chassis which I believe was actually on a later version of the Hornby Pacer so yours may be the latter version.
158809
16 Jul 2006
Kent
no no no no no no. the problem with mine is the metal clip that connects with the one from the ohe cra is bent so i have to wedge it so it will work
