Computer Problems
S Lowes
11 Jul 2005
Birtley
Can some please tell me what this means, and is there anything that can be done about it :(
Techniquest
19 Jun 2005
Nowhere Heath
Never seen that one!
I don't THINK it's an important file, although I'm sure Cockfosters, the resident computing expert, can confirm either way on that. If it had been a .dll it had reported as lost, I'd be worried. Thankfully it's not.
Gareth Hale
11 Jun 2005
Do an Ad-Aware SE scan, and a spybot Search+Destroy scan, and if it doesnt help, delete the directory.
bloogrape
21 Nov 2005
Berkshire
Edonkey = Officaly spyware bro, same as bearshare, get rid of it and do a full system scan asap
Nitro
20 Nov 2005
Scott, I would suggest you got to www.download.com and get all the anti-spyware utilities you can get your hands on. Atleast one is bound to have it in its definitons.
class 313 said:
Looks like your hard drive has snuffed it.
I agree.
You clearly had spyware, and then your hard drive has failed. The message you got was a warning that failure was imminent.
You will need to purchase a new hard drive, and fit that to your PC. Hopefully you kept your original XP CD, and install Windows from scratch.
You can try fitting your old HDD as a slave and you MIGHT be able to copy some of your documents off it before it dies completely if it has not already done so.
But, in theory, you've backed up all your files so won't need to do this? ;) (In reality people don't tend to back up even though we all know we should!!!)
--- edited ---
But i cant get onto my XP installation, i typing this from the laptop:(
Does it start to load at all? If so, then the HDD isn't completely dead (yet), you may be able to copy any vital files off it before it dies. Take the HDD out, put a new one in and get XP re-installed. When that's done, put the old HDD in as a slave and hopefully you'll salvage some stuff.
S Lowes
11 Jul 2005
Birtley
Yes it does start to load it shows the device i have installed when i first turn it on eg: CD Rom + Hard Disk then it goes to the windows xp loading screen, stops then goes back to the start where it tells me what devices i have installed :confused:
devon_metro
11 Oct 2005
I had this problem on my old 98 machine, i had about 10 seconds whwn booted to disable the program before a forced restart...
Bloody annoying!
So your BIOS boot screen is working. Could have just mangled XP up, i have had to reinstall XP before.
Donny Dave
9 Jul 2005
Doncaster
From what I have seen here, your CMOS chip on the motherboard is fine. It's just that for whatever reason, XP has decided to stop working properly (not unknown for M$ products.)
If you want any help, I charge a reasonable rate of £15 an hour + VAT....
Tom B
27 Jul 2005
Have you tried safe mode? Alternatively you might get something from using a LiveCD - but I wouldn't be too optimistic.
I'd advise just getting AdAware - it picks up most things, having 50 anti malware programs just causes more problems than it solves. And do an update. And a scan. Regularly.
Also use some COMMON SENSE! Downloading anything which promises to "help clean up the registry" or "search faster" is most likely to be malware. As is any p2p software or things targeted at the newbie user. There is also now malware out claiming to be anti virus software - only use reputable products. Do a google if in doubt of ask on here.
bloogrape
21 Nov 2005
Berkshire
well said bro
Guinness
13 Jun 2005
Personally the only 3 Things you need are :-
Avast! Anti-Virus (Free for Personal Use)
Kerio Personal Firewall or Zone Alarms (Both Free for Personal Use)
Lavasoft Ad-aware (Again, Free for Personal Use)
Windows Firewall is really like using Tesco Toothpaste, it doesn't really protect or do much.
As Tom said, do a scan regularly e.g. when you go and have your Lunch leave your computer on and do a spyware scan. :)
S Lowes
11 Jul 2005
Birtley
Thanks for all the help guys, ive just ordered a new hard drive and am going to take everyones suggestions about the scanning utilities onboard :D
If you want to have a go at fitting it yourself, have a look on the web for guides ( http://www.google.co.uk/search?hl=en&q=fitting+a+hard+drive&meta= ) and if you have a question let me know (you can phone me for advice if you want).
I've got 3 hard drives and the important stuff is on at least 2, so if one fails I won't lose too much. ;)
I would personally never run a PC with just one hard drive. If anyone here has only one HDD then ensure you backup your important files (e.g. to CDs) regularly.
Remember Hard drives are the most likely component to fail (along with PSUs), because they contain moving parts.
Ben
8 Jun 2005
Anyone got an Idea of how much External HDD's Cost?
I Do need to start thinking about backing up files
Tom B
27 Jul 2005
External HDDs - might I ask what's werong with an internal one? You do get problems with them being awfully slow since many use USB (for those who think USB is fast, compare it with ||'l internal data cable).
Ben
8 Jun 2005
Scared of buggering My Computer up installing it.
Tom B
27 Jul 2005
I think you run Windoze? That's far more likely to bugger up your computer!
devon_metro
11 Oct 2005
IIRC installing an internal HD is not to hard. Plug it in and in the boot menu set it as a slave. Might be wrong...
Although they are cheaper and as tom says, faster.
Donny Dave
9 Jul 2005
Doncaster
Not quite that easy. you have to make sure the jumper settings are right (and the are fiddly little things), and also ensure that you get the IDE cable in the right way. I have seen a friend of mine who plugged the cable in upside down. It didn't do the HD much good.....
