The HST shore supply isn’t compatible with IETs sadly.
You really would have thought that by 2018 and all the expenditure on the project, this one would have been cracked.
I think that should be "at most" 110mph on Diesel. Not as fast as their predecessors. But also, not as quick to accelerate. So, overall, slower.
However once there are no (or very few) HST's running presumably it would be fairly easy to convert them to be able to power 80x's during their turn around at platforms.
Generally with utility supply the big city is getting the supply to where you need it (i.e. digging up stuff to run cables) whilst the actual costs of the "box" is fairly reasonable.
There's an argument that given you can only power one train at a platform (and power supply systems being based on maximum loads) you could run two "boxes" off the one supply.
As such if suggest that in, say, 12 months time there'll be a program to change them over, with a few platforms at certain locations where HST's are likely to run being retained.
Well the IET was always meant to operate to termini "off the wires". Can it be that, despite all the hoopla about their 21st century environmental concern, etc, nobody has thought about how to prevent the noise and exhaust while they are sat on extended turnround at such locations. Adequate batteries, just run one engine, shore supply, has any thought been given to any of these? What about places like Penzance with a low overall roof?The issue will more likely be whether an IET has the facility to be 'plugged in'
Presumably as a result of the short formations of trains off Stoke Gifford reported on the allocations and diagrams sub forum.1B25 10:37 Paddington-Port Talbot (8000??) and the 1B28 11:37 Paddington-Port Talbot (800016) and return trips to London, both operated by just one 5 car 800 today.
Just got on the 17:00 Bristol to Paddington one of the busiest services of the day and it's a 5 car totally overcrowded. Is there a shortage of units, this has been an HST until yesterday when it was a 10 car 800. Sooner the 9 cars are here the better.
During the Swindon stop I had a chat with the very friendly Swansea train manager, who told me Customer Hosts are now being trained to be Competent Persons to take charge of the second set in the absence of two TMs.
This is the railway. Just because XC have been operating safely like that for years doesn’t mean anyone can...Which is what should have happened in the first place. What a shame that it didn’t.
Perhaps it is the HST that is a product of BR’s non-standardisation. In any case, how does anyone know yet if IET remote overnight stabling locations will be fitted with suitable supplies before they are needed? Do any IETs stable away from Hitachi depots yet?Given that the IET was designed, essentially from scratch, to replace the HST on trains out of Paddington, and to a much lesser extent EC.....
Why is the HST shore supply not compatible?
Who thought that was not a good thing to specify?
The post privatisation railways hatred of standardisation strikes again.
Thanks for confirming what was little more than an educated guess. As often happens a molehill has been treated as a mountain by some posters...Not yet - Worcester and Hereford will be the first two and they are being fitted with IET shore supply. The AT300 will use the GWR depots at Long Rock, Penzance and Exeter - they will also be fitted with IET shore supply...
You'd think that would be something that would have been standardised on long ago. If not by manufacturers then at least by an internal standards body.
I guess the way trains are used doesn't make it worth the effort to force such a standardisation.
Wouldn't it be easy to run a single contact wire over the tracks in stations to feed stabled trains? This would avoid staff from having to access the track to carry out manual handling of the shore supply cable. I know that it might cost a bit more than an extension lead but it would be out of the way of the p'way gang and away from contamination by diesel engine leaks etc.
All the disruptive piling & construction works associated with traditional electrification would still apply - the only difference would be that you would have 1 wire instead of 2.Wouldn't it be easy to run a single contact wire over the tracks in stations to feed stabled trains? This would avoid staff from having to access the track to carry out manual handling of the shore supply cable. I know that it might cost a bit more than an extension lead but it would be out of the way of the p'way gang and away from contamination by diesel engine leaks etc.
Only places that tend to have single "trolley" wires are depots.
Ah yes, my mistake.Paddington looks like it has a single contact wire
Ah yes, my mistake.
I think special exemptions may be given for listed terminal stations (King's X is another that springs to mind), but a system of that nature would be fairly useless at a through station like Temple Meads.
I'm sure you can get away from it inside Temple Meads' Digby Wyatt shed, but not on the platforms to the south...you might as well add in an "updated" modern overall trainshed roof over P6-15 while you're at it!It depends on what sort of speeds you are dealing with. @GazK's book says that Tramway OLE is suitable for up to 30kph and has to have fairly close spans. Add stitching either side of the mast and it is good for 80kph, which I would think is more than enough for Temple Meads. I suppose the difficult thing to consider is whether the costs saved by having a simple system like that are lost by having to have more frequent structures. In stations with grand old train sheds, you can probably get away with it as you can string up structures from the building
Maybe a special for November 5?If people wonder why there is a separate earth for Traction, just think what a 25kv to earth fault would do if it tracked across the mains supply to a station and, potentially, nearby properties.
