Class 390 Pendolino Question
Discussion in 'Traction & Rolling Stock' started by Ash Bridge, 24 Jan 2015.
Thread Status:
  1. Ash Bridge
    Ash Bridge Established Member
    3,270
    17 Mar 2014
    Stockport, European Union.
    Is it possible for a Pendolino to be in service with 3 Panto cars?
    Today at 14:40ish I was sat in the car at The B&Q car park at Heaton Norris which is located alongside the mainline between Stockport and Manchester Picc. An 11 car unit passed bound for Manchester and I was certain there were three cars with pantograph wells in the set, am I seeing things?
    Rail Forums
  3. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    No, all 11coach sets have 3 coaches with pantograph wells, only the 2 pantographs though.
    I think it's because they needed an extra transformer or something which is mounted on the PW coach, I think it is F which has it, if not then it's U! ;)
    How is that for covering the bases? :lol:
  4. starrymarkb
    starrymarkb Established Member
    5,985
    4 Aug 2009
    Exeter
    Yes, it was easier to use the existing panto/transformer coach design insead of designing something new but instead of the pan there is just a connection to the 25kV cable that runs along the roof (and a Circuit Breaker)
  5. najaB
    najaB Veteran Member
    19,438
    Ah, okay. I thought I remembered reading somewhere it was future proofing in that they were buying extra carriages anyway, so it made sense for some to have the pantograph well 'just in case' any pantograph cars need to be replaced at a later date. That answer had never quite made sense to me.
  6. Ash Bridge
    3,270
    17 Mar 2014
    Can't believe I've never noticed it before, especially close up at the station, many thanks for the explanation:) etc;)
  7. WatcherZero
    WatcherZero Established Member
    9,081
    25 Feb 2010
    Wernt they at one point thinking of adding a third pan for redundancy in case one was broken? Since they already had connections and well.
  8. cjmillsnun
    cjmillsnun Established Member
    2,934
    13 Feb 2011
    I doubt it as they normally only run with one pan up (the pan to the rear of direction of travel), so already have redundancy.
Thread Status:
Share This Page
