Class 93 Tri-mode Loco
Nym
2 Mar 2007
Somewhere, not in London
Technically, no. Practically? It's hard to see any potential customer wanting MKIV compatibility and therefore justifying the cost of modification.
So them LPA jumpers on the front are for decoration then?
They don’t look like the 27 way AAR ones used for standard AAR coupling.
23 Nov 2015
No, I would think they are to do with interfacing with the units that they may spend some of their time dragging - there are similar sockets on the front of the 37s ROG use.
The multi-working on the 93s (as it is on the 68s and 88s) uses the two smaller grey sockets next to the orange LPA sockets - and uses standard UIC jumper cables. Presumably some form of WTB control system.
Nym
2 Mar 2007
Literally what I said three posts previous...(!)
The 27 way jumpers for dragging units are subtly different to those on the front of the 93.
(They look very much like Module 42 or Module 52 Clip Retained jumpers from LPA, the "27 way" ones used on the front of locos for adapting onto the units through jumpers are slightly different in that they have a different cover casting to the more modern LPA ones.)
craigybagel
25 Oct 2012
If they've gone to the effort of making them compatible with MKIVs with the TfW mods that would seem a very strange expense to go to given that TfW have shown little interest in them and as I've repeatedly pointed out, they don't appear to have enough power to work TfW services on diesel. Unless there's someone else planning on scraping together the remaining MKIVs when they become available and putting them to some use?
ExRes
16 Dec 2012
Back in Sussex
Why would TfW show any interest in a freight loco?
craigybagel
25 Oct 2012
It's debatable if these are really freight locos since they are seemingly capable of providing ETH. That said, my post was questioning another poster who believed the 93s could or should be compatible with MKIVs. I don't expect TfW to show much interest either
xotGD
4 Feb 2017
A locomotive with a pantograph would make sense for the Cardiff - Manchester services. A good proportion of the route is wired.
Whether Class 93 is the appropriate loco is a different matter.
ExRes
16 Dec 2012
Back in Sussex
I must be mistaken then, I didn't think they were fitted with ETH equipment at all
craigybagel
25 Oct 2012
Absolutely, a true Bi-Mode loco would be great. But it needs similar power to a 67 on diesel, and that's all of the time - not just for bursts of a few minutes when the battery is full.
Possibly mixing them up with the GBRF Class 99s? They have no ETH, which doesn't stop people suggesting they should be used on Sleeper services.....
Bertie the bus
15 Aug 2014
They've got an ETH index of 96. Post-order but pre-delivery one of the services they were touted as being for, and indeed the ORR application stated such, was the OAO London - Stirling service but that later changed to Voyagers and now seems to be set for these Hitachi units FirstGroup have just ordered.
Belfastmarty
14 Oct 2020
Belfast
On diesel mode 93s aren't really an appropriate replacement for a 67 or 68. No reason why they shouldn't haul passenger stock, although again they are rather more suitable for under the wires that away from them. Given the lack of appropriate use cases this would seem to make them de-facto freight locos.
Wyrleybart
29 Mar 2020
South Staffordshire
Erm, what is a freight loco ?
I would regard 93s as mixed traffic locos simply because they are built with a train supply
Belfastmarty
14 Oct 2020
Belfast
Yes, I agree they are capapable of mixed traffic use. The point I was making is passenger applications for 93s look few and far between - the most likely use is as a replacement for a 66 on intermodals, if they can find any customers to sign up for them.
craigybagel
25 Oct 2012
Exactly. Which brings me back again to questioning why you would bother making them compatible with MKIVs.
It might be worth remembering how sluggish a single 67 is, even light loco.
A 67 running light is anything but sluggish! Compared to an electric loco maybe.....
With 5 MKIVs and a DVT they can match DMU timings. They're slow to get moving from a standing start, but they pick up speed pretty quickly once they get going.
That said, you wouldn't want to replace them with something with less power - like for example, a 93 on diesel.....
Wyrleybart
29 Mar 2020
South Staffordshire
One particularly useful task for the class 93 would be the class 360 unit swapovers between Kettering / Bedford and Northampton. A fairly low speed totter across the Marston Vale then a gallop under the wires to Northampton and back. Although why does the diesel need to go beyond Bletchley, unless the 360s are needing to be hauled.
Obviously these are GBRf workload, who do not have class 93s !!!
Class15
30 Dec 2021
North London or Mildmay line
Am I missing something or do these workings not run via Carlton Road Jn, South Tottenham, Lea Jn and Camden Jn? I’ve seen them many times along that route.
31160
18 Mar 2018
But even if they got the contract off GBRF how on earth would this pay enough for brand new locos, they might have a super secret job lined up for these but no sign of it yet
Meerkat
14 Jul 2018
Or they are relying on regulatory pressure when a politician on a green crusade or a London mayor decides that new shiny locos that can decarbonise and depollute freight trains mean they can restrict diesels. Or a client asks the FOC to help burnish their green credentials after seeing an advert for new shiny green locos.
CDM Transport
26 Aug 2022
Despite looking all over, I couldn't find a forum on it. Are the 93s replacing the 37s or not? Someone told me they are but someone said that the 93s are not doing unit moves and the 37s will continue doing what they are doing.
ChristopherJ
Repeatedly returning banned member
8 Aug 2005
London, UK
GBRf have the contract to move the EMR 360s and would use one of own Flakes (99s) rather than a ROG 93.
Yes. Initially, the EMR drags used a circular route via London, taking them back to their old haunt at Stratford (GA) before heading back up the WCML to Northampton!
Wyrleybart
29 Mar 2020
South Staffordshire
Of course. I was using that traffic flow as an example. A similar way to the drawback loco used to haul the ECS off the Up Cornish Riviera back from Paddington to Reading, and moreso the ECS for the Down Riviera which would sit on the blocks at Paddington under the overall roof.
From what I read at the time the 93s would replace the Europhoenix / ROG 37s for all their various activities, and with various benefits. An example would be a Kirkdale - Sims class 507 drag with vitually no AC use, compared to say an Ilford - Sims movement where probably the West London incline would be practically the only diesel part odf the journey - dependent on the authorisation of 93s to use OLE.
Spartacus
25 Aug 2009
I'd rather the 93s replace the 360s, horrible things that always seem to be breaking down! :lol:
