How many threads have we had where people have been delayed on the tube and then missed the train their Advance ticket was booked on and the general consensus is tough because the tube is not part of NR (or something like that)!
It's complex. But, in this case, the delay wasn't on LU.
If the delay was on LU, you
may still be covered for a journey (as in the tickets are not invalidated), but it depends on the exact tickets held.
However if LU caused the delay then Delay Repay isn't applicable. If there were multiple delays then it really depends on the exact circumstances.
Okay this is a through journey but the ticketed part was completed on time and using Yorkies logic (no offence) all you would have to do to claim your money back is to wait at the other London Terminus until you see a train cancellation and then put a claim in against it!
I can think of one family that do similar things!
Ah, I think you misunderstood then, as the ticketed parts were:
- Manchester - London Terminals;
- London Terminals - Uckfield (delay occurred on this leg)
The only part of the journey that may not have been ticketed (depending on the definition of ticketed) was LU, where it may or may not be relevant, depending on your interpretation of the Advance Fares FAQ, which may or may not be used to determine a journey for the purposes of delay compensation, depending on your interpretation of the term "journey".
Clear?
When crossing any other station group (Birmingham Stns, Bradford Stns etc) there is no 'requirement' to do anything other than walk. In the case of London Terminals, there is no compulsion to take LU, except for the fact that minimum interchange times require the use of LU (
except KGX-STP). This, in my opinion, only becomes relevant if you miss the departure time of the onward train (not applicable in this case). If you did miss the departure time of the onward train due to a delayed taxi, getting lost, delayed bus or so on, then that could potentially be seen as invalidating an Advance ticket.
I do not think the use of PAYG between the relevant London Terminals means that the journey is not from Manchester to Uckfield. This was not, in my opinion, three separate journeys.
