(depending on which traction requires more voltage)?
Just less than 100k per single track km according to Network Rails Electrification Strategy.
A very comprehensive list of factors!The costs of electrification are driven by a number of factors, such as :-
Ah yes. I know them well! The ****** Residents Association, with Mr and Mrs Angry attending every Local Council meeting and having their comments on "outrageous" new plans in the local press whenever there's no real news.. . . a few vocal individuals who either seek attention or are generally opposed to all change.
Er... on page 29 of that document they say '500k to 650k' per single track km. (Although that could be brought down slightly, they think)
That's quite a difference to £100k - have I missed something?
I do wish that whenever major work is carried out on non-electrified that they would assume future electrification and design structures with this in mind; adds very little ( if anything ) to what they are doing anyway but saves a lot of time and money if it is later decided to electrify the route in question.
OK, it wouldn't mean everything would be ready for such an eventuality, but every little helps...
I believe its standing policy that whenever a structure (such as bridge or tunnel) is replaced or renewed its done to W12 gauge to save money possibly replacing it again later.
In urban areas there are often gas, water, sewage, electricity and communications services embedded within old bridges - these can take quite a while to move.been saying that for a while, but why dont they go the whole hog and make it to bern gauge?
The majority of bridges on the LGVs are 2 concrete supports and a concrete road deck, is it really that difficult to replace our old bridges?
No problem - I think it was brought to my attention by the requirement for a bridge over a preserved steam railway (Embsay possibly?) to have OHLE clearance when it was reconstructed some years ago. I think in the end they might have got a derogation from the standards, given that it was highly unlikely wires would ever be installed!Ah... I wasn't aware they were already doing that, thank you.
In open countryside it's often easier to replace the bridges - sometimes keeping the original piers and adding new precast concrete arches to give sufficient clearance for the OHLE underneath.
In urban areas too it isn't a simple job to raise the clearence even if the bridge carries no services. Steeper approaches will not go down well, and space for longer approaches is less likely to be available. Potentially a modern bridge can have a thinner deck I'd have thought.
but I dont understand why if they are clearing bridges for w12, why not go so far as to eventually allow double decker trains? UIC GB+ or whatever it is called now.
Southampton tunnel was recently cleared for that reason, but to completely discount going any further is baffling to me.
There has been research done into double deck trains in the areas where capacity is most needed, eg the former SR, and DfT's consultants reckoned it was a non-starter. The nearer you get to London the vast number of bridges over the railway becomes the limiting factor.
There are longer ones in the mornings and evenings- there's a lot of 12 carriage trains arriving at the london terminals in the AM peak, and dpearting in the PM peak, and far fewer at lunchtime and weekends. To go longer would require more long platforms- at most of the terminii the platforms already get rather narrow at the "country" end as they've extended into the throat/added more platforms. Even more 12 carriage trains requires more terminal platforms that can cope, plus more suburban stations long enough.
well there has to be some way to improve the standing room only London trains in the morning.
Neutral Sections form the boundary between two separate Feeder Stations. The neutral section itself consists of a central section which is earthed to the traction return rail. In this way it is impossible for a pantograph to "bridge out" the two sections of live equipment.When it comes to feeder stations on AC OHLE networks (which I presume are always accompanied by neutral sections), can two of the same be installed next to each other or must they always be positioned alternately with mid-point track sectioning cabins and their associated neutral sections (i.e. FS - TSC - FS - TSC etc)?
I'm particularly curious since it appears that a new Thameslink neutral section will be installed just south of Radlett Jn, in-between Grahame Park FS and Sandridge TSC.
... standing room only is not the way to commute
You've never had the pleasure of using London Underground then
