Maybe it's my age - but I find yellow fronts odd!
Does not look like there is any room for yellow.
Lets hope it has far less issues than the 700s have on Thameslink. Five months until they first run in public service isn't it?
Just how much of a revolution is it from the 387s?
Sooner than that.
To be fair the 700s are a completely new type of train and SWT won't have to do quite so much testing as GTR had to.
This thread is to discuss the Crossrail Aventra units, not SWT 707s.
My "expert's prediction" is that they'll be a reliability disaster for the first few weeks, before bedding in. Much like all new equipment tends to be.
345 undergoing climatic wind tunnel tests in Austria. Photo courtesy of TfL.
They must have to insulate the open gangway really well to conduct the testing!
Why on earth would a metro train going through tunnels and brushing against diesel traction have open gangways? Ventilation or something?
Why would they need to insulate the gangway? It's testing whether the train still works (electrics etc) in extreme weather conditions.
Note that it is a single car in the testing chamber. In service, there will be something attached to the gangway at the rear that could otherwise be described as open at the time of the photo unless there were to be some form of insulation.
Surely the train's failed as the driver cannot see out of the front window?
Just think about your comment. The test vehicle is a single car with a full gangway at the opposite end to the driving cab. This gangway doesn't have any door as it is permanently open through the train. Now if you are testing the train in sub-zero temperatures, it is reasonable to assume that it refers to the extermnal temperature. So just as the passengers appreciate that the temperature of the train is controlled, so do all the internal systems, fabrics and finishings perform as intended in that environment.
Thus it is necessary to place an insulated closure over the exposed gangway opening during this test to replicate real-world climatic conditions.
I thought the whole point of introducing them this early was to intentionally go through all that now so that potential issues when the really crucial central section opens are minimised. They'll also potentially be doing the proving work for the Aventra series as a whole - I imagine the 710 and (whatever class the GA units will be) deployments will be made simpler by virtue of this.
Its nothing to do with interior comfort, finishings etc, it's a test of mechanical system function in extreme conditions. Im well aware there is an open gangway at one end, my point is that should have no bearing on mechanical function and therefore this test.
Some of the carriages have internal doors which I assume operate in an emergency. Can't remember whether the DMs have them or not, I don't get much time on the assembly line.
Operations director Howard Smith said: "It's important that we check that the new trains can operate in anything that the changing British weather can throw at them and it won't be long before our customers will be able to get on board a train."
Weather simulations tested the heating, ventilation, air-conditioning system, windscreen wipers, demister, train horns and traction motors.
Quoting the BBC:
I would argue that the HVAC systems are most definitely there for passenger comfort!
Really? Best you keep away from the assembly line in that case
The only internal doors on a class 345 are from the driving cab into the train. The rest of the train is just one big open space to cope with passenger loadings.
Once I was told about them, they became easy to see on the 700s.I expect that there will be some sort of emergency partition doors that'll be able to be deployed in the event of smoke in the passenger area.
When I read that quote from the BBC report, I couldn't help noticing the omission of "doors". I'm hoping they will be as reliable as the rest of the systems tested once they encounter a British winter.
