Internal communications suggest the following order for 701 introduction:
Reading
Dorking and Hampton Court
Kingston Loop
Hounslow Loop & Weybridge
Woking, Guildford & Chessington
Windsor
Shepperton
And it's been suggested elsewhere that some 450s will remain on Reading services longer term anyway.Thanks for info,
Suggests there will be a mix of old and new trains for some places for a while
eg Epsom and Leatherhead tend to see a Dorking train alternate with a Guildford train
Similarly Kingston trains alternate between loop and Shepperton services
Reading
Kingston Loop
Windsor
Shepperton
I'm assuming by "Windsor line" he actually meant "Windsor Lines", ie Reading, Windsor, Hounslow loop, Chertsey. A performance enhancement is certainly needed on the Reading line.Cheers. That looks like removing some 450s and 458s upfront too on the Readings with the first 455s to go from Dorking and HC (presumably with some 456s being used strengthen some Woking, Guildford & Chessington services that are currently 10 car in the interim. Looks like the 707s staying on the Sheppertons till they go.
Given Mark Hopwoods recent "we've triaged the Shepperton service performance, Windsor line performance next" one does wonder if solutions involving more/all 10car with wide doors and large vestibules will be needed sooner rather than later so things might be rejigged again.
The first step would be to eliminate 450 usage. The door cycle times on them kills sectional running times. I rather suspect, though, the "solution" will be to insert more padding in the timetable, as Great Western has done for years.A performance enhancement is certainly needed on the Reading line.
The very short term solution is to run 707s instead of 455/456/458/450, the problems is there are only 30 units... Robbing Peter to pay Paul as the expression goes and they have already used that trick for Shepperton!The first step would be to eliminate 450 usage. The door cycle times on them kills sectional running times. I rather suspect, though, the "solution" will be to insert more padding in the timetable, as Great Western has done for years.
It was to do with automatic door opening wasn't it?Does anyone know how exactly the 701s will achieve even shorter dwell times than the 707s. Aventura have slightly slimmer and slower opening doors than desiro cities, their aisles appear to have been specified by the DfT to be equally wide also.
Yeah that might be it. I didn't realise it was completely down to the automatic braking/door opening but it'd make sense.It was to do with automatic door opening wasn't it?
A uniform fleet (all 10car not just 70%) with the doors always being in the same places on the platforms will help in addition to ABDO.Yeah that might be it. I didn't realise it was completely down to the automatic braking/door opening but it'd make sense.
I thought that elephant in the room wasn't allowed to be mentionedWhen they become doo
An item on BBC's East Midlands Today programme about the ALSTOM take-over of Bombardier tonight (18/2/20) showed a 701 on the test track at Derby running as a 25kvAC train
New trains are often certified on both systems, from memory the first two 707 had pantographs and transformers fitted for certification, they were then removed. Similarly the first 3 450s (or whatever the first 3 units of the 25 unit speculative order were classified at the time) were tested on both systems, think these got refitted and the ac parts ended up in 360s
The one on the Velim test track is on ac as that doesn't have third rail
the first
It means the train can subsequently be leased to an ac (or dual voltage) Operator if required.
However I would not expect fitting of pantographs and transformers to the 701s except for initial test units (and the test ones may have borrowed equipment intended for the Anglia units, so will be removed after testing)
I would have expected Bombardier to have equipped an early train with just a DC traction package and for the 3rd rail equipped Derby test track to be used for early and intensive testing at that voltage in case the omission of certain components which are only required for either AC or dual voltage operation create "problems", and further delay delivery and acceptance of these EMUs
I would have expected Bombardier to have equipped an early train with just a DC traction package and for the 3rd rail equipped Derby test track to be used for early and intensive testing at that voltage in case the omission of certain components which are only required for either AC or dual voltage operation create "problems", and further delay delivery and acceptance of these EMUs.
Pretty much - this isn't the 319s 30+Years ago.As I understand it, the "AC traction package" can essentially be regarded as the "DC traction package" plus a transformer and rectifier - they both work around a ~750v DC bus input, which is fed from the shoegear when in DC third rail mode, and from the rectifier in AC OLE mode having been stepped down to the correct voltage. The only effect that removing the AC equipment should have is making it lighter!
The other way of looking at this is realising that the 701 still has an "AC traction package". No recent trains have a DC traction package. It's the incoming end of the power supply that changes...As I understand it, the "AC traction package" can essentially be regarded as the "DC traction package" plus a transformer and rectifier - they both work around a ~750v DC bus input, which is fed from the shoegear when in DC third rail mode, and from the rectifier in AC OLE mode having been stepped down to the correct voltage. The only effect that removing the AC equipment should have is making it lighter!
How about 5/10 Sub I know we had sub used before but not the 5/10 bit!A name for a suburban commuter fleet seems like a bit of an odd one, although I suppose they're allowed to refer to them however they like internally!
I might cheekily suggest 5/10ARS - Aventra Reading Suburban :P
Was also posted twice in this thread last month. Posts #1282 and #1295.
Just came across this excellent video on YouTube
The plan published as of late last year was for the first 10 car unit to arrive with SWR in "early 2020".There is a rumour doing the rounds one is due to arrive very soon, as for when? who knows.
Forgot to post these, I took some photos of an unidentifiable five car unit at Velim last week.
